Kevin YHPM.
Has anyone done any optimizing to the settings or motherboard system to get best sound? Any recommendations?
Adjust or shutting off anything that will reduce over all system noise. Anything not having to do with audio or unnecessary to daphile. That sort of thing.
I have seen what I'm suggesting done in other server builds with great success. Unfortunately, the software is obsolete and not supported any longer, like CPlay in the windows memory player. Can't do DSD, or else I'd still be using it and not trying Daphile.
Indeed. And the first step would be to verify that they are an issue - and after that, verify that each step actually is an improvement, rather than believe random hearsay on the internet.Anyway, with that said, it's all about noise and jitter.
So I guess any stuff that isn't what you want to hear is "nothing"? 🙂That's ok, if you have nothing to offer, then I'll figure it out on my own.
No, I just don't agree with you.
That's still allowed, right?
Do you consider a vendor of a product that supposedly reduces jitter a reliable source for objective information?It's not Internet hearsay.
Look at cicsmemoryplayer.com.
The creator of the software ran noise test.
Do you have any evidence for that?The more unnecessary parts are shutdown the better the results, this includes in the BIOS.
Lack of demand? Too much competition?Like I said cics memory player is not really supported any longer. There's even missing pages on the site. I don't know why.
In a Computer Transport, parameters like RAM settings, RAM quality and motherboard traffic all make a perceptible difference. The purity with which data is streamed to the DAC is critical. It is here that cMP excels – measurably.
only use 1 RAM module as this improves stability of lower settings.
Advanced CPU Core Features
•Disable Intel(R) Turbo Boost Technology
•Set CPU Cores Available to 1
•Enable CPU Multi-Threading
•Disable CPU Enhanced Halt(CIE)
•Disable C3/C6/C7 State Support
•Disable CPU Thermal Monitor
•Disable CPU EIST Function (this is critical to ensure stability at low CPU frequency operation)
•Disable Bi-Directional PROCHOT
Here you go Julf. Don't know if it refers exactly to what you are asking for, but it does for what I'm asking about. Which is again- Can anything be shutdown in Daphile to improve performance?
Are they even his measurements
And to answer your specific question - no, from what I have looked, there is nothing unnecessary or non-audio-related running in Daphile that would reduce the CPU use by even 1%.
I'll do my own before and after tests with the Daphile server.
