It is certainly possible that the standards body got it wrong too. The individual responsible who thought that RMS might be a good name for something which has nothing to do with RMS could also not realise the difference between power and average power.Charles Darwin said:As I mentioned twice already the amp is driven with pink noise according to the EN/DIN standards and RMS is the maximum output it can sustain for 10 minutes in Watts into a stated load, usually 8Ω for domestic and 4Ω for pro amps.
I do. Of course.Pano said:I don't believe some people think that. At least not people who know what AC is.
You seem to finally have got it but was it really necessary to try to shoot the messenger twice using sinuous strawmen?🙂
That said I very much doubt that it was an individual who was responsible.
One can pretty much guarantee that it was a committee drawn from representatives of all 15 EU nations at the time.
RMS should never be applied to power, but some standards body (DIN?) invented this peculiar measure some time ago (1960s?).
They also defined it for their purposes in DIN45500/DIN EN61305 and agree that it has next to nothing to do with the actual meaning of RMS but in a world of PMPO, Music Power, Total System Power etc RMS was known to the public and closest in value to what they came up with so they just used that term.
In the world of the Deutsche Industrie Norm RMS power is defined as the maximum an amp can deliver for 10 minutes using pink noise as input signal.
Nope. As yet said in posting #14, the German term the Deutsche Institut für Normung (which the abbreviation DIN correctly stands for) used in DIN 45500 was Sinusleistung, not RMS power. Sinusleistung was defined as the maximum power at a maximum THD level of 1% that an amplifier was able to deliver continuously over ten minutes when driven by a sine Signal, without getting too hot or being destroyed.
Best regards!
I took the definition from DIN EN61305 which the site claimed evolved from DIN45 500.
Either way there has been an EU wide and presumably legally binding definition of RMS power since 1996. What I thought was missing was a crest factor for the pink noise used.
In the end I just searched wrms and found the seemingly appropriate norm.
I did not look up 45 500 specifically, mostly because it has been out of date for 20 years and was only applicable to Germany.
I'm not sure what it is I am supposed to have "got". I asked whether your statement used 'maximum' in its normal sense or really meant 'maximum average'; whether you were quoting someone else or speaking on your own behalf was unclear but in either case you could have said what you meant or understood them to mean, as appropriate, or said that you were merely the messenger. I am not aware that I shot anyone.Charles Darwin said:You seem to finally have got it but was it really necessary to try to shoot the messenger twice using sinuous strawmen?
Several years ago I had a double cassette player/recorder (Sanyo) that performed few years until I started my DIY project actually using. It said "120W PMPO". Wow! Strangely, once I disassemble to clean the pots (Noisier) and the speakers was only 4W RMS. Very ridiculous, no? The power trafo was 5*5*5cms. "Such a power density, I thought".
According to Morgan P. Jones, P.M.P.O. stands for Purely Mythical Power Output. 😛
Best regards!
Best regards!
There is no reason to design a AUDIO (As opposed to shaker table) amp to clip at the continuous power rating, that is just throwing away headroom, especially in something like a class D design where SOA and voltage drop across the pass devices is not a concern, in an AB design voltage headroom costs you power dissipation so it is a harder tradeoff there.
The reason is, high end sound.
"A camel is a horse designed by a committee"
Crest factor in recordings was ever changing, due to loudness war.
Yes it was decreasing, partly because spread of pop and techno music, where nearly constant high acoustical level is an attribute of music. But there is another reason: our environment got noisier, so music has to stand out of the background. Think about traffic noise, aircrafts, AC, computer fans, crowd chatting in the disco, listening music by earbuds on the metro, etc.Crest factor in recordings was ever changing, due to loudness war.
Not sure I see it.The reason is, high end sound.
I mean if I have a certain BOM cost target I can build a 5W amp that clips at 5W into 4 ohms, or a 2.5W amp that clips at 25W into 4 ohms, for music, one of these is going to be a lot better then the other and it is not going to be the 5W one...
Of course the single number marketing guff never catches this sort of thing well.
Reducing the heatsinks and spending the money instead on higher supply rails and more peak current is for an AUDIO AMP pretty much always a win over designing for clipping at 100% DF sine.
This changes of course if you are trying to drive shaker tables, but that hardly counts.
Engineering is a trade off (always), make the ones that optimise for the problem you actually have.
Regards, Dan.
There is a difference between engineering of High End, and mass production HiFi. Criteria of optimization are different.
So, what's the definition of "high end"?
When sphincters are ready to unleash, and you have goose bumps hearing musicians and singers here and now, but not seeing them.
Of course the end result is subjective, but from objective point of view, most audible distortions have to be minimised first, instead of going for some "standard measurements" of distortions that do not matter. It is not hard today to get low THD level; what is hard, to understand how dynamic distortions affect the sound, and concentrate on how the amp and speakers misbehave, instead of paying attention to so called "linear region" that was never a problem for well designed equipment.
In the context of recent posts, it might be defined as good audio reproduction of sounds/music with high crest factor.So, what's the definition of "high end"?
Then there's the (quoting another poster) "mass production HiFi" or what some might call mid-fi, playing modern pop music with hypercompression that has lowered the crest factor asymptotically towards 1.
OK, we have a bunch of audio wise guys here under one virtual roof.
What would YOU call it? How would you describe the power output of an amp that can supply a certain voltage into a defined load with a distortion limit? If not RMS power, come up with a good term for what the amp can do.
Night lamp, heater, beer stand. What else?
Well, a conversation item.
- Member Areas
- The Lounge
- When did Wattage become other than RMS?
