DIY Audio Analyzer with AK5397/AK5394A and AK4490
I have just made a test on an RTX6001 (from the prototype series) using ARTA. In ARTA the level was set to -11.5 dBFS to get a read-out level of -12 dBFS. See the attached. Settings like the ones shown in post #1251.
They are useful in various contexts, codec testing is one area where an IMD test is useful. (multitone FFT is my preference)
I have had this test capability for more than a decade, nonetheless I hardly ever use it and am not that good at interpreting the results.
Really good solid state designs may not be appreciably worse than the test equipment used to measure it, this will not be the case I think with tube gear, particularly those using chokes and transformers.
High frequencies and high slew rates may move further into nonlinearities, also feedback decreases with frequency so any correction will be reduced. However in a bandlimited system like digital audio there are very specific limits on valid inputs. Clipping and hf above those limits may tease out bad things but really aren't relevant.
The ADC does of course have built-in filters.
I'm looking at the specs for this, and it says differential input and good for 100vrms. I was running about 40v to it from a btl amp and seeing huge amounts of harmonic distortion that's not actually there. I hook up a differential probe and the distortion is gone, but my noise floor is now hugely amplified due to the limitations of the probe. I tested this with two different amps and I'm getting the same results. I was hoping to avoid using differential probes for this reason.
Further testing shows that as soon as I pass about 6V on the inputs, the distortion becomes present. It stays at the same levels regardless of whatever attenuation I set.
Here it is direct into the RTX6001
And here it is with a differential probe
This is direct in at 5.5V
then 6.2V
And the signal on a scope
Then at varying levels of attenuation
Behavior seems to imply that the distortion is generated somewhere prior to the input attenuators since they have no effect on the distortion. Can you elaborate on cables and anything else connected in parallel with the inputs?
What are you doing on the output side of the RTX? Are you running near the limits of the generator on the range selected?
Yes, dummy load attached. I'd assume the attenuators should also be reducing the distortion, but it just doesn't change.
I'm not seeing this with a loopback either, but max output is 5v per pin.
Also, nowhere near the limits of the generator
