Are these valid Gerber files for a Pass BOSOZ Power supply?
I found some files using Wayback Machine that are supposed to be the Gerbers for the BOSOZ (Pass Balanced Line Stage), but I can't open them using any of the viewers I've found online.
The files in the sozpre.zip for the power supply (as an example) are:
PL45BR0.bot
PL45BR0.ncd
PL45BR0.rep
PL45BR0.smk
Total size of those 4 files is 7k.
Are these Gerber files?
How can I view/print what I need to diy a board from them?
I have the .jpg from the Pass article but it's quite lo-rez, so I'd like to find something a bit clearer if possible.
Help! 🙂
VictoriaGuy,
I used it to print the attached pdf.
Hope that helps.
Dennis
Thanks, Dennis.
The lines in your .pdf look sharper than the ones in the graphics from the Pass article.
I guess there is a separate file required to specify the holes in the pcb?
The power supply image I posted (from the Pass article) doesn't have the holes, but the amplifier pcb image from the same article did.
Scaling the image properly to fit the actual components is a bit tricky- it looks like your .pdf file has that right.
Please see attached.
When he wrote the article, Nelson Pass intended the Gerber files to be available to the diy community.
It's a pity that usable Gerbers or good image files don't seem to be actually available.
It looks like I will be able to use what I have now to make a couple of boards.
Thanks.
