Hello,
that sounds fine. Haven't mentioned that till now: I am in for one stereo set.
Cheers, Tom
Cheers, Tom
Is it compatible with 115V primary?
Thank you for splitting the grounds so that it can be used as dual mono.
Looking nice 🙂
Pierre
Looking nice 🙂
Pierre
Hi Pierre,
as far as i know, there shoud be some
similar Transformers who fit in the same
Footprint out there...
Hello Brian,
GB will start after measuring the prototype.
But its good to see we've meet your taste.
Peter, it is not about the taste, it is about "no taste".
The layout is good and it will work as advertised. Thanks for the good job you guys did.
Hi Pierre,
Would be delighted to be pointed in the right direction. I could not find FL14/30, and the foot print is rather unique... It would be elegant to be able to use the same transfos. Would you consider running the primaries to terminal blocks so they can be wired for either 115 or 230V?
Alternatively I don't mind paying for a separate run with traces configured for 115V. Sorry to bother you. But this is a nice, useful design and many folks in this part of the world might like to use it 😀.
Again, if you or someone can point me to a substitute transformer that would fit that would be great. I will search too.
Thank you
Pierre
Promised.
But tonight i'm lazy.
Tomorrow, or Sunday i'll try. 😀
Promised.
Thank you! On my side, no luck so far...
Hello Pierre,
the 115/230V issue is solved.
But sadly i'm way to stupid to post the PDF here.
Send me an E-mail and you'll see....
A perfect solution. Thank you for taking the time! This will make many of us very happy 🙂.
Pierre
- Group Buys
- Paradise Phono Preregulator
