A WE-91B project
Another OPT is finished
Tonight I finished connecting the circuit and testing. It works, and sounded very good. The voltage of each tube is correct. But massive humming, begin finding the problem. And one more problem, when my hand getting close to the first stage 310A (but not touching it), the humming getting stronger
Hi jerry. Very well done so far. I have the very same problem with a valve preamp. I have narrowed it down to a loop, causing the hum. If I run the pre through a isolation transformer, gone. Check your grounding, and try shield the tubes. They are microphonic. This helped me out a lot. Regards
Hi Bren. I will check each stage to find out what causing the hum. I will post the process and help me with that, thanks.
