No, I'm not set up to do so currently.
I expect the software plugin is fine.
The sound difference I hear is reduction in extension of both lows and highs, with a bit of dirt in the mids...symptoms of noise.
You will have to listen closely for the changes, amongst which is a change for the worse in the flow and 'vibe' and clarity of the music.
The 'dirtier' the source track the better.
Dan.
I thought you indicated that the differences were "Yuge!" Even so they should easily show up in testing given your description if its the software. If its some combination of software and hardware (e.g. running out of CPU, quite unlikely on a recent computer) then only you can check it since you have the specific hardware.
I am astounded that there should be any such a difference.
To make things clearer, I am playing back some very old Tango music...scratchy sounding violin etc.... a good test.
I found this by accident...hey I expected the playbacks to be identical...in this case, I find that the ABX plugin does change the sound compared to the original.
Dan.
So, you could provide the music files that you use to hear the big diffo in the ABX plugin, for others to test with?
What could possibly lead to a "preference" in a DBT/ABX??
Explain?
Huh? You use whole songs to compare because that's what you want to do and you like A more than B. What could possibly lead to a preference in a casual sighted comparison???
Scott, it's a phishing expedition of trying to invalidate useful experiments because they lack absolute values. The entire premise of his arguments is built on it must be either X or Y rather than any muddling of "some contribution of X and a lot more contribution of Y. Oh, and don't forget Z".
My life got a lot better after I made some profile changes.
It's a great article, very clever experimental design, absolutely worth the couple dollars (and I have no financial interest here).
I enjoy that you're concerned that how we think of you entails the belief you'd try to swindle the handful of us that read this thread for a couple dollars
Welcome to the club 😎
Jan
Let us try and with some civility discuss a theoretical test to determine what is the minimum audio bandwidth required to make no perceptible changes in recorded music to be played back on a reproduction system.
Now this is often given as 15 - 15,000 or 20 - 20,000 hertz. Some acknowledge that younger subjects may have better high frequency hearing.
The obvious method is to use a set of headphones and a level controlled oscillator. Some claims have been made that high frequency perception is not accurately measured by this technique. One valid point is that issues such as room reverb and even some noise level may actually improve the perception of audio. Of course there is also atmospheric loss of high frequencies which don't occur with headphones.
So we can first start with the music source. Musical instruments may actually produce energy to several hundred thousand hertz. Our ears have a dynamic range generally acknowledged of around 140 dB.
To be sure we have no bandwidth or dynamic range issues we can aim for a 200,000 hertz bandwidth and 150 dB or 25 bit dynamic range.
The test room should of course have noise levels of -10 dBa or so to not allow any known influence.
The room reverberation is another issue. A dead room may not be the best, so multiple rooms may be needed. Perhaps dead, .5 S, 1 S, 1.5 S, 2 S, 3 S, 5 S & 7 S reverb times should be used to allow for classic reverberation. That of course leads to direct to reflected ratios, and more rooms to examine those contributions. Perhaps we can get away with only 20-30 test rooms. particularly if we allow for artificial noise level adjustments upward.
Then there is the reproduction system. Harmonic distortion probably should be at least 60 dB down for upward masking. Downward masking is not as effective, try 100 dB for those distortions or noise.
Test subjects? Figure a minimum of 10, with 30 or more better.
Makes earphones seem quite attractive for a simplified test.
Even with all this the issue bites us hard that you can't prove a negative.
So demonstrating something exists with headphones is fine. For example I can hear from 15 to 18,000 hertz. But concluding based on headphone measurements that a loudspeaker system only needs to cover 15 to 18,000 hertz probably ignores the kids who can hear to 22,000 hertz and maybe much more!
Why would it be useful to go over the heard frequency range? Something that would be interesting is why two instruments/samples/etc can play the same note, that to our eye appears like the same FR plot, but our ears can hear a timbre difference. Yes we can zoom in on the FR plot and see minor differences that can account for it, but we can't quantify them. As far as I know, no one could look at both and tell you which is going to have A or B timbre or predict what one will look like that has a specific quality if you had a whole alphabet worth.
No, you seen to be equating vanishing THD with "sameness". But they still might in fact sound the same to someone in their favorite system or a dozen different folks might each prefer a different one over the other.
What you said. Bold added.
I said nothing about THD... but presumably with a lack of THD, there is no difference.
If you disagree with that statement, say.
I asked on what BASIS would a preference be found - the preference you refer to??
Assume an ABX or DBT test so that there is no visual or other bias.
_-_-
What can make allegedly same-THD+N amplifiers sound different?
I am not claiming that all of these are of equal or even great importance, just things to consider.
Interaction of the source component with the input of the amplifier, including distortions occurring at the input. Cordell and I have suggested that higher input impedance can be useful here, especially if the source component's output is the typical mid-sized electrolytic capacitor with perhaps a 100k to common to get a low d.c. output offset.
Overload behavior, including out-of-band signals that strictly speaking shouldn't be there. Within this category, not merely slew-rate limiting but in particular asymmetrical slew rate behavior.
Slow shifts due to signal-induced changes like self-heating (what was proudly re-invented as "memory distortion" but known to scope designers for many years).
Interaction of the output with the load.
Note that some of these will likely not be revealed by hooking up the Ap (or whatever generator/analyzer) in a specific "standard" configuration, and using sinusoids for the test signals.
Some of this gets severe with other components like phono preamps, where about everybody drives the input from a low-impedance generator, which for MM inputs is ludicrously inappropriate for measurements of noise and distortion---but almost always is used to publish the RIAA accuracy. That's fine to do in itself, but the interaction with a specific cartridge or representative test load is also important.
Their favorite cable makes one oscillate? Remember I've been there no scopes or diagnostic equipment allowed in the listening room. No propeller hats either.
Ed takes a design cue to make sure he's above/outside the known realm of human possibility, both in terms of DR (mosquito in the neighboring county to Saturn V launch pad 😀) and, now, in terms of FR (turning one's internals into jelly to making the local bat population hate you... I jest, I jest). Given this distinction is blurry, it certainly has plenty of merit to ensure that you're staying ahead of what we know is possible. Just have to keep in mind what other design compromises one must make to achieve those goals. Sorta like making absurd specmanship amps -- stability at the extrema gets harder and harder to control.
Gets back to the aphorism "perfection is the enemy of good enough".
Bear,
If you take a single topology and build it two ways, one where all the devices are matched as close as possible and another where plain Jane devices are used, no selecting of components, one with let's say 50 db of negative feedback and the other with matched components and 25 db of negative feedback and both measured exactly the same 0.005% THD would they sound identical at the same output level?
RNM,
Your results look so good I previously would have thought that such data was dry lab'd.
You can also do similar setup for headphones. In L.Audio Vol3 there is before and after of an over-the-ear headphone measured at the ear canal entrance that was EQ'ed using same gear as for my M2/room.... made very flat over most of the FR range.
THx-RNMarsh
Bear,
No, they would not sound the same. DF and Zo vs freq would be different.
THx-RNMarsh
BTW I have no idea why I posted that bit about Candy. It seemed to be connected with something relevant at the time. I hope it had some entertainment value.
Sure it has!
So it seems your unconscious part, brought back to your memory the image of something that you’d feel better reading than reading what you read on your screen now.
(that “something relevant” is still taking place now).
George
THx-RNMarsh
That gain is going to have to go somewhere, thus into local loops as opposed to the outer loop. Without running the sims on such a reconnection, I do wonder how *big* a difference in Zo (and thus DF) we'd be seeing.
So add LP clicks to the digital playback.I meant without doing anything about the vinyl artifacts. The chance of a random LP not having an audible tick or pop is low.
Edit: OOPS saw later in the thread this has been mentioned.
Scott, I will answer you about Quilter soon.
Jan
I should join that club too. Full Rasmussen syndrome in effect and I've already had an award winning legend tell me my system is rubbish 🙂.
What you wrote needed correction/clarification which was provided.
Free yourself from stereotypes like "GEB" or something similar. As SY correctly pointed out, at the beginning of any experiment a clear stated hypothesis is mandatory. This hypothesis is the basis for any operationalization and includes the answer to the question if there is at least one human that could hear a difference or if the average Joe will be able to differentiate between the DUTs .
If you want to select a highly qualified listening panel then you have several options for doing so. Surprisingly it can make a difference if your are looking for people who are good in detecting "sameness" or if your are selecting humans who are good in the detection of differences. The signal detection theory with its experiments is a good source of information around those questions.
Please remember that every careful experimenter should be interested in getting correct results but not only those that suits his/her own beliefs.
The authors of the often mentioned ITU-R BS.1116-3 wrote for good reasons:
Other than about common places, I have no idea what you are talking and what is your point here ref. my original post. Sorry, it must be my dumbo day.
You're sure you meant to quote me?
- Member Areas
- The Lounge
