Meteor in Russia...
I don't think nuclear blasts are necessary. If you can detect them early enough, land a rocket on it and start pushing it off course for some hours or days. Even a relatively small push, should nudge it a few degrees out of a collision course, but you need to do it as early as possible. After all, earth is pretty small, easy to miss ;)
jan
If the thing is a few Km i guess that rocket propulsers wont be enough
and the only working pusher would be one or several thermo nuclear devices ,
ultimately the russian Tsar Bomba design in its full power unreleased version
would find itself being the savior of mankind.
On one of the videos you can hear the sonic boom(s). I haven't yet seen a video whereby one could count the seconds & do a rough calculation as to the distance. The were several "explosions" in the video, not just one big one....a string of them, of varied intensities & timings. Truely a once in a lifetime celestial event. I got to see the comet Hyukataka in all its glory on a crystal clear cold night in 96....the thing covered nearly the entire sky, once in a lifetime.
______________________________________________________Rick.........
jan
If it's solid, thats fine. If it's a gravity held accretion, push too hard and it falls apart. I suspect it would take a very long time using a very small force. One concept is to use the mass of the spacecraft a small distance from the object, with the rockets keeping the spacecraft away. Gravitational attraction would slowly pull an aggregate object.
Nasa knew about the near miss a long time ago, but I think the meteor caught everybody pants down..
I read the meteor was the equivalent of 20 hiroshima sized bombs? Whoa.:eek:
jn.
jn.
I doubt they never knew this one was coming in , why the radio silence..?
Keep it easy.
The media & NASA had said that the two events(Close flyby & meteor) were un-related.....I would tend to think they are related. The one and only reason given by the authorities was " The meteor came from a different direction".
I would contend that the two 'Tennis court size' & ' SUV size' were a binary pair in orbit, the smaller got captured by Earths gravity,
___________________________________________________Rick..........
