220 Mega Ohm Resistor - Really
High meg resistors like this are made by Victoreen and some others. They often come encapsulated in glass but not always because 200 meg is not all that high of a value as far as high megs go. Keithley instruments uses some in their electrometers and picoamp sources. And there're often much higher up in the gigaohm range.
If you have a way of measuring high megohms, you might be able to make one with India ink painted on a short insulated rod. You'll need to experiment with length. The more ink, the lower the value. But India ink is pretty high resistance wise. I did this as a kid for a Geiger counter project in an old magazine artical. This works better for higher resistance around 100K meg. BTW, for your microphone project a tolorance of 1% is totally unnecessary and a waste of money. It's just not critical and you won't hear any difference. 200 megs will work just as well.
Victor
Speedskater said:
"R&D Electronics" also known as Electronic Surplus was down the street from the Victoreen and Keithley factories in Cleveland.
I wonder if that was the place I once visited about 25 years ago while on a trip to the Dayton Hamvention. The owner (?) had dozens of the old Tektronix 500 series plug-ins on a shelf behind the counter. He wouldn't sell any of them because he foolishly thought they would be real valuable some day and was hording them.
Victor
The Ohmite Mini-Mox recommended by kaos are the ones often
used in microphones. Those are the blue ones.
The UM-57 has 2 of these resistors, one to supply the fixed
polarization voltage to the capsule center plate, and the other
as grid leak for the EC92. I'd go with 250M. The value should
not be critical but could influence the LF roll-off slightly.
I'm looking inside a M-582 I have but can't see any high ohm
resistors to see what type they use.
The important thing is to keep the grid circuit away from anything
with high leakage. FR-4 PC boards are too leaky. Polycarbonate
is OK; any plastic that will hold a static charge. I think teflon is
OK also. The grid circuit should also be physically as short as
possible and right under the capsule mount.
Does the UM-57 use an M7 capsule? What capsule are you using?
Sounds like a fun project. They have a lot of DIY mic discussion on
the Prodigy Pro board.
Michael
The K49 is about 80pF/side and I think the M7 must be about the
same.
That's about 50Mohms at 40 Hz, and there are 2 220M resistors in
parallel which results in a 110M/160M voltage divider.
That's a little over -3db at 40 Hz. That sounds about right. The U47
has 100M, the M49 has 2x150M in parallel with about the same
capacitance per capsule side. The C12, which has a similar
polarization scheme to the UM-57, has 2x250M in parallel.
Victor
Probably not, back then there were other surplus shops. This shop had a warehouse for of real nice old test equipment. They have been in business for 50 or 60 years and know the value of all their stock. Cleveland is a 5 hour drive North of Dayton, did you stop in Columbus or Lima?
At Plessey UK resistors over 1meg were banned from designs.
Someone designed a telephone exchange with high value resistors everywhere and it worked fine.
Until, they installed one in a hot damp country and they refused to work.
Plessey had to take the hit for installing air con.
For a lot of SMT PCBs even 1M can be pushing it without conformal coating. I usually start looking at the problem differently once I start to see 1M resistors are needed.
I would be tempted to series connect a dozen, or more, 1M SMD for a big resistance if resistance that big is really needed.
Spread along a really clean PCB should perform reasonably well.
Q.)
What could be used as an insulating coating?
Is polyurethane varnish suitable, or shellac, or .....?
I go into a hardware retailer and ask for "conformal coating please".
I'll get a funny look !
Google lists only one supplier of a 3M coating, all the other offer a coating service.
Acota
Stafford Drive, Battlefield Entreprise park
Shrewsbury,
Shropshire,
SY1 3BF
Tel: 01743 466 200
Please Quote Ref: Novec Coating Online. This will help our call team to deal with your enquiry as efficiently as possible.
You'd order it from a specialty electronics supplier obviously. I can't remember the last time I walked or drove anywhere to purchase parts for one of my projects beyond simple fasteners and the like.. 😀
I certainly would not rely on polyurethane, varnish or shellac purchased from the local hardware store or home center for something like this. Could be hazardous and probably also not provide the required electrical performance since it wasn't formulated with this in mind.
10Meg to 1Gig resistors are not unusual in instrumentation measurement systems. 1% is fairly easy.
Take a decent electrometer op-amp wired in inverting mode with a 1Gohm feedback resistor. 10nA input gives 10v output. Simple! Then the fun begins: guard rings on the pcb and/or PTFE standoffs; long integration measurement times to cancel hum etc.
But then 10pA can be measured with useful accuracy.
