FirstWatt J2
Ok, with gain around 5.5 (90.9K + 20K), reduced CCS current on the front end (now 8mA) and a lower bias through the output stage (from 1A to 0.8A at 24V rails), I think it will all work just fine. Adjusting the diode current in the CNY didn’t do much to reduce the bias, so I added a resistor across the transistor side of the opto to adjust the voltage.
All this meddling allows me to not externally cut the gain at my active crossover, which was my goal.
So, still have some gain so hopefully back in “recommended” territory.
I suppose that raises the question of why not a F4J - despite the fact I don’t have enough devices...
well , almost ....... 🙂
Official Pass Labs Disposal Facility
