Analogue Metric Shunt Reg problem
I have built the Analog Metric SR50 variable shunt regulator.
I need 12v and 5v output which I can get when under no load, but if I connect a 5R dummy load to the output it drops down to 2.1v for the 12v one and 1.9v on the 5v version.
Where have I gone wrong or is there a problem with the circuit ?
Many thanks, Alex.
  • SR50 Shunt Regulator.pdf
I will try to change the jumper wire for R1 and use 1R or 10R and measure there what's happen with the current, also you can play using a lighter dummy load, that's only to know if goes ok with other requirements.
Are you sure shunt regulator can support 2A or 1.5A?
I did put a 3.3R on the 5v one and 10R on the 12v one to limit the current then took them out when I could not get any more than 2v out.
The transistors are rated at 6A so should be OK.
Can some kind sole give me a bit of an explanation how the circuit works especially Q1.
It is supposed to be adjustable from 5-50v and a max current of 8A.
The adjustment is after Q1 and 2 so I am a bit lost as to where do I start trouble shooting.
I am not an electronic engineer but have a good grasp of basic electronics and know how to use a multimeter and scope.
The AC transformer is 2 off 15v 100VA and I want to have 12v 2A and 5v 1A.
Many thanks, Alex.
