Ok and with Peeking ...... if you knew which had 480 and which had 720 and 1080 and 4K and 8K..... and you looked at each of them and said you could see a difference and further that you could tell which one was more accurate picture.... greater detail and more accurate colors, etc, would that viewer be wrong because he peeked?
No way to tell because the experiment was not designed correctly. You can't draw valid conclusions from an invalid test setup.
Right
Even though a 100 out of a 100 will experience a marked difference between 480 and 4K. We cant trust that because we peeked.
What's wrong with this picture?
Richard
you should use a MONO record, or switch your amp in MONO mode, to position your speakers...
after you find the correct position of your speakers you can switch back to STEREO.
yes. I do that also..... voice is always recorded in center and that can be used also. But a hard mono is certain.
-RNM
I'll order one later today from RS and give it a try next week. Can't do any harm!
For audio, I would use a much larger value across the lines. But to ground, the C value must be limited to a safe leakage amount.... in USA <4mA.
Leakage Current Standards Simplified | MDDI Medical Device and Diagnostic Industry News Products and Suppliers
Also, if you notice the level I was reading on the CATV was much higher than this safe amount. That is because I had several products on line... each contributes leakage current so the total may be unsafe even if each individual equipment is 'safe'.
THx-RNMarsh
Complete and deliberate non-understanding of sensory experiment design.
I was just musing about the fact that some people swear by a dedicated spur for audio
Yes, but those are the folk who think mains cables sound different....
Exactly... All too common.
On the topic of clean power for our audio, here's a business opportunity:
Get one of those new Tesla Power Bank home super batteries, around $ 3500 for iirc 6.5kWhr.
http://www.bbc.com/news/technology-32545081
Slap a nice High End sticker on it, sell for 8k and you're done.
Probably even measures good. And runs your coffeemaker in the event of a black out. Win-win 😎
Jan
Jan
Well, Richard and I belong to the group who actually have confidence in what we see and hear. As far as seeing, I can be fooled more than some of my more attentive colleagues due to my own vision problems, but when it comes to hearing, both Richard and I are most probably MORE EXPERIENCED in listening to audio differences, and we have come to trust our ears over the decades of having some of the best listening equipment, as well as participating in listening tests, including ABX double blind, one of which we both participated in back in 1980 or so. We both came out about the same sensitivity in this ABX test, BUT 2 others, people who were actually at audio reviewers level, did BETTER than us! In other words, we are just above average in the audiophile scale, and others can actually discern differences sometimes better than us.
Now, we operate and convey our opinions based on what we hear today. IF you want to ignore us, do it at your own loss, since we are both audio designers who have a lot of experience in just about every area of audio design.
Sure SY. Right.
Even if 100% of every man woman and child on the face of the earth can see the improvement in clarity or definition from 480 to 4K... their perception doesnt matter if they peeked. You throw out their perceptions.
I'll stick with the meta-data volume for more accurate results.
Peeking doesnt matter as much as you think it does with some questions. But makes for a nice clean test for test to test comparisons.
THx-RNMarsh
Me too. When I peek, I can tell apart any two amplifiers.
Richard,For audio, I would use a much larger value across the lines. But to ground, the C value must be limited to a safe leakage amount.... in USA <4mA.
THx-RNMarsh
Why are you referring to current to ground as "safe or unsafe"? Leakage to ground is not unsafe. The limit of 4 mA is because of the trip value of GFCI units for human protection.
The link you posted refers to leakage that can go through a human body, not leakage to ground.
John
I am sure you tested this hypothesis, so it must be true.
Richard,
John
The leakage to ground can become the current thru you to ground. So it must be limited.
-RNM
You need to look no further than the medical/Pharma industry in this country.... DBT say all is good but when it gets out to very much larger numbers (the meta data) a very different picture sometimes emerges. And, it is That info which is considered to be more valid and important nor thrown out as not matching the results of the DBT. So, the DBT is an important first step, only.
THx-RNMarsh
Aren't we discussing ground loops in fully grounded systems, where two grounds causes unwanted currents?The leakage to ground can become the current thru you. So it must be limited.
-RNM
John
JN,
Somehow I thought that Richard had transferred to talking about grounding in test equipment, not sure how that happened but that is what I thought changed here. Perhaps I missed something.
John
We are discussing ground loop cause and prevention AND ac line line noise filtering. Multi-tasking going on.
UL takes into consideration of faults in wiring, grounds and equipment. Thus GFI, fuses etc. And, there may be situations in their mind where you become a better return path than the existing paths. So, you need to heed their limits (and IEEE) with regards to ac filters.
-RNM
JN,
It's been difficult to follow, I will admit. But the his last post referred to audio and I think, filters acros the line.
Typical line filters do run some current to ground, and 4mA is the limit due to unwanted trips in GFCI's. But a filter sending current into a three prong cord can push amperes with no danger to humans unless the ground bond is broken.
That's why I didn't understand the link to human electrocution limits..
John
I'm often amazed at the hyped complaints or fears - do the sound propagation in air path length and tell me if you speakers-listening position are located that precisely
It matters a hell of a lot if you are trying to configure a measurement system with it. Not a lot if doing hifi playback.
(oops.... context: whether it matters if channels are a sample out of synch in a soundcard)
- Member Areas
- The Lounge
