Gauging interest for 600ohm (pultec clone) LCR RIAA modules. Lundahl has 45mH and 1.8 H chokes on catalog and they are selling for 130euro/pair and you need to add a couple capacitors and few resistors. We can also run a short PCB batch to make things prettier and easier to build. I believe a target price would be 300euro/pair but maybe we can work on that if volumes go up.
Gianluca
Gianluca
yes it is ... only 10k commercial available module I am aware of is by Silk and it is said to have a roll off at higher freqs. we should be sourcing bigger chokes for a 10k unit but I guess we would be facing the same roll off.
Noguchi has a reasonably priced 600 ohm set I was considering on my next trip to Japan, but if someone had a line on a good 10k set at a decent price I could be interested.
Note, Dave Slagle Intactaudio/forum is the LCR-guru. He will tailor LCRs to suit anyones needs.
I have a pair of Lundahls and they have below acceptable tolerances. To be of use they need to be matched. They might have solved the problems now as it was a quite a few years since I bought them. I have a source who, anyway earlier, had matced units to sell.
The Tangos I had earlier had extremely tight tolerances.
Jacmusic sells matched LL chokes (3% tolerance) and as far as I know a new model is now available. I know about the many discussions on Dave's forum and i am pretty sure his irons would be' bullett proof but not sure that would be a proper andlarge group buy. I need to recheck what's the story with that 7.5k RIAA he was developing
Hello Gluca,
I guess Jacmusic has some connection with Diyparadiso in Belgium from where I have bought Lundahl. I think Lundahl made the LCRs for Diyparadiso at special order.
Do your really think 3% is good enough? Off course you can optimize with the caps and Rs but I would opt for 1%.
I need to run some sims on spice to see how tollerance comes into the game. I never worked hands on a LCR RIAA (thou I've built 2 LC 18 and 24 dB 600ohm xover for my biamped system) but i guess you need to fine tune R and C to get closer to the ideal curve.
Have done a lot of work with 600ohm LCR sims. I have many models ready. Just mail me if interested.
If you happen to have the components value for that 7.5k RIAA i'll cranck the numbers into spice and see what a 3% tolerance means. I believe Slagle's inductors come with adjustment taps, very hand for accuracy of the whole filter.
Tks Lars
my mail is
gl dot sperti at libero dot it
so far it looks like there is small interst for a GB. I'll shoot an email to Dave to see what possibilities and prices we can have
my mail is
Guys
for 500$ we can buy the set of 4 chokes (80% nickel with taps for fine tuning) from Dave Slagle to build a 7380ohm RIAA. I will order from him. It is a bit more than LL but the higher impedance, the cores, the 2% taps are worth the extra money imho.
I asked if he could offer a special price for the group buy, i will keep you posted
Hey Gluca,
Think I have a sim for the 7,3k in my computer. Will check later today and mail if I find it.
Tks again Lars. Dave also sent me his asc file. I'll go for a pentode ...
Did you buy the inductors at the end?
What inductors? I had Tango before, and Lundahl now. About Dave, I use his transformers and love them.
About Daves file, please mail it to me. Must check if it is the same I have. I found a pentodedriven(D3a) 7,3k sim yesterday.
- Group Buys
- Potential 600ohm LCR group buy
