Digi-key sells Berquist Silpads to fit a TO-247 case. These should also fit a TO-3P case. It would help to know exactly which cse you really mean by a TO-3P, whether it is the old TO-3P case with exposed metal tab like the TI TIP34 series or something else. In any case, the TO-247 insulator should work just fine.
These are On-Semi MJL3281's (TO-264 case) for a Class A amp.
I wanted mica because I really expect to be experimenting a bit, and a sil-pad would have to be cleaned off and replaced every time I remount the device. Mica, on the other hand...
wrenchone...I honestly did not see the TO-247 Berquist pads at Digikey. They appear that they will work, but I'd still rather have mica.
Sil pads
RS Components have these
2015-122 TO-3P 283-3672 £1.58 £1.34
http://rswww.com/
At £15 pounds for 10 they seem expensive
technical specification
Thickness: 0.38 mm
Thermal resistance: 0.20°C/W (for TO-3 case)
Electrical insulation: 4 kV
Thermal conductivity: 3.5 W/m-k
This looks like they conduct heat well.
These are a lot cheaper.
3223 07 FR-122 TO-3P 283-3638 £0.28 £0.24
At 28p they are a lot cheaper but you have to buy 50 so you still have to spend £14 pounds.
Thickness: 0.18 mm
Thermal resistance: 0.40°C/W (for TO-3 case)
Thermal conductivity: 0.9 W/m-k
I presume that there not much point in having a massive expensive heat sink if the heat from the transistor is no passed to it???
Looking a some of the posts I may has well just stick some insulating tape to the bottom of the transistor and bolt it up.
I'm confused
http://rswww.com/
Thickness: 0.38 mm
Thickness: 0.18 mm
I'm confused
BrianGT said:I have used the 4170 them for both the TO-3P (TO-264) and the TO-247 devices. The 4180 is bigger. As you can see, the 4170 works fine, since it is thicker and seperates the package from the heatsink. For the TO-264, most of the contact area on the package is covered with the 4170. I couldn't find the 4180 at the time, but it is a better choice.
Hello Brian,
As the ceramic insulators are quite rigid, one must also use something else to fill the gaps. Did you use thermal grease or something else? Thanks in advance.
Charles Hansen
I would think that, with anything other than a Sil-Pad, heatsink grease would be a requirement.
As far as my own needs, Aavid came through with a few samples for me. I still couldn't find anyone to actually sell the bloody things to me, but I have enough for the current project.
wrenchone said:Digi-key sells Berquist Silpads to fit a TO-247 case.
it's Bergquist -- plug in and the parametric search engine at DK will spit out hundreds of examples -- they don't yet have fuzzy logic which convert our misspellings
Re: Sil pads
Melted insulation tape will make a nice mess of your output devices and heatsink
HuntTheShunt said:Looking a some of the posts I may has well just stick some insulating tape to the bottom of the transistor and bolt it up.
I'm confused
What if the Heatsinks are hard coated (hard anodized?) and the transistor just mounted directly to the sink? In another thread, there was confidence that the electrical insulation and the mechanical resistance of the coating is good enough to ensure safe operation.
And I guess, the thermal resistance of the hard coating isn't higher than that of a insulating pad. But I don't have any numbers.
Ciao, Tino
Ciao, Tino
zinsula said:What if the Heatsinks are hard coated (hard anodized?) and the transistor just mounted directly to the sink? In another thread, there was confidence that the electrical insulation and the mechanical resistance of the coating is good enough to ensure safe operation.
Ciao, Tino
when you drill through you have to make sure that you use an insulated shoulder washer -- and you still need the thermal paste -- the paste is thermally conductive for any voids or imperfections either on the heatsink or on the semiconductor.
if I had to guess I would think that not using an insulating pad would raise a potential hazard such that Underwriter's Lab (in the U.S.) would not certify the product as "safe".
jackinnj said:when you drill through you have to make sure that you use an insulated shoulder washer -- and you still need the thermal paste -- the paste is thermally conductive for any voids or imperfections either on the heatsink or on the semiconductor.
I agree, these are the premises to do this properly.
Yes, that's likelyif I had to guess I would think that not using an insulating pad would raise a potential hazard such that Underwriter's Lab (in the U.S.) would not certify the product as "safe".
However, especially in balanced designs and not so high power rating, it may be possible to be below a voltage threshold (48V???) used to classify the hazard potential.
Semiconductor Thermal Paste?
I'm looking for a good thermal paste that I can use with, or without thermal pads that is non electrically conductive. This seems to fit the bill. I have pieces of aluminum angle used also where I want solid thermal transfer. Comments or other suggestions?
I am unaware of any standard thermal paste that is electrically conductive at the kinds of voltages we see in audio gear.
If any of the the usual products were conductive, sloppy me would have left a trail of non-op amps behind me, and it didn't happen! ;-)
neckro of the year?
when doing metal to metal thermal contact, AND you need an insulator, relying on a paste for electrical isolation is foolhardy.
do you want paste on thermal pads? the word "pads" implies insulator with thermal coatings.
use plain old white thermal grease and a proper insulator , IMO some of the pastes tend to dry out sooner than others.
if you explain in more detail what your application is "the questions" will become clearer.
redjr,
I think that aluminum thermal compound is electrically conductive. Good for CPUs but I wouldn't recommend it for amps.
The type that is normally used is silicon thermal paste. It is non-conductive. Simply spread it evenly on both sides of the mica insulators and bolt the transistors to the heatsink.
If you don't want the mess, go for something like silicon pads. No thermal paste needed.
redjr, they make commercial silicone non-conductive heat sink grease, and it is readily available.
If you are not using a pad or mica wafer, then the conductivity is not an issue, because as infinia said, expecting paste of any sort to act as insulator is foolish.
Examples:
8616-3ML MG Chemicals | Mouser
10-8108: GC ELECTRONICS: Test, Tools & Supplies
Examples:
I didn't think I could make myself any clearer, but apparently I do. I don't need any paste simply to use as an insulator, nor do I expect any to do so. You can use paste and an insulator together though. Maybe I don't need to, but I like the idea of paste filling in the imperfections of the metal before the thermal pad.I am unaware of any standard thermal paste that is electrically conductive at the kinds of voltages we see in audio gear.
For pieces of aluminum angle or channel, since they will be used as an extension for the heatsink, I simply want to use a good thermal paste between them for better heat transfer - not any electrical conductivity.
Rick
How well do the alumina (oxide) insulators work? Does anyone have data or a reference?
It would seem that the much increased thickness would work against overall thermal conductivity, even with alumina being a better thermal conductor than mica in general. I looked, but couldn't find data comparing mica insulators vs. alumina insulators. The alumina ones look more 'serious' though!
why even mention non-conducting pastes if it's a don't care?I didn't think I could make myself any clearer, but apparently I do. I don't need any paste simply to use as an insulator, nor do I expect any to do so. You can use paste and an insulator together though. Maybe I don't need to, but I like the idea of paste filling in the imperfections of the metal before the thermal pad.
Rick
thermal pads don't need anything in fact by you adding stuff spoils the performance, read the data sheets. Do the thermal analysis! (it's as easy as ohms law) if one thermal interface is real problem, then a 'magic grease' isn't the right solution. IMO full stop. If one thinks the commercial stuff isn't good enough... looking all the CPU exotic pastes really aren't any better, 'Tom's Hardware' has done several articles you can look up. Spend the money on more surface area and getting the machining / mechanics right. Angle stock thickness , flatness, proper hardware torqueing sequence and all that. Any improvements to ventilation / and air flow is HUGE in the area of heat management.
Kapton works fine _only_ if the surface of the heatsink is smoothe and particular the hole has no sharp edges. It's very easy for those edges to cut through (= no insulation)
I always countersink the holes slightly to remove any burrs.
- TO-3P Insulators
