I mean did he tell you he had processed it in someway?
Yes. So, I listened, and I wrote back with my impression. That was it, no further communication after that.
Anyway, getting back the purpose of my original post, I wanted to suggest I imagine it might be possible for some kind of signal manipulation to be perceived in the way Max has been describing.
For those who may be thinking he is totally imagining things or dishonest, I don't think it's probably either one of those. Rather, I suspect he is changing the sound of things, either by modifying signals, or modifying the acoustic properties of headphones, whatever it happens to be in each case. For at least some of the claims, that is. Maybe there is some biased listening going on in cases that can't be accounted for by some kind of physical causation.
Beyond that, I know Dan seems hopeful that there will be some commercial value to what he is working on. If it is something that can be done by an existing VST effect plugin, and that is already in use as a musical effect, then it seems unlikely there could be any new invention involved. If there is something beyond that, then I am not aware of what it might be.
In any case, I don't think Dan is a bad guy, and I wish him the best in his endeavors. I'm just not hopeful there is a way to make money out of whatever he's up to.
@ Max Headroom (Dan)
Can you remember in what way you modified the contents of the file you sent Markw4 he is referring to above?
I agree, I have sent him what I can to help in whatever he is doing. I figure if he learns something it can only be good.
Hi Mark.
Could you tell me the file names.
I'm pretty sure I sent you a pair of files.
Dan.
Dan, Sorry, don't recall that. The only think that stuck with me was my general impression of the modified sound. I purposely didn't keep any copies or other information since I thought it was up to you if you wanted anyone else to hear what you were working on.
In that case, I probably said that they both sounded too bit-depth reduced and grainy to tell any difference. More I think about it that seems right, but I don't have a copy of the PMs so who knows.
What about you, Dan? Did you keep a copy of our correspondence?
I think you are right that you reported no difference that you could tell.
I cleaned out my DIY Mailbox recently and deleted corrspondences...yours too it seems.
Dan.
Dan.
The reason I said I didn't recall if there was a processed and unprocessed file, is that I was only left with one overriding impression, that what I heard was grainy and poor fidelity, as though it were bit-depth reduced without dither.
It could be I was left with that impression because both files sounded that way, assuming there were two. I think I wrote back something to you about it being very difficult to detect differences in such files, and that it would be better if you started with Hi-Res files, which make it easier to hear small differences.
Anyway then, if one wanted to make a process to reduce noise and improve sound quality at the same time, maybe it's possible. If the source file has a lot of HF noise and maybe HF distortion, it might sound better to filter some of that out and replace it with synthesized HF harmonics. Actually, there are VST plugins to create HF harmonics. Nothing new there. And people have tried to rescue bad recordings with EQ and harmonic synthesis. Of course, it only makes an improvement if original sound quality is poor.
But making a VST plug-in happen by the laying on of ferrite "hands" is a good trick.
For the record, we have looked into toroid power transformers for the last 40 years or more. They at first seemed to be the 'answer' for hum minimization, and relative efficiency. We first overlooked their 'downside' of enhanced coupling of high frequencies through them due to the nature of their construction (in and out windings virtually on top of each other) and like so many people here, presumed that the AC power source was relatively clean, except for a few harmonics of the fundamental frequency. However, this is not the case. There is a great deal of AC mains garbage up to many MHz generated by local sources, such as electric stoves, motors, etc. This should NOT be passed through the transformer if it is at all possible to minimize it. The best way, that we have found is to use either specially designed E-I transformers (more like isolation transformers than just power transformers) and put them in a separate enclosure, away from the audio circuits, or try for Rcore transformers, that appear to have the best compromise between E-I and toroid configurations.
Now how can you get an 'intuitive' understanding for the difference between E-I or Rcore, and toroid power transformers? Simple: Just measure the capacitance between an input and an output winding of comparable power transformers to note the degree of capacitive coupling between the input and the output windings of the transformers. Go for it, you might be surprised. Of course you could do other measurements, like frequency response, but that takes more effort and does not show the internal cause of the problem.
I have actually tried O core and R core from the same manufacturer of the same ratings, in a class D power amplifier. For some reason the R cores resulted in significantly compressed sound.
Yes, thank you again for those Scott, they are and will be put to good use.I agree, I have sent him what I can to help in whatever he is doing. I figure if he learns something it can only be good.
I'm always learning from this forum and certainly from your inputs, and other online sources and experimentation of course.
What I'm up to is understanding whats going on with this field effect I and JB are dealing with.
I find it intensely interesting that the fine properties of pretty much all kinds of systems can be altered by 'filtering' at the system energy inputs and energy outputs.
In the case of audio and video systems and according to filter composition, this fine alteration can be subjectively beneficial or subjectively deleterious...take you pick.
Dan.
I'm starting to wonder if some here understand what a filter does.
Note: The word filter is a huge hint as to what it does.
]Toroidal transformers contain the field almost entirely, E-cores can induce hum into nearby wire loops. Maybe it's just the wholesome reminds-us-of-our-parent's-table-radios sound of hum?
No hum was involved when I was doing testing between two identical transformers, One was Toridal with 1 amps output, the other was E-Core with 1 amp output.
Both were feeding a common 7805 then a custom TDA1543 which I built myself. And there were significant audible differences between the two transformer types. Vocals were FAR more intelligible with the E-core in place.
A little 3rd harmonic distortion can make vocals sound more intelligible than they really are. How do you know there wasn't more distortion?
Expanding or contracting 3'rd harmonic distortion, Markw4?
And how would a power transformer generate this sort of distortion into an audio circuit?
- Member Areas
- The Lounge
- Funniest snake oil theories
