If you're referring to my comments, read my post again beginning with "Which completely misses the point".I'd like to comment on that tired old argument that the switches of the box would 'hide' the differences. That's is an untenable position if you think it through.
The ones that either you or Sy have used to empirically refute FVA's results.
There were no results, so I can't refute it or give a contrary cite. Just a few hand-waves in an internet post. If there's actually something substantive published somewhere, I'd appreciate you pointing me towards it.
Sorry, I'm done with your posting in circles about him.There were no results, so I can't refute it or give a contrary cite. Just a few hand-waves in an internet post.
Frank Van Alstine has been building and selling audio gear for over thirty years. If you read his comments again found on his Audio Circle forum, you would find that there is more than hand waving going on regarding ABX boxes.
Or - are you just speculating? 🙂
What VFA results? There ARE NO VFA results, just bar-talk, and demonstrated wrong at that. Unless you are hiding it - show it and I will read it.
You criticize test issues that are addressed and taken care of in SYs article which you apparently have not had the intellectual curiosity to read.
Jan
Of course I read it. Have you? Test issues that are addressed? That's hilarious!!!You criticize test issues that are addressed and taken care of in SYs article which you apparently have not had the intellectual curiosity to read.
You mean like this:
"Nonetheless, if a particular hardware implementation
of the ABX test is found wanting, it is not difficult to construct an ABX box with whatever
switches or relays are deemed adequate for audiophile use. After all, the signal in an audio system has
passed through many switch and/or relay contacts during recording and mastering, and most audio
systems have source selector switches."
Which completely misses the point.... Again and again.
I understood "distortion" in a wider sense: every transformation of the signal: harmonic and transient distortion, memory effects, compression, frequency band limiting, etc. Some can be very little, and even pleasant to the ear.If the "reproducing chain" adds significant distortion then it is not a reproducing chain but part of the musical performance. I certainly don't want this. However, those who like some distortion may prefer more distortion - perhaps the extra distortion at home compensates for the lack of volume when compared to a live gig?
You mean like this:
OK, is it possible for you to clearly articulate what the point is then?
Jan
ABX BOXES RELY ON SPECULATIVE ASSUMPTIONS AND ARE NOT SUPPORTED BY SCIENTIFIC CONTROLS THAT VALIDATE THAT YOU ARE TRULY COMPARING DEVICE A (BY ITSELF) TO DEVICE B (BY ITSELF)OK, is it possible for you to clearly articulate what the point is then?
You're a funny one! If I would refer to your comments, I would say so, otherwise it all is pretty senseless, no?
Jan
I think I read somewhere that bowed strings tend to produce triangular waves?
Yes, the violin has stick-slip behavior, making a rough sort of triangle.
Well shouting doesn't help, really.
OK, so another content-free statement from you. Are you going to come up with anything factual or should I give up trying?
Hint: What are the 'speculative assumptions' ABX boxes rely upon? Which are the scientific controls that the ABX box should support but isn't? How then should we validate that we are truly comparing etc.? I mean you MUST have SOME idea of what you mean??
Jan
Perhaps something is getting lost in the translation. I point out the common canard used to defend ABX boxes - which is exactly what you use :Yotherwise it all is pretty senseless, no?
Agreed! Such is NOT the problem with them. The problem lies elsewhere.
OK, agreed. Although you should be surprised how often that is the first argument that pops up.
jan
There are quite a few types of documented distortion, and some that appear to be smoke screens. I read in a well documented technical journal that transient intermodulation distortion (more appropriately called "transitory" intermodulation distortion, ie TID) was in fact the direct result of slew limiting, and that it was impossible for it to exist in modern audio electronics. SID itself is not a distortion but a precurser to TID and a couple others. Apparently it was discovered in the 50's and helped with radio communication design.It matters to some people. There are so many distortion mechanisms they are not all discovered, codified, or measured. I truly believe hard rock and rap musicians LOVE to listen to distortion. I personally have my list of dislikes: ODD HARMONIC DISTORTION (3, 5,7,9th to infinitum). TIM (Transient Intermodulation Distortion) SID (Slew Induced Distortion). Personally IMHO even harmonic distortion more than ..5% behaves almost like an enhancement to music, a sound elixer of euphony. Poorly designed room cause harmonic ringing and standing wave pertubations. The list is endless. GRH
20 Years later, a group of audio gear designers tried to say they discovered it, renamed it TIM, and of all things blamed it on high feedback. But, their paper was found to be faulted and contrived and was not accepted outside of audio publications. Later, a paper came forward that explained why the TIM article was wrong. In more recent years even Rod Elliot says that he's seen no evidence of this TIM distortion in wide bandwidth designs with low compensation and high feedback. I found it funny that the audio magazines capitalized on distortion that doesn't manifest outside of a boombox or computer speaker systems.
Joined 2009
You build an amplifier and it sounds good, you are happy. Then you build one with lower distortion and in most cases you feel it sounds better. If you hadn't the 2nd amplifier to compare with, you would have been happy with the first one. Often it's harder to perceive an improvement when you 'go up the quality scale' but easier when you drop back down it.
I think that's correct. Ever since Matti Otala made us aware of this, designers have understood the root cause of slew limiting and, helped with better/faster output devices that required less drastic compensation caps, routinely design amp that do not show slew rate limiting.
Jan
Jan
Here's the kicker- Otala actually wasn't the first person to identify the level of feedback had nothing to do with the slew rate limiting. In the 60's, Japanese designers were aware of miller pole compensation inducing the slewing effect prior to the first TIM publish date. One of the biggest follies of the TIM articles was, again, that they were laying claim to an already-discovered distortion that was documented and understood 20 years earlier by Roddam and Japanese engineers, called TID.
There was no internet in the 1970's, but I would have thought that Otala and Curl would have had to put their TIM paper through a screening peer review.
End of the 60-ies I was playing with ack-ack guns; I knew of the slew rate limiting trying to fast rotate a few tons of steel to keep up with a crossing aircraft 😉
Later we were promoted to SA missiles on mobile launchers - same SR limiting stuff again.
Jan
Jan
- Member Areas
- The Lounge
- Is distortion really a problem for music reproduction ?
