Funniest snake oil theories
How so there is a change to the vessel wood from aluminum 2. change the rubber to bee's wax and 3. adding a layer of dielectric rice paper. I am not saying it is an improvement from the original but rather 3 real changes to the make up of the cap . The wood in the cap is hygroscopic as is the rice paper even if it is sealed after building it still has water in its make up . The snake oil comes in if this is done any where outside of desert with humidity above 10%.
And if he is using those caps for filtering any serious current, good luck with the heat dissipation!!
Since You Asked...
How does the entire image shift sideways, and how do you know it wasn't your head position?
Hello John.
The centre image shifts sideways a little, not major, but enough to be apparent.
Very much like center image shift when fine adjusting tape machine head azimuth.
What level of control was used in swapping cables?
Me standing back, remaining in the same position while the store owner/repairs customer/friend swapped the direction of one CDP to integrated amp interconnect.
How were the source return currents controlled, or was 80% of the return current via the grounding conductors?
The interconnect was decent quality (nothing super special) coaxial construction.
Probably two wire mains CDP, probably but not certain, 2 wire mains supply amplifier....decent typical hifi gear of mid eighties.
There are far too many uncontrolled factors here to determine if directionality existed.
The thing is I picked this fault in my TT that I had wired with reversed cables.
Mono switch on amplifier centered image.
Balance control did not center image imbalance.
Stereo/Rev switch on amp reversed center image imbalance.
Swapping phono RCA's at amp input reversed center image imbalance.
Swapping channel connections at phono cartridge (V15 mkIII) did not reverse center image imbalance.
IOW, I tore my hair out trying to find the center balance fault.
Once the effect was demonstrated to me in the store, I immediately swapped the direction of one of the hardwired phone cables, and this cured the problem that had baffled me.
I dismissed the cable to be the cause of the fault because, well, it was originally the one length of cable, and the books told me that directional effect was not possible.
Keep in mind that I used to service a lot of tape machines, and so I am very aware of/sensitive to mono signal minor L/R phase imbalance.
Nowadays, I don't lose any sleep over it, I just ensure that L & R cables are installed in the same direction.
Dan.
If one's only criterion is that it be different then of course you will spend until eternity chasing your tail ...
If you tinker with your system then one of several things can happen:
1) No apparent change takes place
2) You hear more "detail" but it's exaggerated, somewhat 'shouty' - unpleasant in the long term - Dan's "false detail"
3) Becomes "nicer" because "detail" is discarded- you hear less of the unpleasant stuff because a good, thick, syrupy goo has rounded off all those rough edges
4) You hear more of what is in the recording, and it is easier to listen to a specific part of the structure of the sound - you can tune in, focus on what a particular musician or sound element is doing, understand the contribution of that to the overall sound - and do this with ease, without feeling stressed or becoming fatigued
Personally, I enjoy the last way - and so I refine my system to achieve that. And, it appears to work even with what are technically poor quality recordings ...
Total agreement with you there Frank....I have been through all the steps you list, and 4) is when a system is getting good.
5) Is when you have, 4) plus nice musicality...anything sounds good with all the depth and detail you could ever want, and pretty much any recording sounds plain enjoyable (musical content/tastes dependent of course).
Dan.
Hello John.
The center image is fixed by your head location. That cannot be discerned by humans. What you may have done is discern the images off center, and assuemd it was the center that moved instead of the side images.
The problem with single ended IC's and 3 prong line cords, is that based on the overall loop resistance totals, the return currents of the IC's will flow on the line cord grounding conductors instead of the shields of the IC's. The actual ratio will depend on the contact resistances of the rca's, the IEC's, the wall outlet, as well as the gauge of the line cord ground and the IC shields. In addition, the loop of the line cords to IC's will impact it as well.
Instead of metallic conductor directionality (which doesn't exist), I'd worry about all the real phenomena which most designers ignore. That is, control of signal current paths.
jn
Measuring is a bit like schrodinger's cat, when you measure the problem isn't there, its like blind testing, the difference disappears in a blind test, this is well know to certain factions of Audiophiles, a fact I discovered when visiting another forum, where mentioning measurements, DBTs or engineering would get you instantly banned ( a narrow minded view on the universe, that showed their collective ignorance).
Of course you could try solution 9...
Learn the required engineering discipline and do the job properly, instead of airy fairy views and possible causes that are not investigated properly or put down to strange phenomena that only affects audio equipment.
Maybe we should develop a Maxwells demon detector, and measure the concentration of said demons in a particular piece of equipment of cable, where they seem to prefer to congregate.
Indeed, I found a whole colony of them in my amplifiers, I trapped them in my directional cables then drainwd them into my time harvester. Now my hifi sounds better than ever.
Sorry, I meant on difference in cable or routing lengths on PCBs.
Don't know...according to theory, signal path lengths would have to be substantially different to produce perceived pan pot type center image shift.
That said, I have always been suspicious of typical integrated amplifier layout and wiring.
Indeed, I am yet to hear such an amp deliver precise center mono.
I have always strived to make signal paths identical....cable lengths and dual mono constructions.
Dan.
Giving the signal return path the same consideration as the signal itself is the way, I think of all signals as a differential pair when doing layout cabling etc, its the best way, and often overlooked or forgotten about.
Dan, I agree with symmetry, if for no other reason that it would drive me insane, having different cable lengths (slight OCD🙂).
Dan, you must have done some head-scratching on this - what's your best guess on what's going on?
I'm thinking that VLF/infra channel to channel noise coherency is part of it.
In my experimenting with my cable clip on thingo, putting both channels through the one clip on makes central mono programme content perfectly central, zero width of the central mono content, and zero wander.
Only speculation for now until I get to making some repeatable measurements.
Dan.
Yes, send and return paths need to be minimal loop area.
Earth planes are more complex than first inspection.
Dan.
I'm thinking that channel to channel noise coherency is part of it.
Dan.
Don't worry about channel to channel noise coherency. Instead, worry about channel to channel difference with a mono source.
Measurements channel to channel from the speaker outs is going to require some major work. You're looking for tenth db differences and below with 5 uSec level interchannel timing delays, and you won't get that with speaker loads as well..they will confound the measurement.
Identical dummy loads, two differential inputs, analog subtraction, and accuracy out the wazoo. Your looking for microsecond changes in 500 hz to 2khz.. tain't gonna be easy.
jn
