Funniest snake oil theories
Also, there could be unwanted latency as the FIFO fills up to make sure enough data is buffered to prevent underflow. SRC is a way to use a fixed clock without problems a big FIFO might have.
What problems? EAC can usually run at 8 to 10X in ripping even a bad CD, filling up a FIFO so that there is no possibility of either under or overflow in several hours is trivial and the memory costs nothing. How much can clocks vary and have the recording still be worthwhile fussing over? At CD rates 1% off is not even 7M bytes an hour. I found the IEC consumer spec 1000ppm or 0.1%
EDIT - We crossed, at 1000ppm max it is trivial to buffer even 2hr at 192k/24 in a couple of seconds. You want to do movies and keep them in sync, I consider that outside serious music listening?
The Sony Discman ESP portable CDP's spun the disc at higher speed for a few seconds until the FIFO was at specified capacity and then settled back to 'normal' disc spin speed.
These players would also run multiple read retries on scratched/damaged discs.
IIRC the buffer memory chip capacity was surprisingly small.
Dan.
Edit: Sony-Discman-D-E440.html
IC 602 - MSM51V4400D-70TSK - 1,048,576-Word x 4-Bit DYNAMIC RAM : FAST PAGE MODE TYPE
I haven't bought anything Behringer in a while but still have a mixing console and a compressor. Back when I still cared about factory made equipment the common idea among musicians was "Behringer makes everything and everything they make sounds like p**p.".
Has that changed in some way? It's an honest question, not rethorical.
"Everything they make sounds like .... " sounds exagerrated to me.
While Behringer also has some "crap" products they also got some stuff whose price/performance ratio can`t be beat.
Regarding that interface I am pretty sure it can rival 2-300 EUR ones sound-wise.
Harry, we know that you laugh at us. We, in turn, laugh at your foolishness in not understanding what we are all about. We are serious, and you are just a reactionary. '-)
You are correct John, I do chuckle at the 'experts' who insist that what I have, or BQP cannot have effect.
Harry, you really have less than zero idea of what's cooking.
"Laugh on laugh on my friend, he laugheth best that laugheth to the end".
Dan.
Okay, but if my DAC did that i would look for a new DAC and not be satisfied with a cable swap, which would amount to a kludge bandaid treatment, IMHO. (Unless maybe the cable was clearly broken/defective. I would especially avoid expensive audiophile cables which should not be needed.)
EDIT: In some cases small gauge power conductors in USB cables, especially for longer cables, can result in enough voltage drop to affect reliable USB device operation. In such cases using cables with heavier gauge power conductors would not be unreasonable.
What DAC are you using? I have yet to see reasonable data from these devices.
Personally I have tried Maudio Transit, ASUS XONAR U7, and the latest RTX6001. Have an RME Babyface Pro that I have not tried yet. But as you can see, this covers quite a performance and price range.
Dan.
Here we go again !!
It's about time that the posts of these persons were put into a new thread -
Bybee Lovers Thread
David Gilmour at Royal Albert Hall on BluRay.
I guess you can't enjoy the best all the time. BTW hi speed buffering is not ripping.
a maximum disc rotation speed of 10,000 RPM, then 12x at the outer diameter should be possible (about 400Mbps). This is why the Blu-ray Disc Association (BDA) already has plans to raise the speed to 8x (288Mbps) or more in the future.
Understood. Previously you mentioned using EAC for CDs, which is a ripper app. So, maybe I could put it this way: they use encryption to prevent unauthorized copying of any kind. DVD and BluRay player apps as currently written only decrypt data in real time. To copy decrypted data for a DAC from a BluRay at high speed to a large buffer is not legally allowed for at this time since authorized player apps don't do that. It would be essentially unauthorized copying, or loosely speaking, ripping. Unless of course, you wrote a new player app to go with your big FIFO DAC and paid all the licensing fees to make it legal.
Regarding not enjoying the best all the time, you are right. The BluRay I mentioned is a good performance with great players, but unfortunately the digital audio recording of the performance sounds way too digital.
Also, one can look at the error rates that JensH and Victor got with the 9038q2m and 9018k2m, respectively, out of cheapo boards with opamp I/V's. E.g. Jens's I/V is sitting around -103 dB THD (3HD dominant) at 3.65 V output (SPDIF input). As his plots show, there's a moderate amount of hash up top, but that's *still* sitting a good -115 to -120 dB from the primary.
Source: ES9038Q2M Board
Victor's data, from what I remember, shows something similar using I2S input.
If there are major problems with these *cell-phone* chips SRC's or the rest of their pipeline, these two gentlemen aren't showing it. Could it be better? Sure, of course, but the conversation is starting with errors that are -100 dB or smaller.
