100W Ultimate Fidelity Amplifier
There is EX14
thank you again, mr. mile.
i didnt end up building ex14, though. 🙁
fx14 was already increasingly difficult to build for me... i would like something similar to fx8's parts count for my current project.
could it be possible to ask you for fx8 with fx14's input stage? (diamond differential? balanced ltp is it called?)
i know they were used in sansui amps and sansuis have a special memory for me, maybe thats why i find fx12 to sound so gorgeous. 🙂
oops sorry, i meant FX12
I guess it would basically look like this amp with ccs
duplicate R2 and place the extra resistor before the C2 tapping.
I don't like the unbalanced collector loads on the input pairs.
I don't understand R7, R8 & Zd1
Do not pass all the bias setting current through the R16 adjuster. It will not last long.
Are the outputs vert or lat?
Its an old JLH design using ( obviously ) lateral mosfets. Despite the unpromising lack of balance in the input stages the amplifier gives remarkably good measured results with very low thd. The zener diode and associated resistors set the input stage and vas standing currents.
Parameters amplifier APEX FH11
Hi, friends! Tell me, pleas, parameters amplifier APEX FH11 (2 pairs of output transistors). I am intrasting:
PSU nominal - ??? (V)
PSU maximal - ??? (V)
Output at 4R - ??? (W)
Output at 8R - ??? (W)
BIAS (Quiescent current of output transistors) - ??? (mA)
Thank you!
