AKSA's Lender Preamp with 40Vpp Ouput GB
Founder of XSA-Labs
Joined 2012
Edit Jan 27, 2020: I am getting good questions from some members who are just building this preamp now. Here are some links to the BOM for the MB and the tricky to get right rotary switch and Micromatch connectors and 8-pin cable:
The MB BOM is here:
http://www.diyaudio.com/forums/atta...vpp-ouput-gb-aksa-lender-mb_pl_04_01_2018-zip
The cable is the 8 pin Male-Male:2205062-2 TE Connectivity / AMP | Mouser
The jack on the PCBs for the cable are female 8 position (one on each end):2178710-8 TE Connectivity | Mouser
The rotary switch is not stocked at Mouser. I ended up getting it on eBay - seearch for Lorlin CK1051
To order Preamp Boards please order from my Etsy Shop here:
Aksa Lender SE Class A Preamp
From old thread..
It does seem that there is interest in a GB. The nice thing with this design is choice of SMD or through hole on amp core daughterboard. I have not priced those yet but they are small so probably $5 for 10. Is anyone interested in the metal core version? That would allow increased bias to use as headphone amp.
--------------- NEW GB THREAD STARTS HERE ------------------
Link to basics of this preamp starts in post 25:
AKSA's Lender Preamp with 40Vpp Ouput GB - Page 3 - diyAudio
I was asked to move the GB aspects of this preamp here. Thanks to Hugh Dean (AKSA), Keantoken, and JPS64 for making this possible.
The original thread describing this preamp is here:
AKSA's Lender Preamp with 40Vpp Output
Basic schematic of through hole prototype version:
644601d1510165924-aksas-lender-preamp-40vpp-output-lender-preamp-aksa-schematic-v5-png
Implementation in SMT/TH prototype:
646265d1510907783-aksas-lender-preamp-40vpp-output-smt-carbon-fb-jpg
Demonstration of 40vpp output into 25kohm:
644607d1510165924-aksas-lender-preamp-40vpp-output-40vpp-oscope-screenshot-jpg
Measured performance 20vpp into 7kohm (with 21.6dB gain):
646386d1510957760-aksas-lender-preamp-40vpp-output-smt-preamp-20vpp-7kohm-10r-degen-yes-matched-12kcarbon-fb-png
4vpp into 7kohm gives 0.0011% THD:
646388d1510958510-aksas-lender-preamp-40vpp-output-smt-preamp-4vpp-7kohm-10r-degen-yes-matched-12kcarbon-fb-png
Layout design by JPS64 for Main PCB with CLC filter, & cap Mx PSU portion, Input selector, daughterboard sockets for amp cores, and peripheral output caps etc.
647184d1511340359-aksas-lender-preamp-40vpp-output-diy-aksa-lender-main_pba-top-jpg
TH Daughterboard:
647196d1511344542-aksas-lender-preamp-40vpp-output-diy-aksa-lender-pre-tht_pba-top-png
647066d1511284591-aksas-lender-preamp-40vpp-output-aksa-lender-pre-tht_pba-top-png
SMT Daughterboard:
647201d1511346114-aksas-lender-preamp-40vpp-output-diy-aksa-lender-pre-smd_pba-top-jpg
Metal-core (IMS) Daughterboard PCB:
647189d1511342696-aksas-lender-preamp-40vpp-output-diy-aksa-lender-pre-ims_pba-png
Alert - error on main PCB. R141 Should be 10k not 220R.
Alert - error on main PCB diode V141 should be standard 1N400X not breakdown or zener.
Alrert - error on MELF SMT BOM, R102 and R103 are swapped. R102 should be 33k and R102 should be 10k on the MELF SMT v001 PCB.
Revised BOM for MB (8-pin connector was incorrect), file here:
Mainboard schematic looks like this (note R141 is 10k not 220R):
649511d1512424995-aksas-lender-preamp-40vpp-ouput-gb-jps64-aksa-lender-preamp-main-schematic-png
Schematic for Mainboard here:
http://www.diyaudio.com/forums/atta...-preamp-40vpp-output-diy-aksa-lender-main-zip
Schematic for Through-Hole Daughterboard:
649512d1512425408-aksas-lender-preamp-40vpp-ouput-gb-jps64-aksa-lender-preamp-th-daughterboard-schematic-png
Stuffing Guide for TH amp daughterboard:
657357d1516206987-aksas-lender-preamp-40vpp-ouput-gb-th-placement-stuffing-guide-jpg
Schematic for SMT Daughterboard (updated V2 correct for silkscreen error from V1 - R102/103 were swapped, corrected now):
650412d1512862009-aksas-lender-preamp-40vpp-ouput-gb-aksa-lender-pre-smt-schematic-v2-png
SMT & IMS Daughterboard Parts List/BOM:
http://www.diyaudio.com/forums/atta...-output-diy-aksa-lender-pre-ims_or_smd_pl-zip
TH Daughterboard Parts List/BOM:
http://www.diyaudio.com/forums/atta...r-preamp-40vpp-output-aksa-lender-pre-tht-zip
Please place orders in Etsy shop.
Edit Dec 8, 2017 - GB1 MB and TH board test:
650200d1512777832-aksas-lender-preamp-40vpp-ouput-gb-gb-th-demo-test-jpg
650198d1512777779-aksas-lender-preamp-40vpp-ouput-gb-aksa-lender-pre-gb-mb-th-8vpp-7kohm-fft-png
Both SMT and TH daughterboards verified to work:
650482d1512912624-aksas-lender-preamp-40vpp-ouput-gb-gb-smt-build-completed-jpg
Playing in stereo with TH and SMT:
650489d1512914952-aksas-lender-preamp-40vpp-ouput-gb-aksa-lender-pre-gb-smt-th-stereo-jpg
FFT of SMT for 20Vpp into 7kohms is THD of 0.001%:
650483d1512912624-aksas-lender-preamp-40vpp-ouput-gb-aksa-lender-pre-gb-mb-smt-20vpp-7kohm-fft-zoom-no2-png
Edit (Dec 2, 2018) - Latest measurements with MELF board...
4Vpp into 7kohms (45v Vcc):
654181d1514879318-aksas-lender-preamp-40vpp-ouput-gb-aksa-lender-pre-melf-4vpp-7kohm-fft-png
20Vpp into 7kohms (45v Vcc):
654180d1514879318-aksas-lender-preamp-40vpp-ouput-gb-aksa-lender-pre-melf-20vpp-7kohm-fft-rt-png
40Vpp into 7kohms (50v Vcc):
654182d1514880003-aksas-lender-preamp-40vpp-ouput-gb-aksa-lender-pre-melf-40vpp-7kohm-fft-50vcc-png
51.4Vpp into 7kohms (59v Vcc):
654183d1514880354-aksas-lender-preamp-40vpp-ouput-gb-aksa-lender-pre-melf-51-4vpp-7kohm-fft-59vcc-png
Maybe thread title should be renamed to 51v? :)
Edit Jan 16, 2018: Aksa Lender as very nice HPA:
657047d1516059914-aksas-lender-preamp-40vpp-ouput-gb-aksa-lender-hpa-amp-cores-2-jpg
2.0Vpp into 50ohms with HPA (title is a typo):
657054d1516060213-aksas-lender-preamp-40vpp-ouput-gb-aksa-lender-hpa-130ma-1-0vpp-50hms-png
657048d1516059914-aksas-lender-preamp-40vpp-ouput-gb-aksa-lender-hpa-amp-main-jpg
Edit April 16: Recent review by DrPro. http://www.diyaudio.com/forums/anal...ender-preamp-40vpp-output-58.html#post5407342
Edit April 9, 2024: I have received word that many of the links to the BOM and stuffing diagrams etc may not be working anymore diue to the change in DIYA backend software a year or so ago. I am putting stuff below here as I get requests:
Stuffing Diagram and Schematic for the 0805/1206 SMT PCB:
BOM for 0805/1206 SMD board:
QtyValueDevicePackagePartsDescriptionMFGMFG_PN
1​
100RERA6AEB3092VERA6AR830k9, 100V, 125mW, 0.1%, 25ppm, 0805PANASONICERA6AEB3092V
1​
100µCPOL-EUGPANASONIC_GC1POLARIZED CAPACITOR, European symbol
1​
10R0R-EU_R1206R1206R14RESISTOR, European symbol
2​
10k0ERA6AEB3092VERA6AR2, R10030k9, 100V, 125mW, 0.1%, 25ppm, 0805PANASONICERA6AEB3092V
1​
10k0R0207-SMDR0207-SMDR10
1​
1k0ERA6AEB3092VERA6AR1130k9, 100V, 125mW, 0.1%, 25ppm, 0805PANASONICERA6AEB3092V
1​
1k8ERA6AEB3092VERA6AR4A30k9, 100V, 125mW, 0.1%, 25ppm, 0805PANASONICERA6AEB3092V
1​
220RERA6AEB3092VERA6AR730k9, 100V, 125mW, 0.1%, 25ppm, 0805PANASONICERA6AEB3092V
1​
270RERA6AEB3092VERA6AR1630k9, 100V, 125mW, 0.1%, 25ppm, 0805PANASONICERA6AEB3092V
2​
33R0ERA6AEB3092VERA6AR5, R630k9, 100V, 125mW, 0.1%, 25ppm, 0805PANASONICERA6AEB3092V
1​
33k0ERA6AEB3092VERA6AR130k9, 100V, 125mW, 0.1%, 25ppm, 0805PANASONICERA6AEB3092V
1​
33pGRM21BR71C225KA12LC0805C52µ2, 16V, X7R, 0805MURATAGRM21BR71C225KA12L
1​
470RERA6AEB3092VERA6AR1230k9, 100V, 125mW, 0.1%, 25ppm, 0805PANASONICERA6AEB3092V
1​
47R0R-EU_R1206R1206R15RESISTOR, European symbol
2​
47µ0CPOL-EUFPANASONIC_FC2, C3POLARIZED CAPACITOR, European symbol
1​
68k0ERA6AEB3092VERA6AR930k9, 100V, 125mW, 0.1%, 25ppm, 0805PANASONICERA6AEB3092V
1​
6k8ERA6AEB3092VERA6AR4B30k9, 100V, 125mW, 0.1%, 25ppm, 0805PANASONICERA6AEB3092V
1​
9k1ERA6AEB3092VERA6AR330k9, 100V, 125mW, 0.1%, 25ppm, 0805PANASONICERA6AEB3092V
2​
BC860CBC860CSOT23_BECQ1, Q2
1​
BSP129BSP129SOT223Q5
1​
DZT5401BCP53SOT223Q4
1​
FJV1845FJV1845SOT23_BECQ3
1​
TS4148TS4148-0805-RYV0805D1
3​
TSM-103-01-L-SHTSM-103-01-L-SHTSM-103-01-L-SHX1, X2, X3
See Zip file below for SMD 0805/1206 BOM in .XLSX format
  • Aksa-Lender-SMD-0805-1206-BOM.zip
So far we have the following interested members, please quote message and edit with your name and qnty and type if interested.
JPS64 - 2 sets w/ SMT daughterboards
Algar Emi - 1 set, SMT or TH?
Redarc12 - 1 set, SMT or TH?
CFT - 1 set, SMT or TH?
Jacques Antoine - 1 set TH
Silasmellor - 1 set THT
Bvtrinh- 1 set TH
ggetzoff - 1 set TH
tubesguy - 1 set TH
Aatto - 1 set SMT
Mordikai - 1 set TH
Johnny2Bad 1 set TH; 1 set SMT
Joined 2011
Bvtrinh- 1 set TH
ggetzoff - 1 set TH
tubesguy - 1 set TH
Aatto - 1 set SMT
Mordikai - 1 set TH
vvs07 - 2 sets TH
Thank you!
Bvtrinh- 1 set TH
ggetzoff - 1 set TH
tubesguy - 1 set TH
Aatto - 1 set SMT
Mordikai - 1 set TH
vvs07 - 2 sets TH
Fabian85 - 1 set SMT
Founder of XSA-Labs
Joined 2012
GB status update...
JPS64 -2 sets w/ SMT daughterboards, Paid
*Algar Emi - 1 set, TH, Invoice sent
Redarc12 - 1 set, TH, Paid
CFT - 1 set, TH, Paid
Jacques Antoine - 1 set TH, Paid
Silasmellor - 1 set THT, Paid
Bvtrinh- 1 set TH, Paid
*bvtrinh - 1 set TH (second set), Invoice sent
*ggetzoff - 1 set TH, Invoice sent
tubesguy - 1 set TH, Paid
Aatto - 1 set SMT, Paid
*Mordikai - 1 set TH, Need PayPal address
*Johnny2Bad 1 set TH; 1 set SMT, Invoice sent
vvs07 - 2 sets TH, Paid
*Fabian85 - 1 set SMT, Need PayPal address
PCGAB - 1 Set(MB) with SMT boards, Paid
Harry3 - 1 set MB plus TH, Paid
Wayne1 - 1 set TH, Paid
obh - 1 Set(MB) plus TH, Paid
PJN - 1 set TH, Paid
manniraj - 1 set TH, Paid
Erik777 - 1 set TH, Paid
Zman01 - 1 set SMT, Paid
AKSA - 1 set SMT, Paid
xrk971 - 1 set SMT, Paid
spind - 1 set TH, Paid
Founder of XSA-Labs
Joined 2012
Group Buy Update
bvtrinh - 1 set TH (second set), Paid
ggetzoff - 1 set TH, Paid
Johnny2Bad 1 set TH; 1 set SMT, Paid
So I still have not heard from Algar_emi, Fabian85, or Mordikai yet. Thank you to all the other folks who have sent payment.
Group Buy Update
schlomoff-1set mb,1set th
Founder of XSA-Labs
Joined 2012
GB status update.
*Mordikai - 1 set TH, Invoice sent
schlomoff- 1 set TH, Paid
—— Waiting List - please add name below ——
Fabian85 and Algar_Emi, please respond by 23:00UTC. I have several people interested in boards via PM. Thanks,
X
