Want to know availability of TDA 7294 IC ?
It's not available in Jodhpur or Online.
http://www.techenclave.com/community...-1-amp.151052/
Call these people: http://www.vegakitindia.com/ and order on the phone. They will send it C.O.D.
Where can I get plexiglass (acrylic glass) in Mumbai. I'm also looking for Hex spacers for PCB
Hex spacer available from some footpath stalls on the road parallel to the railway track just
outside the Grant Road railway station. I believe plexiglass is available in the Bhuleshwar
area but not sure.
Roushon.
dear all sir
i want rectifier byv 34 .from where i get this in india.thanks
It is available in in.elements14 but very expensive. Try ebay.
Roushon
There is a road in Mumbai that is full of workshops that cater to the needs of the ship repairs. This place might be interesting to visit and find out how it will be useful for DIY purposes.
Gajanan Phadte
Gajanan Phadte
Gajanan Phadte
Yup Heat sinks and Ideas.
If you know the name of the road then please post.
Roushon.
Chromo Paper is not available at Flora Fountain.
How much will a full roll of dry film photoresist cost ?
Roushon.
I have spent a lot of my DIY hours in many scrap yards where ever I went 😀.
Heatsinks,Valves,Motors,cabinets and what not
Sent you a PM. You said chromo paper is available there in very large quantity. May be start a group buy.
Roushon
Not sure if this has been ever posted, but....
Electronic Capacitor, Electronic Capacitor importers, Electronic Capacitor suppliers, Electronic Capacitor distributors
Thanks for the post. Seems to be only for heavy duty products. But do they retail? Suppose I need only four pieces 10000uF 63v. Will it be entertained? And what will be the shipping chrage? If you have dealt with them then please give some details.
Edit: Sorry! Just noticed you are not from India, so you may not have all the local informations.
Roushon.
So,asked around in many shops for chromo paper-they dont have the stuff.
Did another try showing them the paper Roushon kindly sent,i got *some* paper from a shop,but its not good enough for the transfer.Either holds the toner or it simply flakes off.
So that was a dud.
Any chance of getting a paper group buy?I am thinking of now mailing the people on the card Roushon posted.
As of now,i am simply using backing from A4 sticker sheets.My sheets have a plastic coat which occasionally shrink and jam the printer.Now that means a lot of browsing center wallahs refuse to give me layout prints on my plastic-paper and i have to travel 10-12 kms to get printouts.And that too has turned bad of late as the prints are not satisfactory,especially if there are too thick traces or ground planes to print.
Also,What about the photo resist film?
Also,Roushon,about caps,if there are many people interested,could we have a GB for decent ones?
I know its easy to get legit caps,but there will be people who stay quite a bit far from centers like SP road/Lammy/Ritchie st. Or have an issue with fake caps.
Or perhaps we could have something like that nichicon gold cap GB that member Buzzforb conducted.
So that was a dud.
Looking for MJL series complimentary transistor online. e.g MJL4302/4281 pairs or equivalent alternatives.
(For ESP 500 watts amp)
Help please.
Help please.
So that was a dud.
I asked the Mayur Paper in Mumbai if they can ship
paper, they said yes. So you can just call them up. But
there is a problem in this, you are not sure if you are
getting the correct paper until you get it. So, it is best a
group buy. There is always a problem with ground plane
quality even after 100% transfer of the toner to the board:
do not keep the board dipped for long time in the etchant,
or it is better to cover the ground plane area or very thick
tracks with paint over the toner, this is easy. Tracks, pads
etc comes perfect. I just etched some double sided with
SMD, the etchant did eat up some ground plane area as I
could not see whether the etching is complete (being
double sided, blocks light from back) and kept it a bit
longer. But it was good enough.
For caps you can try diycomponents.in. I also do not mind
group buy, but it never materialized here.
Roushon.
I was trying out the toner transfer using Chromo paper.unfortunately the PCB exploded. I am afraid if it is the bad pcb or too much heat.
Fortunately Chromo papers worked perfect it seems .
I am sorry for the accident.
You got it almost correct. I think too much heat or there were air bubbles inside the copper clad board. Sent you a pm with some more instructions. With this paper you can transfer 100% of the toner.
Roushon
Another possibility is that it is paper phenolic board. If yes, try glass epoxy board which I always use and never had any problem.
Roushon
Roushon
Yes it is phenolic board which I am using especially for experiments.
After finding success on phenolic I would move on to expensive and hard to find epoxy boards.
- Design & Build
- Parts
- Parts in Mumbai (India)
