VSSA Lateral MosFet Amplifier
What power should i expect from a +/- 27V supply ? I have a rather insensitive/hard to drive 8ohm speakers 86db.
As you already presented, your speakers are quite insensitive so I would suggest you rather to use power supply enabling +/- 40 to 45 Vdc on the output. VSSA's peak output voltage swing is 2 V below rails. 😉
What is the input sensitivity ?
VSSA voltage gain is x22,28 means Av=26,96 dB, so for full (43 Vp) output 1,36 Veff is necessary.
Hi LC,
I was under the (mistaken) impression that only the PCB will be offered. As I already have all the parts, please remove my request from the list. I will have my own boards made.
Kindest regards,
M
P.S. It is amazing price for the kit, BTW.
M
New List:
Joachim Gerhard 2 PCB set
AKN 2 PCB set
Idefixes 2 PCB set
kimon 2 PCB set
brianco 2 PCB set
Dane 2 PCB set
MKHunt 2 PCB set
Cambe 2 PCB set
Supernet 2 PCB set
boyet0173 2 PCB set
tom42107 2 PCB set
presbel 2 PCB set
meltman 2 PCB set
gannaji 2 PCB set
dodo 2 PCB set
jj506 2 PCB set
vgeorge 2 PCB set
touchdown 2 PCB set
wponline 2 PCB set
Luke 2 PCB set
cvtaudio 10 PCB set
Renio 2 PCB set
maillard 2 PCB set
PauloPT 2 PCB set
hcbonfim 2 PCB set
gusto142 2 PCB set
PinkPink 2 PCB set
dine1967 2 PCB set
bressix 2 PCB set
nico2k3 4 PCB set
routhun 2 PCB set
CaféNoir 4 PCB set
ColinAlex 8 PCB set
Murdoc 2 PCB set
regal 2 PCB set
AUSTINP 2 PCB set
kroyin 2 PCB set
fredlock 2 PCB set
mikvous 2 PCB set
myfi 2 PCB set
FelixG 4 PCB set
ichiban 2 PCB set
padamiecki 2 PCB set
gogu 2 PCB set
joshvi 2 PCB set
philippeleite 2 PCB set
DavorXXL 6 PCB set
sakdi 2 PCB set
buzzfo4b 2 PCB set
acqu27 2 PCB set
siberia 2 PCB set
mravlca 2PCB set
baswamin 2PCB set
gazzagazza 2 PCB set
miksi 4 PCB set
chunek 4 PCB set
raysimmons 2 PCB set
johnkrammer 2 pcb set
jony 2PCB set
Hi LC, could you also offer the power supply PCB, like the one that you have on your VSSA amp? This at least matches with the amp size and also an option for those who don't want to use the SMPS power supply.
Hi LC,
Kindest regards,
M
You can get PCB only, no problem. As PCB layout is the last but not the least important part of the game called "Catch the SQ", I suggest you to try it. 😉
AKN 2 PCB set
Idefixes 2 PCB set
kimon 2 PCB set
brianco 2 PCB set
Dane 2 PCB set
MKHunt 2 PCB set
Cambe 2 PCB set
Supernet 2 PCB set
boyet0173 2 PCB set
tom42107 2 PCB set
presbel 2 PCB set
meltman 2 PCB set
gannaji 2 PCB set
dodo 2 PCB set
jj506 2 PCB set
vgeorge 2 PCB set
touchdown 2 PCB set
wponline 2 PCB set
Luke 4 PCB set
cvtaudio 10 PCB set
Renio 2 PCB set
maillard 2 PCB set
PauloPT 2 PCB set
hcbonfim 2 PCB set
gusto142 2 PCB set
PinkPink 2 PCB set
dine1967 2 PCB set
bressix 2 PCB set
nico2k3 4 PCB set
routhun 2 PCB set
CaféNoir 4 PCB set
ColinAlex 8 PCB set
Murdoc 2 PCB set
regal 2 PCB set
AUSTINP 2 PCB set
kroyin 2 PCB set
fredlock 2 PCB set
mikvous 2 PCB set
myfi 2 PCB set
FelixG 4 PCB set
ichiban 2 PCB set
gogu 2 PCB set
joshvi 2 PCB set
DavorXXL 6 PCB set
sakdi 2 PCB set
buzzfo4b 2 PCB set
acqu27 2 PCB set
siberia 2 PCB set
mravlca 2PCB set
baswamin 2PCB set
miksi 4 PCB set
chunek 4 PCB set
jony 2PCB set
AKN 2 PCB set
Idefixes 2 PCB set
kimon 2 PCB set
brianco 2 PCB set
Dane 2 PCB set
MKHunt 2 PCB set
Cambe 2 PCB set
Supernet 2 PCB set
boyet0173 2 PCB set
tom42107 2 PCB set
presbel 2 PCB set
meltman 2 PCB set
gannaji 2 PCB set
dodo 2 PCB set
jj506 2 PCB set
vgeorge 2 PCB set
touchdown 2 PCB set
wponline 2 PCB set
Luke 4 PCB set
cvtaudio 10 PCB set
Renio 2 PCB set
maillard 2 PCB set
PauloPT 2 PCB set
hcbonfim 2 PCB set
gusto142 2 PCB set
PinkPink 2 PCB set
dine1967 2 PCB set
bressix 2 PCB set
nico2k3 4 PCB set
routhun 2 PCB set
CaféNoir 4 PCB set
ColinAlex 8 PCB set
Murdoc 2 PCB set
regal 2 PCB set
AUSTINP 2 PCB set
kroyin 2 PCB set
fredlock 2 PCB set
mikvous 2 PCB set
myfi 2 PCB set
FelixG 4 PCB set
ichiban 2 PCB set
gogu 2 PCB set
joshvi 2 PCB set
DavorXXL 6 PCB set
sakdi 2 PCB set
buzzfo4b 2 PCB set
acqu27 2 PCB set
siberia 2 PCB set
mravlca 2PCB set
baswamin 2PCB set
miksi 4 PCB set
chunek 4 PCB set
jony 2PCB set
analog_sa 2PCB set
