Thanks for the feedback! 🙂
That sounds like it is something upstream of the DAC (HQ player I guess) - as we have tested that with the 1.3V reg there are no issues playing any format the chip supports up the the freq supported by the master clock. 1.2V reg can run out of steam on the ES9038 at very high sample rates with a high master clock (As noted in that chip's datasheet) - that is why we offer the 1.3V reg now.
Cheers!
Russ
Cheers!
Russ
Here's what I have tried: Eliminated the Placid HD and used a 3amp linear supply. Eliminated the UFL cables, and used about 2" small ga hookup wire, tied all grounds together, checked voltage out on 1.3v trident, looks fine during noise issue. swapped out new cronus, for old (repaired by me) cronus thinking maybe it wasn't supplying the correct clock, or had some issue.
Only DSD is affected as far as I can tell. Played a 192/32 rip of a red book CD I made just for test purposes, played fine, as do other 96/24 and other PCM files. I tried a higher bit rate DSD256 and all I get is loud pop from the speakers, about every two seconds. Also, could not shut down Volumio after this happens, it's like the BBB is overloaded...
If I want to test with cronus MCLK, what needs to be done other than remove the XO reg and hookup a UFL or wire? I have tried to run ext clock to both the BII and BIII and neither will lock. The BIII lock will flash on at about 1hz rate, but not stay locked.
Any ideas? I know I'm throwing a lot of info at ya...
P.S. - This seems like a clock issue to me. Over a period of time, and it's not exactly repeatable, clocks are getting out of sync. DPLL setting change? Try ext clock? Sometimes it will play an entire song or two without noise, other times, I start to play a track, and it happens right away. It also seems like the DSD sound quality is not 100% even when the noise subsides. I listened to a 192/32 pcm last night, and thought it sounded great, but could have been the beer and exhaustion! ;-)
Widen the DPLL bandwidth and see if that helps 🙂 DSD256 is a very high rate - the BBB may not be keeping up well depending on the SW
That's what I was thinking to try, but I'm not exactly sure how to use the switch positions? Can you translate a suggested setting in switch position terms please?
Sure - on SW2 set positions 5 - 8 to off (1). Gradually decrease until you can't keep a good lock on your toughest source - then go back up one.
GitHub - twistedpearaudio/Buffalo-III-SE-Pro-On-Board-Firmware
Cheers!
Russ
Cheers!
Russ
Can this be done in real time, or does it require power down? Seem to recall it can be done real time, but better safe than sorry!
Either way works fine 🙂 Any setting change correctly resets the DAC as appropriate - so no need to power down.
Thanks! I went ahead and tried it live. Need more test time, but I am now playing a DSD128, DSD256 failed with pop and intermittent momentary lock attempts, this also causes loss of Volumio web interface with the BBB using ethernet cable. The browser interface did finaly come back long enough for me to pause the track, and stop the noise! But was not very cooperative.
Yeah that sounds like your BBB just running out of steam at that rate 🙂 Not actually very surprised.
Yea, about the BBB. I am running a 1TB laptop drive on the USB port of the BBB, with cabled ethernet to the BBB. Would using a NAS drive lessen the demand on the BBB? Or, do I need to go to a real PC? Could this all be caused by the BBB not having enough horsepower to do the job?
This thread is not really about the BBB, but my guess is it is the implementation of the DSD decoder or some other part of the software chain. Could even just be IO like disk or network IO.
Sure, I will try to find some answers to my BBB specific questions elsewhere. At least I have DSD playback now, and I will experiment with trimming the DPLL bandwidth back. Really appreciate your help Russ! Thanks!
Very glad to help, I am sure the BBB specific issues you are having can be sorted.
Enjoy the music!
Cheers!
Russ
Enjoy the music!
Cheers!
Russ
It is possible to connect amanero directly to Buffaelo III SE-Pro 9038?
Yes, works great.
Here's perhaps a rather general question related to power supply to the BIII SE Pro. The recommendation in the past was to use a Placid HD to supply the BIII boards, with the 9028 and 9038 the recommended board is the LCDPS HO. The LCDPS has a relatively primitive regulator setup compared to the Placid. Do the new Tridents on the BIII SE Pro boards negate any difference in the upstream regulator performance?
Yes. Though we use a higher performance (noise, PSRR, and load regulation) reg on the HO version than the normal LCDPS. In practice because of the local Trident regulation the LCDPS-HO is more than adequate - it works quite nicely.
I finished integrating the Pro38 and the Merqury and rewriting a new firmware for the DAC this weekend. The Buffalo 38Pro is a big upgrade in SQ over the Buffalo II with IVY it is replacing. The sound is warmer with more details and bigger soundstage.
My Frankenstein DAC:
The Dac consists of one Buffalo III dac with 6 channels and one Buffalo III 38pro with 2 channels. The USB card is a Exau2i 8 channel i2s card. The DAC can be controlled by remote, rotary knob or PC. The dac truns of and on 3 power amps and also turns on/off a projector. I also use a relay to use the dac and amp (2 channels) on different speakers in another room. I use eventghost on the PC to control the DAC. I made some hydrid cables for i2s on the new Pro38 to connect to the Exa U2i.
Just a question. Does the ES9038rpo support MQA decoding?
I have tried to play some MQA files (with passtrough MQA checked) from Tidal at 24bit/48kHz and they seems to work fine. I think the MQA files are backward compatible to normal PCM files. Therefore I do not know. The Mytek Manhatten II I think uses the ES9038/28pro and supports MQA decoding.
I have been listening to some tracks and I must admit I have difficulties hearing the difference between software decoding MQA and passthrough MQA.
- More Vendors...
- Twisted Pear
- Introducing the Buffalo III-SE-Pro 9028/9038
