Hypex NCore NC500 build
So after a customer told me he had rewired his Nord One with Neotech Solid Copper Wire with superb results I thought I'd give it a go. What do I have to lose apart from the £15 for the 1M I needed! 😱
Still I'm open to the idea sceptical but willing to be proved wrong, need 24 hours to burn in. (Well the dielectric to form in the correct direction anyway)
Neotech SOCT solid core copper wires
Neotech`s SOCT type wire is 99.999% high purity UP-OCC copper solid core wire, sheathed in red, heat resistant teflon. Can be used for speaker wire, mains cable and general hook up wire, the best solid core copper wire currently available.
Danny Richie also advised me the Neotech to wire my KEF Q100 loudspeakers. I have not bought it because I have been unable to remove the speakers without damaging the boxes!
Neotech SOCT solid core copper wires | Hifi Collective
SOCT-16: AWG 16, 1 strand of 1.3mm wire, diameters, inner: 1.3mm, outer: 2.45mm, 600V, 16A rated.
Skeptical enough to do a double-blind listening? Or even (gasp!) measurements?
The only SQ issues i can notice are badly designed speakers, severely distorting or under-powered amps. Cant hear differences between wires, opamps, DACs, high sample rate music etc etc...
I should get out of this hobby, clearly not made to get the best out of it
That just means you are blessed because you can get maximum enjoyment from your system at minimum cost 🙂
