E180F V EF184
Hi
I have a little headphone amp running Mullard EF80's or EF184 (much quieter).
Last night I found a nice pair of E180F tubes in my stock, would these be a straight swap 😕seems the only pin out difference is that the screen is connected to Grid 3, all other specs seem close.
Any thoughts would be great, as I would like to build another as a preamp and have heard the E180F is a good choice😕
Cheers
Thanks for the link
Sorry, I must have not been clear?
I have had a look at the datasheet and noticed that the screen on the E180F is connected to Grid 3 ( pin 8 ) and wondered if it will work instead of a EF184? the EF184 has the screen on pin 6. Can these be swapped over???
Cheers 🙂
You can't directly replace EF184 with E180F, whithout rewiring the screen connection. -pin 9 from EF184 to pin 8 from E180F -pin 8 from EF184 to pin 9 from E180F -Cut wire from pin 6 (EF184) to ground, and leave te connection free. By the way, the Russian equivalent to E180F is 6J9P (6ж9п). These are very unexpensive and very good tubes. It's worth a trial.
Hi Blaireau
Thanks for that, It might pay for me to just use these on the preamp rather than trying to mod the headphone amp.
I guess my question was also aimed at the compatibility and people thoughts of the E180F?
I just had a look on Ebay for the 6J9P, your right at only $1.50 USD a piece!! Might try a few.
Cheers
They are the same....., but sounding is some different, I have and I don't like 6J9P /close is 6J11P/.
Alexg, This is my SE 2A3-RCA. Plate resistor E180F now is 13 kohm /not 33 kohm/ and upper
resistor 12 kohm now is 3 kohm/:
https://picasaweb.google.com/109570777566485968551/KVM#5413313827582447474
E180f 6j9p
I have seen many times that use the E180F - 6j5p (Too 6e5p -D3a ) but dont understand how is possible to obtain the 180Vpp of swing voltagge that need for 2a3 - 300b - 6c33 in these tubes the bias are over -70V to -90V
I think that is mandatory to have at less 170vpp ( 200vpp is my target ) and in this case the optimum valves could be EF184 - 6485 - 6j5p - 6ah6
I am upgrading my amp that use 6ac7 driver and 6c33 running at 240v 130ma -90v bias, is why I am studing many tubes. The 6ac7 do 180vpp but the sound is not great.
Opinions and ideas are welcome. 🙂
I have seen many times that use the E180F - 6j5p (Too 6e5p -D3a ) but dont understand how is possible to obtain the 180Vpp of swing voltagge that need for 2a3 - 300b - 6c33 in these tubes the bias are over -70V to -90V...
By using a CCS as anode resistor, it is possible to get more than 200 Vpp with low distortion.
As an example from my memos:
Triode connected 6J9P with CCS and 100k load resistance.
+Ub = 350 V, Ik = 12 mA, Ua = 220 V, Uout 80 Vrms (=226 Vpp), THD = 0,58 %, G = 32 dB
Below is a schematic showing the basic idea of such high voltage driver (but with different tube...)
Here you have the schematic of an amp I built (E180F driving 6C4C) - more see http://www.diyaudio.com/forums/tubes-valves/175429-yagoolars-tube-amp-projects-8.html
What are the operating conditions of your E180F. I can not directly see it from the schematic.
Have you optimized the E180F driver alone for minimum distortion ?
Or have you biased to best overall distortion cancelling (together with the output tube) ?
An inductor load will also allow for greater voltage swing on output of the driver tube.
He has 1.7V bias on the E180F.
There is 1.7V (D106) minus VbeQ1 (0.6V) =1.1V
This is across the two 68R resistors in series for a bias current of about 14.5mA.
Find the intersect of these on the plate curve and yous should find the anode voltage.
Unfortunately I don't have a datasheet with triode strapped curves.
6688 curve is here, and looks like around 140Vak.
http://www.triodeguy.com/Triodeguy PDF files/6688 Triode Curves RFS Measurements.pdf
Measured
Ug1(E180F) = -1.9V
Ua = 145 V
I have not optimised the amp towards minimum distortion. Neither driver nor driver/output tube.
