Funniest snake oil theories
The largest gains are those obtained from knowing how to address the room/speaker interface and what is causing any sound defects.
IME the room/speaker interface is not relevant - from my perspective it's equivalent to saying that a real piano won't sound right unless it's placed in precisely the right position in the room ...
Yes, knowing what is causing the sound defects is key - which is what I address, and it turns out to be nearly all electrical in origin.
Thanks for that rundown, tvrgeek. Especially interesting about the gold plating issues, I hadn't seen it explained as such before - I definitely found that the typical audio gold connectors useless for maintaining integrity.
Petroleum jelly I have tried, several times, but for whatever reason it has not worked for me - in audio at least. Very high pressure, engineered connectors appeals strongly to me - if anyone can recommend some existing system out there, most likely not in audio, I would be interested in knowing about it ...
Credit where due; I took a week long class on "connectivity" from AMP. They went from intra-die up every link in the chain. Imagine a surface. A speck of gold bonds to it. Then another spec. They build up in a porous stack of grains as the slowly cover the surface. Thick enough, they plug the pores.
It was a Bell Labs engineer who said the red gel was basically Vaseline.
I saw one "decent" connector in an EDN about 20 years ago. It was a stack of kapton flex-circuits that were compressed by a plates and a through bolt. It was designed for fighter aircraft. Plain old barrier strips are darn good for speaker cables. Far better than binding posts or any exotic banana plug. You can take a solid wire off a plain old wall plug after 50 years and the copper is still shiny under the screw. Bare copper on bare brass with lots of force. Wire wrap would nick the wire on every corner and those tiny spots were air-tight.
We used to have a saying in the lab. "No such thing as a good connector" I wish I had a wonderful solution for everyone, but I don't. It does leave me with not chasing things I know are not significant in our application, even if theory says the parameter exists on some scale. That leaves me to concentrate on the 90% problem. Speakers.
The trouble is, 'I know' it is significant - because everytime I do something to fix it, the sound improves. Being a rational sort of guy, I therefore repeat the 'medicine' at every opportunity ... 😀
When I read that I thought someone was taking the p***. Didnt realise whose post it was!
There must be something vastly wrong with your system if you can manage to perform so many improvements.
Next you're gonna tell us you predominantly listen to pink .... noise. You know, to keep your ears calibrated or something.
almost there
Bad connections do pass the pauseable physics test for audible problems in the audio chain. Cable directionality carrying AC does not. Grain structure and micro-diodes are valid theories in the lab, but even less valid in the real world than skin effect. They serve only as foundation to the best lie, one based on a grain (sorry) of truth.
Lets look at bad connections so we can separate physics from snake oil:
Poor metal to metal contact is most frequently caused by fretting corrosion. I am sure everyone has re-seated a connection and had a problem go away.
It is common belief that if you have gold plated connectors, you don't get any oxide. That would be true if the thickness of the gold (both halves) was sufficiently thick as not to have any micro-pours. Well, bad news is typical plating is about 5 times too thin. This allows the oxidation of the substrate, tin/nickel/copper to bleed through the pores. Micro fretting (vibration) causes these oxides to ball-up, actually lifting the contact points apart with insulating oxides. Re-seating the connector wipes these away for a time.
This is not difficult to prevent. All you must do is prevent any oxygen from getting into the connection. I know three ways; solder/weld, extreme high force, or as the phone and automotive companies figured out 40 years ago, petroleum jelly in the connector.
Neither high pressure or grease enjoys wide spread application in hi-fi as far as I can tell. Carmoline was about as close as we got. Screw terminal blocks were pretty close to high pressure when we were smart enough to use them for speakers. I do note, in most micro 20 turn pots that are sealed have grease over the contact strip. Jump into your WAYBACK machine to the days of TV tuners, and we routinely hosed down the tuner contacts with Blue Stuff. When I built my TVR electrical system, I used Packard Weather-Pak connectors and made sure both the crimps and the pins were well covered in grease. This allowed me to completely banish "Lucas, the prince of darkness" from the car. Ironic, the Lucas bullet connectors were a very good design had they been greased.
Did you pick up that detail? The crimp inside the connector matters too.
PS: Actually, soldering has it's own long term problems For practical sake, a good solder joint will outlast the electrolytic caps, so it is not a problem within design life-cycle of consumer audio. I will let others here who have deeper expertise in that subject comment further if they wish.
While this is sort of what occurs, some of the details are incorrect. The "oxides" are not the problem "balling up" with gold plating under 100 uinch 2.5 microns";
rather, it is that the copper substrate, if there is no nickel or palladium, etc. diffusion barrier migrates through the micropores and then contaminates and oxidizes on the surface, exposing the micro-asperities as the primary contact points (the surface topography of the substrate is of prime importance here, hence the use of electropolishing for really critical applications)
This is a well established and resolved problem in engineering, radio wave astronomy, contact issues, etc.
The real problem is really bad plating, usual commercial coatings are, at most, 1/10 the required thickness (1/4u or less due to cost) and often w/o a diffusion barrier, hence the above problems.
I didn't take a week long course, I did this in the radio/microwave/aerospace industry for 4 decades, and helped determine many of the mil spec details
here are some typical data for precision work; you'll never see this on most audio gear though... waayy too expensive
http://www.ultraplating.com/specs.pdf
John L.
And as always, things like wire directionality having an audible effect on an audio system: only a double blind test can prove that it exists. By the way, James Randi is offering up a $1,000,000 prize if anybody can prove in a double blind test that a $7250 speaker cable is actually better than Monster Cables. Why hasn't anybody gone and claimed the money yet?
Because that cable may alter the frequency response a bit, turning an extraordinary claim into a mundane one.
We actually set up a blind test on wire directionality with a very vocal guy who claimed that it was trivially easy to hear. When it came time to actually do the test (he was sent cables with the directionality randomized for him to sort), he backed out of it. Steve Eddy will remember this very well. 😀
There will always be some who don't want issues in contention obfuscated with facts. : )
You're talking (writing) to an anomaly.
Best to regard it as an internet bot, with autonomous and interactive functions.
It's triggered by rational respond posts, for which the bot has algorithms which combine interesting sounding words to long sentences, but without factual meaning.
After a preset time has passed without a reaction, it returns to its default setting and posts a repeat message to trigger new candidates into responding.
The more you respond, the more active it becomes.
Indeed. And the other participant in the test said he couldn't hear any differences with the test wire he was sent.
se
