Looks like I will have to do that exercise shortly, of getting the best out of foobar, 🙂. On this very ordinary HP laptop I have at the moment, the internal sound system, including the tiny inbuilt speakers, does a surprisingly good job if everything is carefully adjusted. That is, the speakers do largely "disappear", quite a decent soundstage is brought forth, it's pleasurable to listen to for extended periods - this completely evaporates if an ordinary software player is used, it collapses back to low level, kitchen radio sound.
Just flicking my head around, now and again, to make sure I'm not about to be ambushed by a snup ...
I know you are more cunning than cunningest Blackadder scriptwriter.
luckily I can hear your keyboard from miles away and my golfcart is faster than yours
againt a female sweedish tiger in a sweedish bush-like landscape a male tiger wouldn't stand a chance
GIGO, BigE. Garbage In, Garbage Out.
So now you are suggesting that the input stream is the problem?
I'd just sit back and let the grown ups talk.
So now you are suggesting that the input stream is the problem? I'd just sit back and let the grown ups talk.
I have never said anything like that.
Discussion started with my (INPUT) statements:
(1) Anything can happen in software and computer processing. So that nothing surprising if (2) Players sound different (they do).
And I have explained a few things so that it is clear why and how it can be so (the OUTPUT of the discussion). I expected that I can explain with a single statement or a clue but it has never been that easy.
I am running Foobar principally because I can run a polarity switching VST plugin with it, therefore I have not bothered to compare different players.
I usually play Wav or Flac files into an outboard asynchronous USB soundcard (Roland UA-25ex).
Under these conditions is it to be expected that players will sound different ?.
Dan.
Dan.
Add to Jay's explanation that these (audio processing) programs are written in a high level programming language. The executable program is very much dependant on the used language and its compiler. This adds another layer of fuzziness to processing and routing.
I would say it is impossible to know exactly what is going on at a bit level in a PC.
So everytime I save a document in word without editing I get a different document? Word is much bigger than Foobar!
If I open that same document on my PC with a different monitor, with a different program, with different settings it will not be exactly the same.
I think situations can get different if we use different Operating System. Windows Media Player (WMP) on Windows OS is unique, as they came from the same vendor.
Foobar has a component/plugin (Windows Audio Session API) with exclusive mode output, allowing bit-exact output, muting all other sounds, bypassing Windows mixer.
I just tried to listen to WAV file using WMP and Foobar. They use the same audio driver (the only one I have on my laptop). Different sound.
Since the soundcard is old, I thought, may be if I send the decoded audio in 24-bit to OS/audio driver, the hardware will have a problem. So I tried 16-bit without dither. Then 16-bit with dither. There was no change to Foobar sound with these 3 options.
The WMP sound is unique. It is less defined than Foobar, but it seems that the sound is smoothed out, as if there is some kind of dithering, but I couldn't hear noise change either (very noisy here at the moment).
I would say Foobar is more accurate (with its darker background), but due to this "smoothing" of sound, WMP sounds less aggressive. That's why I like WMP!
Just saw a mention (Amir at WBF) of Foobar triggering a memory leak which might possibly be a reason it sounds worse under Win7/Vista. The link here says it can raise CPU utilization to 100% in certain circumstances - Fix Audiodg.exe High CPU Usage in Windows 7 | Windows EXE Errors
Might possibly be worth a punt Frank?
- Member Areas
- The Lounge
- Have you discovered a digital source, that satisfies you, as much as your Turntable?
