when is ground not ground?
  • All grounds do not go directly to the chassis.
  • Absolutely avoid having any ground conductor handling both signal and power returns.
  • Avoid multiple ground paths for the signal (ground loops).
  • Use only one end of the shield inside equipment.
  • Do not connect the chassis directly to the signal or power supply grounds. Isolate it with a type X2 capacitor and parallel resistor.
ok once again where is it written that the 0 volt node of a supply must be grounded?
I presume that you mean to safety/earth ground? If you do, that's true, so long as no exposed conductive elements of the internal circuit are accessible externally for shock hazard reasons. Which, I believe, is the point AndrewT has been making.
Commercial audio equipment sometimes has signal ground (0 volt node, as you call it) isolated from safety ground via some device, such as a diode bridge, or a varistor. Such devices break or limit power mains induced ground loop noise current via that equipment's power plug, while still ensuring that safety ground and signal ground remain safely close in voltage potential. An internal fault energizing the enclosure via the ground isolated internal circuit will still trip that equipment's internal protection breaker.
ok Ken can you explain why "ensuring that safety ground and signal ground remain safely close in voltage potential" is correct or even required? signal ground and safety ground can be at different potentials without problems.
I will let you answer that for me. Would a shock hazard exist on the exposed outer ring (signal ground) of an RCA jack should the preamplifier circuit driving that jack experience an internal fault that coupled 120V (with respect to safety ground) on to that circuit's signal ground?
...if by code we can't or are not allowed to isolate connectors from safety earth isn't that just a recipe for noise hum problems?
Yes, it is. Which is why audio system hum problems are not uncommon. However, not earthing exposed connectors is a recipe for death by electrocution. National electrical codes are not concerned with audio hum problems, they are concerned with safety.
not for long if the safety/earth ground is functioning.
You're making my point. If the powered circuit is isolated from safety ground then the safety ground offers no shock hazard protection.
and if the rca was isolated from the case there's less chance of that condition existing.
Rather than reducing a shock hazard, isolating an exposed connector from an safety earth'd chassis creates a shock hazard if there is no other tie between safety/earth ground and the signal ground.
i whole heartedly agree that electrical safety is paramount.
so perhaps a new standard in connectors in which the signal common/ground is not exposed or touchable making it complient with code should be explored. or perhaps all interconnects should contain repeat coils so that we can have a better chance at peace and quiet (in our systems)
still don't know, or thus far no one has adequately addressed my original query as to why the 0 volt node of a supply should see safety earth. why is leaving this node floating not acceptable?
An ground loop noise canceling audio signal interconnection standard has long existed. XLR connectors over a 3-conductor balanced impedance interface.
Yes, we have. Several times. Perhaps, you are not able to comprehend the technical explanation. Or, maybe, you're simply too stubborn to acknowledge it.
if a fault where to put a lethal potential on an isolated connectors ground wouldn't that fault not also cause a supply line fuse or protection to trip/activate(?) and in the event that the fault not be sufficient to blow fuses or trip protection would the circuit still operate correctly...
and when it comes to balanced connections the proliferation of semi pro gear with "bad ground practices built in" and some members of this forum falsely expounding that "all" connections made using XLR's must have pin 1 connected to the safety earth is not entirely correct
in microphone circuits indeed pin 1 should be at ground/earth ac mains ground for safety.
but for interconnects linking pin 1 to both signal and safety grounds is a garrantied ground loop.
The mains powered equipment we can build is ClassI. .............
There is a secondary requirement:
All exposed conductive parts should be connected to the protected chassis.
This is the one that requires all the metal bits sticking through the enclosure (even if it's plastic/wood) to be safe to touch.................
