Programmable testing with 00-99 setups stored in memory.
Very nice. I haven't actually got one... wished I had, but I haven't. We can dream
Seems like rather poor heat transfer to the finned heatsinks?
The fat aluminum block will certainly "spread" the heat, and take a long time to get hot...
Copper plate between power transistors and Al heatsink will correct thermal situation.
Mixing conductivity(and greater thermal capacity of copper) and convectivity.
RNM,
What caught my eye in the picture of the amp and heat sink was the intermediate plates which are obviously modules that can be strung together. What is the material used that is coupling the sections together, it looks darker than the aluminum plates. I just wonder how the transfer is between the sections at that point?
yes, it is a lot bigger.
More assumptions..... it isnt going to cost me anything (0).
That, and your amazing hearing, makes you a true expert when it comes to audio design.
The fat aluminum block will certainly "spread" the heat, and take a long time to get hot, but it seems like a standard finned heatsink with a large flat surface, while looking less exotic/Krell-ish would actually transfer more heat more quickly to the air??
The power density at the interfaces won't create that large a thermal drop.
Where the biggest bang will be is at the semi package to plate interface. I can't see if there is an insulator there, but if there is and it's not alumina, swapping to that would make a big inprovement.
Also, can't tell if the packages are iso. If so, I'd plop non iso over alumina as well. And I'd toss the paste, go with graphene sheet at both interfaces.
Course, RM's probably runin 5 watts per device anyway, so this is all probably moot..
Richard, nice hardware, I love it. Never seen a toroid with 4/0 wire before..
John
To be part of the Golden Dung (fly) Brigade requires a bigger rod&schwanz ?
No, only an employer that doesn't mind you wagging the schwanz outside the regular schedule.
Where is Ed complaining that the heat sinks are not black?
I think we went over that and at the typical audio amplifier heatsink temperature a black finish has only a small effect. It is when you get quite a bit hotter when it begins to really make a difference.
BTY I noticed you didn't contribute when microdiodes came up again & again. I keep telling you by my measurements there is no effect shown from microdiodes in copper wire.
Waly,
Is Le Bistrot Lyonnais still the same?
There you go again! Assumptions.
what employer? I am retired. I don't have a job. I am unemployed.
It's all magic.
THx-RNMarsh
yes, master.
It's all magic.
Focus Mr. Marsh, that reply had nothing to do with you or your realm of reality.
Immediate reaction looking at the pix.
Very nice looking.
Is it pure class A?
How many watts are estimated in heat??
signed,
confused and curious
YES !
One of These :
https://www.jameco.com/z/7023B-MTG-...-Tabs-4-4-deg-C-W-Black-Anodized_2039099.html
Outperforms One of These :
https://www.jameco.com/z/530002B025...e-Pins-2-6-deg-C-W-Black-Anodized_696626.html
YES !
One of These :
True, the former sounds so much better.
RIGHT !
Look's like the internals of a Tube !
HAH! And I was wondering where the tubbish sound was coming from.
yes, master.
is anyone using DADiSP besides me? Great software and very fast code.
I used to have in my home a full LSI-11 system (with math coprocessor) and a lot of memory (for the time) and I ran this software on it and it was really great in the way you worked with its windows. Later upgraded changed to PC version. Check it out.
THx-RNMarsh
THx-RNMarsh
- Member Areas
- The Lounge
