suspicious of paper cones
Humidity where I live is currently at 96%. My house doesn't keep humidity in or out, and a lot of the time we have humidity of 20%.
I must say, when humidity is high, the bass is a little wet. When humidity is low, bass is a little dry. My paper cones soaking up the water? Hmmm.
Maybe I'm just imagining it. Maybe it's the different music I happen to be listening to on different days. Maybe I'm just being silly and talking rubbish.
Mine too. That's what we get for having dealt with it. Usually quantified with a term such as "a little bit of."
Mine is bad. The cone was so dry and brittle it broke the minute I touched it. And this is my beloved Radian 502, the 8" coaxial.
Most paper (for any usage) is produced using acidic process. This means that the paper will disintegrate after several decades because acid will destroy it. But several decades is long enough to enjoy loudspeaker! Paper sounds the best, is cheap and easily available.
But the paper can also be produced using alcalic process. It will make it to last several centuries.
ICG
Disabled Account
Joined 2007
That is indeed extremely bad. That, however, does not come from humidity alone and that does not to appear to be dry rot, you'd see some of the funghi and spores. These drivers have a 'dust'-cap. What happened to the dustcap? How did you remove it?
Dry rot does not 'just happen'. Aside from humidity there have to be - like on all funghi - the spores, no to little air movement and the absence of light. On speakers light and air movement is given, at least in a normal living room.
For proximity to the sea there are other membrane materials much more susceptible to decay. Do you live, by chance, close to the sea?
