Help building subwoofer enclosure.
I want to build an enclosure for this sub Jbl GTO1014(Ik is cheap but is my first build). I would be using the yung SD300 sub plate amp no boost. I was working on WinISD to design it and I came up with 1.25cubic feet box tuned too 25hz. BUT is that 1.25cubic feet total or not including port and driver displacement? Also need help on making the L port. If anyone can tell me anything on how big to make the enclosure etc. I would appreciate the help. Btw sub is going to be used for hearing bass heavy music ,EDM.
1.25 cuft is a rather small cabinet for this driver, at this tuning frequency.
3 cuft ported to 25Hz will give a fairly flat response down low. If you want a really small box, you need a sealed box, EQ, and a lot of power. You'll lose raw SPL against the ported box, but at least you can keep the cabinet small.
Chris
Nonsense. 1.25cuft is fine for a 1 cuft Vas driver.
3 cuft is nonsense and 1.5cuft is the maximum.
Sealed would be about 0.75cuft well stuffed.
Box volume is internal volume + driver volume+ port volume.
25Hz tuning is ambitious, 31Hz (low B) more practical.
For music a flared 2" minimum diameter port should work.
rgds, sreten.
No one WANTS a large box, it is just physics.. A car driver requires between 20-25% more volume if used in a home instead of a car. You are more than welcome to build a box based on cabin gain and put it in your house but you will be greatly disappointed unless you have eq and lots of power. Chris didn't make up a rule, he cited well established norms. Sorry if it's not what you wanted to hear..
No, Chris is citing simplistic opinion, not well informed fact.
Its simply the wrong driver for a 3cuft vented box, Vas is 1cuft.
Non standard alignments are not a disaster, just not standard.
rgds, sreten.
A vented box of 1.5cuft internal dimensions will be fine.
Reality will be the box is less due to the port and driver.
hi leo143
For home use:
Sealed = 20L (0.7 cuft) F3=44Hz
Ported = 25L (0.88 cuft) F3=29Hz
hi leo143
For home use:
Are you sure that info you plugged in is correct? This are the specs for it
Woofer Specifications
Voice Inductance
@ 1kHz (Levc – mH) 3.05
Driver Radiating Area
(Sd – in2/cm2) 51.15/330
Compliance Volume
(Vas – ft3 / l) 1.03/29.2
Voice Coil DC Resistance
(Hvc – in/mm) (Revc – ohms) 4
Suspension Compliance
(Cms – ?m/N) 187
Surround
Hi-roll rubber
Magnetic Gap Height
(Hag – in/mm) 0.31/8
Mechanical Q
(Qms) 9.1
Voice Coil
2" (51mm) diameter
Electrical Q
(Qes) 0.48
Motor Force Factor
(Bl – Tm) 15.1
Maximum Excursion
(Xmax –in/mm) 0.57/14.5
Free-Air Resonance
(Fs – Hz) 28.7
Total Q
(Qts) 0.46
Diecast Aluminum Frame
Yes
Vented Polepiece
Yes
Low-Frequency Transducer
10" (254mm) Polypropylene cone
hi leo143
For home use:
I'm getting radically different graphs with WinISD and Hornresp, using the published T/S parameters. Here's a screenshot of WinISD Pro. The green trace is your suggested ported box, the blue one is mine (75L tuned to 25Hz).
According to my spec sheet, Vas=~2 cuft.
Perhaps there's more than one version out there?
Chris
Edit - I'm stupid.
Turns out I was looking at the 12" version. I'll leave this up for posterity, or something...
hi sreten
According to the sim, optimized box is 45L with Fb=25Hz. I'm not comfortable with box volume > Vas, that's why I decided to load it in a 25L. There's a bit of a hump but that's really a small sacrifice.
hi leo143
The T/S are correct. For box sim, only 4 parameters are required. Vas, Fs, Qes and Qts.
You may want to consider a bandpass too. Only 24L. A bit tight but should be possible.
