AC Voltage Stabilizer
Hi Guys
Need a little advice. Where Im at AC voltage id suppose to be 230v
Problem the highest that I've measure is 228.6 most of the time it
averages around 226 or so. Believe or not when voltage goes down
to around 220-221 like now, music sounds slow & fat. It's only a
difference of 5-8 volts & yet SQ is so much different.
Question what can I do to bring up the Voltage ? With a variac will
SQ be affected ? Im using a 100 watt AB amp, ML speakers with
a dac & an SD card player. With this set up, if a variac works,
what va ratings should I be looking for ?
Thks Guys
Hi DF96
No hallucination on my part, very very obvious.
Think its to do with the Hypex Smps 400 that Im
using. When AC is low measured DC output at
smps is only around 43v +- . My amps needs
average of 47v +- to really wake up. Best
performance is achieved at 50v +-
Thks
A UPS is the way to go. The battery problem is when there are power outages, this is what wears them, and they are pricy.
Get an UPS that runs on 12volt, then any car battery will do. Only small ups run on 12v. Large ones are likely on 24v, some more.
The 12v battery car on a small UPS, I have used, no problem, you even have a fresh charged battery ready to jump start your car.
