Hello, I would like to ask for some help.
I bought a TDA7297 amplifier (this) and I tried 3 different power source (DC) and I got no bass.
I tried with
5V 1A (USB), no noise, but no bass
12V 12A (XBOX360 PSU), big noise, no bass
8.5V 1.5A (Camera charger), big noise, no bass.
Do you know what the impedance curve of your speakers looks like? Perhaps the impedance is too low at bass frequencies for this little amp to push sufficient current. Just a guess.
I don't know anything about their curve, but I tried with 2 really different speaker but the result was the same.
Maybe some diode or the DC filter cap (the big one) faulty?
Given "The Big Noise" I suggest that the input potentiometer has failed or is of unusable quality.
Try replacement with ordinary resistors.
3.3k from input to centerpoint.
22k (or 25k) from centerpoint to ground.
The source will see 25k3 load, but the amp will see 22k load.
About 13%~16% of the input voltage will get lost that way; however, a greater amount of noise will get lost.
The amp offers 6W~8W good audio along with 10W~22W headroom capacity of sketchy quality. So, all you need be concerned with is that first 8W of decent. If we can get enough voltage to push that, then the rest is just there for extra fun.
Other steps: The input capacitance can be raised up to 470n so as to allow more bass to pass.
I tried with
Could you help me Guys why I have a crap sound quality? Everywhere I read this amplifier have good sound quality , but not for me.
Thanks!
Those are all junk. And like I said on the other forum the input capacitors are too small for a lot of bass. You should use 1uf film input capacitors, at at least 12v. You need somewhat efficient speakers too.
I successfully solved the crap sound quality problem... I got 2 defect audio jack cable, adn this caused the problems with the quality, it was hard to believe the chance for having 2 defect cable , and I re soldered all thing on the PCB and now got less noise, finally I put a Step-Up converter to the input, so I made 13V from 5V or 8.5V, I know I loss some power, but less noise with the 8.5V adapter, and higher volume from USB power banks. But now it is okay.
I tried to solder the ground to the body of the potentiometer, but then the potentiometer worked weird.
I will try to get some capacitors, just the local radio shack got nothing... Could you guys help me pick the right ones from this site please?
Thanks for the help! 🙂
Thanks to a generous forum member who has helped me get things right,
I have managed to put something together which i am very happy with. The board is fed with a 13.8v input and the upgraded capacitors maintain the original board values.
Power supply capacitor swap:
Nichicon UHW1E222MHD (Digikey part :493-6873-ND)
Input capacitor swap :
Nichicon UKW1H2R2MDD1TD (Digikey part :493-10794-1-ND)
This version of the amplifier bypasses all the diodes with the use of the DC connector. Both diodes have since been removed (no jumper required).
The one on the left has the capacitor and terminal block swap.
Is this the new Lunch Money Amp? $6.64 for a class D TDA7492 50w/ch shipping included. I have a couple on the way.
Online Shop 2015 Digital Amplifier AMP Board TDA7492 High-Power Powerful with Radiator Hot|Aliexpress Mobile
Yeah, it's hard to believe they can sell these for $6 buck and change! I just ordered a couple too. Hard not to. 🙂Is this the new Lunch Money Amp? $6.64 for a class D TDA7492 50w/ch shipping included. I have a couple on the way.
I literally paid $8 for lunch today and as I was eating, I thought to myself - I could have had a TDA! 🙂
Just got mine Hot Rodded a bit .... Left the diode and the small ceramic cap in ... As usual, photos to follow....
Changing the big input cap made a HUGE difference, less so with the output ( I think ) film caps, but we can natter about function once I post photos.
Dave
Dave
Anyone tried a TDA7379 board with bluetooth, it's lunch money with a couple of beers?
2015 New Arrival Tube Amplifier 4.0 Bluetooth Amplifier Board Tda7379 40w+40w Stereo for Audio Power with Krc 86b Module Car-in Amplifier from Consumer Electronics on Aliexpress.com | Alibaba Group
I looked for finished 7297 amp and only found a tda7377 some time ago, 18 watts measured, in case you really wonder about chinese claim 🙂
Auna AB-250 2-Channel Car Amplifier -1200W Bridgeable at the Best Price!
TDA7492 is a class D amplifier, vs class AB of TDA 7297.
I still found some residual high frequency from switching at the output of my ta2020 amp.
I think you're better off with one of these things:
12V Car Bluetooth MP3 Wireless Audio Module USB TF Radio WMA Decoder Board | eBay
Plus it has the remote and different inputs 🙂 Just hook it up to your tda7297 board for 5$ and you're set.
I have had mine for a couple of weeks, I got rid of the diode, it seems to have better clarity. This weekend I will changing out a couple of caps. I am using it with my Bottlehead Quickie-battery powered preamp, ADS L470/2 speakers and a Marantz CD5004. For power supply I am using a 12 volt SLA battery. Lots of fun for the price of a lunch!
I await your assessment.
Depends how fun it is to mod .... Not sure how to find replacement inductors The rest of the caps look pretty easy to get at. Should run on a laptop SMPS, a bit more voltage is sometimes a good thing.
Thanks, but the description does not mention bluetooth, I'm guessing it's not?I think you're better off with one of these things:
Yes you are right, I can't even see the bluetooth module.
http://m.ebay.com/itm/251684607689?nav=SEARCH
This seems to have the module. FM, usb etc
Thanks, I ordered one of these units early last month from AliExpress but it did not arrive so I have just ordered from another vendor.Yes you are right, I can't even see the bluetooth module.
Wireless Bluetooth 12V MP3 WMA Decoder Board Audio Module USB TF Radio for Car | eBay
I already have the non bluetooth version connected to my 7297 and the FM is super sensitive.
- Chip Amps
- What the heck? It's less than lunch!
