Hello DIYers, the question is open, which is the best , which material, power handling, mounting issues, the wires and plating, the internal connecting, the passivation process, skeletton vs.molded, ceramic vs enameled ? 😕 everything have influence 😉 up to you now 🙂
Anything which hinders electrons to go from the negative to the positive supply is a resistor 🙂
The better ones are more or less linear and Ohms Law R = V/I applies approximately.
Want something to read? Go -> Vishay - Resistors, Linear - Related Documents
Cheers
Udo
Cheers
Udo
McDerbill & sons - Fine hand crafted o-rings since 1827.What's the best o-ring?
edit: You want the "Classic" series, not the other stuff.
Actually O rings that have been touched by human hands are to be avoided in high vacum systems!
As to resistors look at the current blowtorch thread around post 5000.
Should I enquire about units, or just assume that that it will be inches?SY said:
No. It is 42. You make the string 42 long. Haven't you taken a math class? 😛
Cal, perhaps you missed some of Bill Cosby's earlier (and best in my opinion) standup routines - from the first half a dozen comedy albums (63 - 69).
Definitely something you could share with your parents - unlike the druggy silliness of Cheech & Chong, or the singularly brilliant vulgarity of George Carlin.
Dimensionless quantity.Should I enquire about units, or just assume that that it will be inches?
What's the best bolt?
According to Ben Franklin the best bolt is one collected via wet kite string at an altitude of about 350 feet. He wrote that it is important that the string be three-strand cotton wrapped right handed as any other construction will smear the transients in the bolt resulting in a much less impressive St. Elmo's Fire display on the key tied in the string. Of course the key needs to be brass...not the modern alloy stuff but authentic 18th century brass as the modern stuff has grain boundaries that can distort the rise time of the pulse from the bolt. Oh and don't get me started on the kite details, I'll need a separate thread to go into those in depth.😉
I was brought up in that era of comedy. It seemed sad to see them resort to the foul mouth stuff to get attention later on.Cal, perhaps you missed some of Bill Cosby's earlier
Bob Newhart
Tim Conway
Morey Amsterdam
Mel Blanc
Smuthers Brothers
Wayne and Schuster
Red Skelton
Victor Borge
Kip Addota
Many more but by golly this is a thread about resistors, how selfish of me.
My mother almost peed herself laughing at "Up in Smoke", and she and my father took me to see George Carlin live.
Hmmm, perhaps that's why I turned out the way I did.
BTW, "The Aristocrats."
hmm, you couldn't resist 😉 Or reluctant maybe ? 😛A resistor is someone that needs more than a few drinks to get frisky....
- Member Areas
- The Lounge
- What is a resistor ?
