That's a lot of work, most folk can't have such fancy rooms. But not to worry. In the future, we'll have our iphones implanted directly into the skill, providing audio and picking up audio. Then we'll be able to listen to music directly beamed to our heads. Speakers will be gone and no more compromises.
I'd miss the visceral feeling of bass.
We did a lot of work on the relationship between what we hear and what we feel at LFs while I was at Ford in Noise control. Turns out that starting at about 100 Hz., the lower you go the more important the tactile feel becomes until about 20 Hz you only feel the sound, almost nothing is airborne. Without a tactile feel the perception of bass is never right.
I didn't do a lot of work on that relationship (although obviously glad it was done), I just know that if I don't feel it it don't sound right. 🙂
in pro sound reinforcement monitor situations involving "in ear monitors" the use of "throne thumpers" or "bass shakers"(are essential to drummers) and are being used more and more in home theater installations to enhance low frequency content perception.
Your not thinking of those being an "array" are you? Because they more closely simulate a point source.
People quibble over the definition of an array but as one gets closer a stacked multi driver speaker no longer behaves as a point source.
The theoretical point source does suffer from floor and ceiling bounce, 3 ways and array type speakers can be much smoother.
Your definitions and mine differ. To me there are three types of sources, 3 dimensional, 2 dimensional such as a line array from floor to ceiling and 1 dimensional such as an entire wall of sources. They all act differently.
But a 3D source does not mean it's always omni-directional, it means that all waves appear to have emanated from a single point. Hence one can have a point source with directivity, such as a waveguide. A true point source, one of infinitesimal size, would be omni-directional, but also impossible to create.
In the near field no source look or act like any other source, so we tend to always talk about the far field where very solid rules apply.
"3 ways and array type speakers can be much smoother" - this is not really correct and maybe even the opposite is true.
There is no hard and fast rule for the nearfield of an arbitrary source, it depends on the details. But what you are saying isn't correct in any case. The nearfield of a source like a round piston goes out to about k*a^2 (k is the wavenumber and a the source radius) which shows that the nearfield is shorter for LFs and not farther as you indicate.
(See Pierce Acoustics section 5-8 "Transition to the Far Field")
I'm sorry for the inaccurate generalization and thanks for the reference.
Colloquially when people say near field, what do they mean?
Sound Fields: Free versus Diffuse Field, Near versus Far Field
That is a decent representation. In the near field many things can go one that do not propagate to the far field. Hence the near field is a mess without any real indication about what is going to propagate and what is not.
I thanks the author for the clarity of his drawing and you, for your precisions.
When we hear headphones, we are in the near field ?
Yes, interesting, from a measurement point of view, how about perception though? Also it seems sometimes the term near field is used when the level of the direct radiation swamps the reflections. I've been experimenting with my dipoles and find that too close, less than about 5 feet the stereo image collapses
I agree that floor reflections must be handled, they are disruptive, but they do not interfere with imaging in the same way that lateral ones do -
perhaps not in the same way but according to the quoted research they interfere with reproduction in the worst way imposing on it the fundamentally artificial quality
I believe it's because they - along with diffraction - give away the speakers as the artifical sound sources
a rug nor a floating floor cannot help in this regard and a coffee table creates its own similar problems
ScottJoplin
Here is a problem with your question. The near field concept only applies to free field radiation. Headphones are not free field so no such concept exists. If one were to actually measure or calculate the sound field in front of a headphone is would likely be quite complex for shorter wavelengths. For an insert headphone, the chamber is so small that for most of the hearing range the pressure is completely uniform in front of the device. It wouldn't be until 6-8 kHz before we would begin to see some non-uniform dispersion of sound.
I've found standing improves my speakers imagery, I've suspected this is due to floor reflection though I'm listening off axis now which has improved it a little
@gedlee, sorry I wasn't replying to the headphone question, but the link about near/far field etc
The best definition imo for near field vs far field is that near field decreases by 3 db for each doubling of distance. Far field decreases by 6 db. Thus its the difference between a point and a line.
This is a good article on it. Line Array Limitations
There isn't a neat transition point, longer wavelengths transition closer.
It depends on frequency of interest, wouldn’t it?
- Who makes the lowest distortion speaker drivers
