CFA Topology Audio Amplifiers
You choice, in my book this is useless and dangerous, from a stability perspective.
I know about a theoretical improvement when matching the speaker Qts/Qes, but that would be exactly valid for a particular speaker only.
You can use a higher absolute value of output negative resistance than that to improve the electrical damping of the loudspeaker. However the problem which arises is that voice coil inductance Le is going to have a peaky resonance with capacitor Ces of the motional impedance. Le can be compensated but only partly due to its non constant value with frequency and inside the gap. This is the main problem in servo drivers based on a bridge to sense the velocity of the cone.
Petr1951 said:
Amplifier without GNFB and negative output impedance does not need patching cables and acoustic elements crossovers due to the influence Back EMF. He compensates them .
The aim of global negative feedback of an amplifier is to maintain its output voltage independent of its load even if this load acts as an Electromotive Force generator. Remember that in a loudspeaker, the (Back-)EMF always in series with voice coil resistance Re.
Back-EMF is not a problem for a GNFB amplifier.
Waly! in your book, it is useless and dangerous, and in my experience it is very useful and safe. Repeat this all very pleased with the sound of power and no one complains about the instability of work. In my country, the firm was lounging on manufacturing speakers and amplifiers. After fabrication the amplifier of my circuits the company revived again. Improvements do not depend on the speakers. Tested with different types: horn, closed, labirinth (mazes) and other acoustic design.
Do I need to ask for evidence/data first? Or can I conclude, right away, this is subjective crapola.
company performance can be objectively tracked - sales numbers, revenue, margins
relation to technical performance in high end audio may be weak...
Halcro's commercial sucess certainly argues for the high weighting of artistic visual design and skillful marketing - while "the story" includes the obligitory claim of unusually acute hearing and dissatifiaction of all that came before its pretty clear that sub ppm distortion # are the result of strictly measurement driven engineering
another story i've heard several times is of someone losing money dielivering high performance at modest pricing deliberately and openly making the decision to shift to the hi end "nose bleed" pricing audiophile market - with the requisite exotic components and weighty custom milled aluminum plate enclosure and becoming a commercial sucess - these people may have electronic design elements in their marketing story but never seemed to indicate that there was ever any engineering risk in producing the actual amplifier circuit that would be accepted in the hi end market
Linn is only one more example - of how many K$ can be charged for a chip amp in a sexy enclosure - one more "the price is the point" marketing sucess
combining this evidence with double blind thresholds, Carver's Stereophile challenge and the well known loudness preference and the power of the expectaion effect I find it strange that there is such a strong belief in the very concept of an "ultimate" amp - it certainly seems likely that amplifiers that have matching frequency and output impedance response with no obvious defects are indistinguisable - certainly invisible compared with loudspeakers
...Halcro has closed - so the combo of tech specs And visual impact/"story" didn't seem to survive the currents of Fashion - are we supposed to take a lesson on the audible character of error correction amps from this?
yes one of the condtions for "all amplifiers sound alike" is linear operation - within respective design limits, approrate signal and load combos
and yes there are unreasonable signals and loads - and they can be designed for if you want to spend the money
you could make a case for "audio taste" in clipping, rail collapse, output protection...
but so far those arguments haven't been put to the front in this thread - the main claim seems be CFA is distiguishible from VFA in linear operation, both designed to work with below -80 dB distortion
Waly (4323)
Dear Waly! I in no way not going to dispute your personal opinion of your book about the harm of negative impedance for audio amplifiers.
Number of people make my amplifier is growing every day. And growing number of enthusiastic reviews. And your opinion will remain your personal opinion.
Speaker impedance conductors allowing the skin effect and proximity effect conductors is about 0.2 ohms. Throw resistance inductance crossover. This is roughly the same 0.2 ohms. Here you are almost 0.4 Ohm which additionally between the amplifier and speaker system.
Negative output impedance compensates the distortion caused by the response (back EMF) due to the voltage drop across the speaker wires and crossover elements
Best regards
Petr
jcx (4325)
VAS distortion without NFB can be reduced to 0.00003% (-130dB)!!! using VAS-clone (backup)
For this it is necessary to bring the output voltage VAS-clone of the input voltage and to subtract it from the input voltage. The error signal is used as the predistortion signal in the main channel VAS and thus minimizes the distortion. This mechanism acts much more efficient than traditional NFB.
http://s020.radikal.ru/i715/1401/6d/f52c6e5786c1.png
best regards
Petr
All who are interested in the problem I described with THD at amp vs at speaker end of 20 feet of zip cord......combined with motional feedback and the like -- Buy the book by Esa Merilainen. Current-Driving of Loudspeakers. Eliminating Major Distortion and interference Effects by the Physically Correct Operation method. 340 pages. Yr 2010.
Thx-RNMarsh
RNMarsh (4328)
it all started here with this publication:
Distortion Reduction in Moving-CoilLoudspeaker Systems Using Current-Drive Technology*
P. G. L. MILLS** AND M. O. J. HAWKSFORD
University of Essex, Wivenhoe Park, Colchester, Essex, C04 3SQ, UK
J.AudioEng.Soc.,Vol_.37,No.3,1989 March
This has been a long way, and many have realized that it is a dead-end destination
best regards
Petr
RNMarsh,
Following your post in the Blowtorch thread I found this note by the author you mentioned for current drive for loudspeakers. Perhaps this is one of the things that answers some of the question about why some prefer the cfa over the vfa topology? I got this from EDN Network. This was a comment to another person following an article about the current driven loudspeaker.
Loudspeaker operation: The superiority of current drive over voltage drive | EDN
Esa Merilainen
In current-output (transconductance) amplifiers, the feedback represents the current flowing through the load and thus increases the output impedance while reducing distortion similarly as with voltage feedback. The two forms of feedback can also be mixed to adjust the output impedance.
Yes, for a given load impedance and signal level, current-drive needs some extra voltage margin especially with highly complex loads; but on the other hand, the peak current demand is correspondingly lower and precisely known.
Applying pure current-drive for existing voltage speakers is not so advisable due to frequency response alteration. Speakers naturally have to be designed for the concept, preferably beginning from the drivers.
The problem is as kindhornman says is no modern speakers are designed for current drive. Most will give really wonky results if current driven.
That's not to say, there are no advantages though they are only available if speaker & amp are designed as a whole. And pure current drive is actually quite a poor way to get these advantages.
I posted this in another forum.
>For what it is worth, I think this is impossible. It seems to violate the cause and effect principle. How could the amplifier "know" what the speaker is up to ? Short of sensing the actual motion of the drivers or the actual sound... this has to be sort of by guess and by golly, it seems to me.
It is entirely possible for an "amplifier" to know what the speaker is doing.
It needs to sense the speaker current. An amp which twiddled its Output Z using both current & voltage feedback does this. Speakers act as accurate microphones (sense the actual sound) if operated into Low Z.
See "Loudspeakers as Microphones" - Peter Baxandall special lecture London AES (early 80s, late 70s?)
If operated into High Z, then the voltage at the terminals is a measure of cone velocity.
Both these mechanisms obey superposition & Thevenin so if you're clever, you can look at this while the amp is giving zillion volts and amps to the speaker. But non est tantum facile.
There are several tried & tested methods of using this "controlled output Z" or "current + voltage feedback" or "actual sound & motion feedback" (different descriptions of the same thing) if you incorporate the amplifier design in the speaker. Some of these are in the zanier incarnations of my Powered Integrated Super Sub technology.
The simplest is the negative output R that Fons mentions.
More sophisticated but similar (??!) is ACE technology by Erik Stahl which was used by Audio Pro, Sweden for subs. Unfortunately, since he left, there isn't anyone there who understands it. Anyone have a contact for Erik? Or a clean copy of his original AES preprint?
These methods have the distortion reduction and dynamic overload protection features discussed in Mills & Hawksford. However, they are badly affected by heating of the voice coil.
David Birt (?) did an excellent IoA paper at Windermere where he arranged speaker and amp in a bridge so he could measure and compensate for heating on the fly. Anyone have an email for him?
These are the most elegant methods and they can be analysed from many viewpoints. Some of these viewpoints don't show up the distortion reduction advantages clearly.
I'm contemptous of methods which rely on extra transducers or extra windings (like Mills) or zillion point DSP EQ especially if they don't give ALL the advantages of the elegant methods.
A brute force zillion point approach possible today is measure accurately speaker Z (not that easy) and tailor the output of a High Z amp to suit. This would give some but not all the advantages of the above systems cos it wouldn't "know" what the speaker is up to.
In fact, I (or anyone else) dunno know how to design dynamic speakers for good performance with current drive. Rice & Kellog, who invented the speaker as we know it, had much more insight than the Thiele-Small pseudo gurus today.
But it is theoretically possible to design an electrostatic speaker for good performance with current drive.
___________________________
As a speaker designer, I expect my speakers to be used with high quality cables and flat response 0R impedance amps. I hate it when unwashed amp designers try to 'improve' on my designs. Petri's negative 0R2 is probably innocuous. The 1R presented by many tube amps is starting to get dodgy.
BTW, Carver's successful Stereophile Challenge proved 2 things .. not one.
  • it is possible to hear differences between amps that might lead to a preference.
  • it is possible for one versed in the art to replicate these preferred differences with entirely different technology & topology. With respect to Mr. Cordell, I don't think anyone on this forum is sufficiently versed 😱
ALL. Please don't indulge in more "Yus guys are all idiots & deaf" exchanges with those who persist. Just report them to the moderators. 🙂
Let's stick with the CFA stuff guys.
Should I open up a current drive loudspeaker thread? ( remember,that's how this one started as well! )
I fear you should, there seems to be far too many people here who don't understand the difference between CFA amps and amps with a high output impedance (current drive).
I was foolish enough to buy the Finn's book on current driving of speakers. 10% sense culled from Malcolm Hawksford's work, + 90% nonsense, comprising pseudo-science, poor-quality amplifier designs, and ranting!
(I donated the useless book to the local Oxfam charity shop)
Because, formely, the amps called CFAs were those where it was the output current which was the value controlled by the feedback.
As CFA now means an amp with a low impedance inverting input, how do you call the concept underlying in the initial term ?
I was foolish enough to buy the Finn's book on current driving of speakers. 10% sense culled from Malcolm Hawksford's work, + 90% nonsense, comprising pseudo-science, poor-quality amplifier designs, and ranting! (I donated the useless book to the local Oxfam charity shop)
It would be interesting to see you detailing your arguments against Merilainen's book in the new thread opened by Bonsai :
http://www.diyaudio.com/forums/solid-state/250272-current-drive-loudspeakers.html#post3798772
...worth further, more structured, detailed inquiry. At which time I know a PHD in statistics... whom i can ask for help or answers.
First rule of statistics is to ask the statistician first.😉 Then you know what data you need.
Waste of your time to collect lots of worthless data and then a waste of the statistician's time to try to extract information that isn't in the data.
If it looks like there is a pattern, he can see if it is real or not.
A pattern is already obvious. xFA believers report that xFAs sound better, when they know what "should" sound better. That is almost certainly a real pattern.
What would be useful is the answer to a different question.
If your statistician can see the true answer to that then please post his analysis, I'd love to learn his methods.
but at a meta-data level of thousands...
I don't know where you will obtain your "thousands" from.
Meta-analysis is essentially confined to data, usually peer reviewed, that is not "stacked".
I have not yet seen even one audibility test here that meets the basic minimum to qualify for a competent journal, but I live in hope.
Best wishes
David
I would say that such an amp had "Current-derived voltage feedback"
Yes, lot of confusion here about CFA = current drive output or CFA must be a VFA (mixing internal amplifier topology up with canonical feedback topology)
But, let's leave it at that least we sink once again into a long worthless exchange.
I agree. Many times people take things and go off on a tangent with it. I thought it would be obvious that as we are designing amps here and CFA in particualr, that the amp must interface with the load in the best way - which means lowest distortion. Is this the best way to get lowest distortion thru the System?
Might make a good new thread to develop amps which interface better for best over-all results. Rather than amps which just measure well in isolation without real world I/O conditions.
So back to CFA --- lets try various simi-real speaker loads also with the SIM's and see what develops. Several models of speakers exist which can be used and whole XO/Spkr circuits can be used. I have a pair of new Quads .. how does the OPS we have developed so far with CFA handle that load? Others? Is there a universal OPS that keeps distortion at its lowest with any and all speaker and XO types? Or are there two... one for electrostatics and one for dynamic loads? And, are the SOA protection different?
Thx-RNMarsh
only a 100 pages to loop back again, again
and loading on all of the traditional silliness as not applying to CFA
do we really have to reprise all of the ca 1980 JAES findings re Otala and fanboys "suspicions" which have been proved conceptually flawed or irrelevantly low, easy to overcome without his tweak recommendations?
The output impedance “interface distortion” comments should make any competent engineer blush – Cordell, Self “textbook” audio amp theory and measurements, JAES articles by Cherry, et al
look on Klippel's site if you are serious about bounding dynamic speaker electrical terminal nonlinearities
but you also need to tighten up your reasoning about said speaker impedance distortion and which type amps reject it better
almost everything about an amplifier's output at audio frequencies into complex speaker loads can be seen with a "tug-of-war" test - a (bigger) amp on the other end of a power R load - driven with phase shifted test signal
you can also drive the other end of the power R with different frequencies, multi-tones, emulate nonlinear loads
