Now would you care to discuss the difference between charge propagation and electron drift?
This is your key problem. There is no charge propagation in this context.
Thought experiment 2, A signal generator has two terminals i.e. it completes a circuit. When, for instance, it outputs a 100ns pulse current goes out the output and exactly the same current returns through the common for 100ns. There IS NO CHARGE transfered to the system.
I suppose this could all be a put on, good for you.
Of course, I was measuring a Tantalum cap.
And apparently measuring them without a bias voltage. Were the cap measurements Scott mentioned of tantalum caps measured without any bias voltage? Who on earth would use an non-biased polar cap for passing audio?
Again, my point was that it was rather disingenuous of you to do such a thing in response to his post.
se
se
As incredulous as it seems, it appears that a lot of companies still do this. A polar coupling cap between opamps, for example.... no bias on them. I have schematic of a new product ( selling for about $800-1000 USD) of well known name that does this.
-RM
tubes
