Cal,
I've been looking at the "Now you can" Cornu thread. (made it about 1/3 of the way so far!)
Which drivers did you end up using in your Cornu's?
Ref Post # 244
http://www.diyaudio.com/forums/club...ver-island-diyfest-2013-a-25.html#post3602191
I found some of the Aura 3" / 16 ohm drivers. Did you try that one?
Would a different size or spiral help out different drivers?
Ref Post # 244
1. the little cornu that could!
and
3. Cal's larger Cornu
Hi Dave,
Yes, I tried 6 different 3" including the really cheap and the mid priced Aura's. The LG's came in first and the JVC's came second IMHO. My BIL up in Prince Rupert now uses the midpriced Aura's in his. The small speaker is a spiral, not a Cornu shaped spiral.
The large *** kicking bass units are a Cornu style with the Fostex FF125WK and the full complement of planet10 treatments.
I would not make a regular spiral again as I think the bends in the Cornu horn help to damp the higher frequencies.
thanks for the info Cal.
I think I'll make a pair and use them in my shop space. Looks like a fun build, and the output certainly puts a smile on everyone's face. This could be the biggest "Bang for the buck" speaker project ever. 😀
I think one of the Fostex's that does the high end better might be well suited to this as it really is a bass cabinet when you get to the 27" size.
Yes they are a fun build. The funnest I can remember.
Cheers
Cheers
You know Dave, you might be right. That plus the fact it's one of the lightest speakers of that volume, makes it that much more fun. 🙂
Cal with his Cornus at DIY FEST
I thought this pic fun for both threads-I also posted it to the cornu thread. Pretty sure the drivers are the Fostex FF125WK with Planet10 mods
They had a lot of bass considering driver size, they must be really bass-ful on a wall.
I remember wondering if they would benefit from thicker front and rear baffles. I thought that the baffles were vibrating/radiating. If that is the case, the sound would be different with thicker baffles.
I can see how the 3/8"(9.5mm)"underlayment"(that's right, Cal, isn't it?) baffle material would be dense compared to its foam-core precedents.
To answer Howard, here is the build thread for the Cornu's.
http://www.diyaudio.com/forums/full...k-building-cornu-spiral-horn-now-you-can.html
Relaxed, or just plain tired ?!
It's a ton of work---!
-thanks for the pics.
Don,
We missed you. I was there by myself, surrounded by a bunch of darn Youngsters! It was awful!
Terry: Last minute stuff prevented me😡Don,
I had the multi-vitamins, decaf "sleepy time" tea, aspirin, and Kleenex all packed.
I'll just leave it so it's ready for next year!
Don
Yes, Doorman, Chris was a workin' son of a gun that weekend, as I suspect he is much of the time. For me though, the relaxing that I do when I have been going really hard, is some of the best relaxing I do-and the deepest letting go-as in: ahhhhhhhhhhhhhhhhhhhh!
Terry, you must be feeling old if we all seem like youngsters to you!
3 amiable characters
Terry Eh O, John of the AMP and Mike-whose floor standing three way I regret not hearing(whilst packing up my gear on Sunday morn) Mike, being on the younger and stronger side, was often recruited to do physical tasks, like moving large speakers around. He was always cheerful and willing.
there were way too many speakers to get a chance to hear even half of them - much less remember those I did - which were Mike's?
yes, while never as busy as Dave, that Chris guy was mostly tired from catching up on less than total of 30hrs sleep each of the prior 2 weeks finishing off prototypes and bespoke builds ( he should also find his lost respirator when spraying NC lacquer - that and Russian Standard don't mix all that well 😱)
you all suck!
Happy all had a great time...sniff...sniff...
Mike commented on a pair of Chris' speakers were pretty startling (in a good way). Hmm....
Too bad he didn't haul his revamped Klipsch CF-3's out. From all reports a huge improvements over the stock ones.
Chris asked:
If I got it right, they were tall 3 ways, in unfinished cabs, with the crossover protruding out the back, guarded by a piece of pegboard Masonite. They came in Bob's car.
- Member Areas
- Clubs & Events
- 10th Annual Vancouver Island diyFEST 2013
