Funniest snake oil theories
Return current will take all available paths.
Return current will travel based on the impedance of the path.
If there are two paths of equal impedance, the current will split 50-50.
If one path has an order of magnitude lower impedance, the current will split accordingly. For example, if one has 10 milliohms and one has 100, the lower impedance will carry ten times the current of the higher.
This is bog standard stuff.
jn
Max, you aren't meaning polarity (like swapping, say, read and green wires inside a tonearm) when you say "direction" are you? Otherwise, do you really rewire your tonearm, pulling cables out and then pulling the other end through to find out which "direction" is right for each cable?
Just wondering...
Hello John.
The centre image shifts sideways a little, not major, but enough to be apparent.
Very much like center image shift when fine adjusting tape machine head azimuth.
Me standing back, remaining in the same position while the store owner/repairs customer/friend swapped the direction of one CDP to integrated amp interconnect.
The interconnect was decent quality (nothing super special) coaxial construction.
Probably two wire mains CDP, probably but not certain, 2 wire mains supply amplifier....decent typical hifi gear of mid eighties.
The thing is I picked this fault in my TT that I had wired with reversed cables.
Mono switch on amplifier centered image.
Balance control did not center image imbalance.
Stereo/Rev switch on amp reversed center image imbalance.
Swapping phono RCA's at amp input reversed center image imbalance.
Swapping channel connections at phono cartridge (V15 mkIII) did not reverse center image imbalance.
IOW, I tore my hair out trying to find the center balance fault.
Once the effect was demonstrated to me in the store, I immediately swapped the direction of one of the hardwired phone cables, and this cured the problem that had baffled me.
I dismissed the cable to be the cause of the fault because, well, it was originally the one length of cable, and the books told me that directional effect was not possible.
Keep in mind that I used to service a lot of tape machines, and so I am very aware of/sensitive to mono signal minor L/R phase imbalance.
Nowadays, I don't lose any sleep over it, I just ensure that L & R cables are installed in the same direction.
Dan.
jn
Agreed, however it takes all available paths, not just the lowest resistance path.
jn
missing some pretty fundamental basics here.
One second there's a discussion about inductance the next impedance... I'm not seeing a demonstration of basic understanding in the above quotes.
Something ironic about the direction this thread has taken.
Just wondering...
No, I mean direction.
You missed an earlier post by me.
I hardwired RCA cables to the TT mech termination block.
I started with 2m of shielded cable, stripped both ends, soldered these ends to the TT, cut the cable at the midpoint and fitted RCA plugs.
This is how I caused one channel to be reverse direction wrt the other channel.
This was my error, and caused the center shift.
Removing one cable, reversing direction and refitting cured the fault.
I learned a big lesson from that.
Dan.
No, unless I'm taking him the wrong way, I think he's spot on. JN said return current will take "the path of lowest impedance." Taking that literally, one might conclude that it means return current will take the lowest impedance path to the exclusion of all other possible paths that are of a higher impedance. Seems to me that Brian was just providing a bit of clarification is all.
se
In my gallery is this:
Signal current which flows through the IC core has to get back to the source. It has two paths in this pic, through the shield, and through the line cord.
DC, the line cord is a better path.
RF, the IC is the better path.
Within the audio range, it is frequency dependent, simple model in the pic.
jn
So, it could be useful to fit an inductance in series with the safety earth in order to keep audio return currents on the audio cable shields ?.
Dan.
Dan, with your clip on experiment, did you try 2 separate clip ons, one on each channel, in the same relative positions? IOW, was there an equivalent, or different effect to just using one?
Also, with the central mono behaviour, do you have that central image follow you when you move side to side in front of the speakers?
se
Yes, Steve gets it.
His idea of removing frequency response and dynamic range to deem poor recordings playable and alive is just nonsense. AM broadcast quality sound is not lifelike.
No amount of snake oil or tweaking will make bad recordings good. Removing the resolution from a system does not make it sound better. It is just the audio equivalent of feeding a 1080HD screen with 300 scan rate standard video and hoping it won't look grainy.
When did I say I reduced FR and dynamic range? Subjectively, the complete opposite occurs - the recording has more sparkle and life because the upper frequencies, poor that they may be, come through cleaner - and the perceived impact of dynamic swings is much greater, in part because you can, and in fact want to, run the replay at much higher levels.
The real reason that this works, which people keep wanting to ignore, is that when the ear/brain gets enough clean material to deal with, the key information about the actual musical performance - then the signal processing ability of the brain kicks in at a much higher performance level and does the separating of the wheat from the chaff, quite unconsciously ...
Ok, so now here is your chance to explain what you are doing to achieve this, specifically. If not, then you are just solidifying troll status.
Someone light a match, please?
Really?
Source for this? Any research whatsoever that corroborates this claim?
Which part of the signal processing ability shows improved performance?
How does the brain separate "wheat from chaff"? How does it know, for example, that the sound of a cymbal (wheat) is not more (or less) sibilant because of recording "chaff"? Especially in a previously unheard recording?
Interestingly, I only realised this over the last couple of years, while reading people's comments, experiences and ideas in forums and such. Before this, I knew subjectively what happened, but hadn't understood what and why it was happening - in a process known as "reading between the lines", 😉, what several people said was known about human hearing suddenly switched on the lightbulb, and it all made sense - and everything I read following only served to confirm the idea.
Using the example of a cymbal, the key aspect is that the brain "wants" to make sense of what it listens to, it has an innate desire to hear "well". And this it can do if the sounds it hears can be separated, mentally. Think of a poor recording of cymbals as the pure, uncontaminated tones of the instrument mixed with a parallel track of 'mush'; if the playback is insufficient, then the mental separation can't take place - in real life, listening to a real cymbal, with severe, messy background noise, the tones of the cymbal cuts through the 'interference' without effort, you won't mistake the sound for a "poor recording", 🙂. And that's how the replay comes across when the system is working well enough.
I knew I was onto something when I first put on, years ago, what had been before a very ordinary, busy pop recording with strong cymbal content, and the cymbals came to life!! Powerful, intense, they had the impact of the real thing - I fell off my proverbial chair ... and never looked back ... 😉
A couple of articles with some pretty pictures of return current paths...what is missing to an extent if references to the path of least capacitance (maybe a better term would be capacitive coupling) that comes into play when trying to protect against air borne and conducted rf pollution.
http://www.emcs.org/acstrial/newsletters/fall08/tips.pdf
http://www.oocities.org/timfoo6143/Path_of_least_L_Singapore.pdf
An here it is in a more practical example with some op-amps...
http://www.analog.com/static/import...14948960492698455131755584673020828AN_345.pdf
Two works well, a single one on both cables further improves the center imaging and overall imaging.
Imagine the central source as a thin vertically oriented sheet extending backwards from between the two loudspeakers (and forward also actually according to programme content, mic techniques and recording space..3D is well possible, but another subject for now.).
Turning a balance control will shift this sheet sideways but still remaining at 90*.
A reversed cable slightly sort of rotates the sheet about the vertical axis.
Difficult to explain, but once heard you won't forget it.
If you have an old tape deck, try tweaking the PB head azimuth adjustment screw.
Ignoring any rec/pb channel/channel level differences, listen for image shifting L and R as you adjust the azimuth screw...at optimal azimuth the central image sits right, and the whole stereo image snaps into place.
Find the optimal point, and then tweak slightly either side of optimal and you should hear what I am describing.
Dan.
se
I was refering to thinking of impedance as a flat resistance rather than a reactance, the discussion previous to that seemed to be taking both resistance and reaxtance into acount, while these didn't
