Valve Itch phono
The relay does not know anything. It only clicks when DC goes through its coil. You know what to do with it and what to label. If you got an input that goes to an installed SUT and a direct input for instance, you can label the RCA to SUT "MC" and the RCA direct "MM". Same for the front panel switch positions. Then select SUT output or the direct to the 40-45dB gain level phono preamp circuit. Now you got MC or MM input selectivity.
