Sure...you tell me the four edit points (give or take) and I will do exactly that.
Dan.
ok so the beginning of each track to the first good cymbal strike is
33:39-33:50 and
34:37-34:38
Give or take that youtube doesn't have great timecoding features.
I watched the video. The good cable correlated with the hi-fi getting about 3db louder and something started distorting too, either the hi-fi or the mic picking up the sound.
That's my take on it, my opinion only of course.
Simply takes moving closer. No need to be an opinion should be easy to measure right off the video and end this.
So how is it that the 'q' word not relevant ?.
All behaviours of all materials and systems are rooted in quantum physics, so what's the problem ?.
I expect RF would very much follow the outline I gave above.
Richard Feynman. Why.
Dan.
Dan.
Ok I'm on to it, back soon.ok so the beginning of each track to the first good cymbal strike is
33:39-33:50 and
34:37-34:38
Dan.
Is this the only hobby where one seeks things in a 1000$ cable, which a 1000$ amplifier can not provide ? That would be beyond logic. Isn't it ?
Regards.
Regards.
Speaker wires are like capacitors, most people say they make a difference but cannot prove anything. Good cables are not that expensive to make or purchase so to remove this from the equation it is better to use good cables.
If you have to ask the question then you cannot understand the answer.Max Headroom said:So how is it that the 'q' word not relevant ?.
Good cables are inexpensive to buy but very difficult to make (unless by "make" you just mean putting bought connectors on the ends of bought cable). Almost all DIY cables are seriously inferior to sensible bought cables. Bad cables can be very expensive to buy.gabdx said:Good cables are not that expensive to make or purchase so to remove this from the equation it is better to use good cables.
I think consumers are not going to try to prove anything. I have made some tests on short lengths many years ago and stick to using specific internal wiring until I find it necessary to change. But it makes no sense to try an win an argument.
Capacitors have measurable nonlinearities which are significant for some applications. In some cases the effects are easily audible, such as tantalum capacitors used in a tone control filter for a guitar distortion pedal.
There are significant differences, the initial 1.5 seconds room sound is one difference.
Dan.
Easily visible by eye, there possibly is a difference in spectral balance that is perceived as louder. There looks like some clipping too, not a good sign for critical listening.
Try to be a teacher, we are all ears.If you have to ask the question then you cannot understand the answer.
So what defines a 'good' cable versus a 'bad' cable, physical durability etc considerations excepted for the purpose of this discussion.Good cables are inexpensive to buy but very difficult to make (unless by "make" you just mean putting bought connectors on the ends of bought cable). Almost all DIY cables are seriously inferior to sensible bought cables. Bad cables can be very expensive to buy.
Dan.
Dan, both look clipped which would cause some distortion. Also, since the room sound went up in one case, it may be that whoever was doing the sound recording turned up the gain when the "good" cable was switched in. Maybe that was done so the folks watching online could hear a "difference" given the low fidelity of most streaming audio.
The clipping is likely the audio AGC pushing too close to the wire.Easily visible by eye, there possibly is a difference in spectral balance that is perceived as louder. There looks like some clipping too, not a good sign for critical listening.
Agreed, constant gain would be better but the differences are audible as is.
Dan.
Find a good undergraduate textbook on quantum mechanics. Read it. I cannot recommend one as my books are from 40 years ago. If necessary, learn the prerequisite mathematics first: linear vector spaces, concept of orthogonality, complex numbers, second-order differential equations etc. Also, it helps if you have a good grasp of classical mechanics, especially in the Lagrangian and/or Hamiltonian form.Max Headroom said:Try to be a teacher, we are all ears.
Adequately low series resistance, and can carry required current without overheating. Adequately high shunt resistance, and can carry required voltage safely. Moderate (not too high, not too low) inductance and capacitance. If unbalanced, then well shielded accurate coaxial construction. If balanced, then adequately tight twist of pair.So what defines a 'good' cable versus a 'bad' cable, physical durability etc considerations excepted for the purpose of this discussion.
KK , not want to name the manufacturer, makes possibly the best speaker cables. Can be bought by the spool too. Not too hard to make a replica.
Possibly the type of copper makes a difference: slow/fast drawn, cold drawn, hot drawn etc. at the molecular level.
- Member Areas
- The Lounge
- Funniest snake oil theories
