Want to construct a power supply to power a car amp with 7 internal boards, 6 x 150 rms and 1 x 1400 rms bridged. Can someone show me a schematic which is easy to build/understand. Can such power supply be built without a custom printed circuit board (maybe a perfboard and hand wiring the components together?
http://ericarcher.net/wp-content/uploads/2009/07/tr808_snare_diy_project.pdf
would like an "all in one" amp to power highs/midrange/midbass/subwoofers. have already puchased the 6 boards, and each has it's own power supply. HOWEVER, would want to build a huge power supply to power the 6 boards (bypassing the power supply on the 6 boards) and have the huge power supply also power a mono board for the subs rated at 1400 rms.
"Power supplies are the easiest part to build, problem comes in when you start factoring in size and heat. The key for a power supply is having something that can supply the needed power for short burst and long term. If you allow me to make one the size of a shoe box, I can build one that will more than enough for anything you want. Try selling that for some one in a Honda Civic. so manufacturers make them very small, then you run into problems with heat. Heat is your killer.
The chips for the audio section audio have been around for ages, they are not very large and have been designed to be mounted for heat dissipation.
Back many years ago I had a very nice Kenwood home amp, it use 63 volts DC on each chip for the power section. the final stage IC's were no larger that wide pack of gum mounted on a large aluminium block. The amp was very heavy, all power supply, transformers.
I use a lot of 24 power supplies for my job, very high current, very heavy, very stable. The transformer is most of the weight.
If you want to build a better system than whats on the market, as you pointed out, the chips are there. But you need to get power to them in a better manner than the manufacturers do, They have to cut corners to make it fit, you don't have to."
shoe box!!!
found a schematics
Switchmode Power Supply For Car Audio
and
High Current 13.8V Power Supply
but not sure how much power each can put out?
shoe box!!!
found a schematics
and
Everybody want to built an SMPS, they are so nice and cosy, and small too, and they are sooo easy to built...anyone can make them... sorry for the ironic tone but i see so many topiks about SMPS building be they ofline or not, everyone want to build them cus they are cheaper and smaller, so what if we have no ideea of how Switching PSU work? we can always ask arround people so why bother reading about it when others can make the hard work for us?, but no a SMPS is never easy to built!!! Theyr entire string of advantages comes with much more complexity than most people realise, so people stop beying so lasy and start reading, the books don't bite you know?...
To be on topik...@wilkes5 do you even know what cind of audio amplifier you need to power? cus one reads your post without understanding much of it... so what is the audio amplifier you need to power, what VA ratings does it require, be more specific or you'l be ignored.
have no idea. changed the post to maybe be more clear. the guy which is quoted in the post made it sound really easy to build, not as easy as he makes it sound? your view and his view, different?
want a car audio amplifier. Is the SMPS supply different from the "shoebox" the guy is talking about?
Here is a beginning.
Not the best, but a start:
It has been thoroughly discussed on this forum aswell, there is a megathread somewhere.
@wilkes5 look at it this way, you want a total audio power of 2300W, for class B power amplifier you will need an PSU of about 3,5Kw, and as the power is drawn from a car battery, this means that over 200Amps will be needed for 12v, now as you have so little knowledge of SMPS, i really hope you will change your mind, it is an insane amount of power and only a well experianced technician will be able to do it properly.
^No,Not as shown.
Building a 2300W SMPS isn't going to be easy,especially if you've never built a SMPS before. close.
can you just double the values of everything in the schematic?
@wilkes5 look at it this way, you want a total audio power of 2300W, for class B power amplifier you will need an PSU of about 3,5Kw, .
the six boards are from Lazer Industries (the first one on the page)car-audio-amplifier-pcb. not sure what class amp it is considered. however, would want the 1400 x 1 channel to be class D right (have been told class D's are the only way to get big power from small supplies (car 12v battery)). so, mixing classes on the same power supply won't work?
please stick with me MarianB, learning lots. but always, always pray for what is right
Ermm,No.
Even if you doubled the output power of that design,you're still nowhere close to 2300W.
Wilkes,
making a 12v dc-dc converter is the best start point imaginable when entering the smps world.
Go start make the one presented in the sound west host.
When you get it to work, you can start thinking bigger.
However 2-3kW is really really hard if not even impossible to get with only one smps from a car battery.
Therefore - make several small ones. Or one control unit pumping several small transformers, lets say 10pcs 300w transformers...
The one in the sound west host gives you less than 300w of power.
Verry true, but still one needs the electronics basics, and he does not seam to know much of anything, that almost guaranties failiure.Wilkes,
making a 12v dc-dc converter is the best start point imaginable when entering the smps world...
^No,Not as shown.
Or cheap, I'm scoffing at the cost of a 10 amp linear power supply atm for the same voltage range (13.8v)....
just to power an old pentium 2 firewall...
@wilkes5 there are 2 books i recommend for you to read:
1.The Art of electronics
2.Power supply cookbook
thanks for help. just finished 1st semester of electronics in college. all we did was learn basic DC circuits and how to calculate total resistance/voltage/current/etc. do you still suggest the first book, because have bought a electronics book and it didn't really cover anything too much of any importance. is just listed devices and history.
maybe stop posting if the thread is a joke? it's just the "shoebox" guy made it sound easy.
the "shoebox" guy
planning on mounting the amp in an DIY electric car conversion. believe the typical battery pack for something is like 120v. someone else from DIYmobile pointed out how you need higher voltage and the "shoebox" guy quote mentions 64 and 24 volt sources. my fault for not noticing such?
with 120 volt source, can anyone picture an easy to build power supply, fitting inside a shoebox to power 3000k rms?
First off your looking at 240 volt because the standard 15 or even 20 amp 120 volt branch curcuit will not supply enough power only 1800 and 2400 watts out of the wall. What your looking at more like 20 amp 240 volt that can supply 4.8kw or at least 15 amp 240 volt 3.6kw curcuit to start that not going to fit in a shoe box unless the shoes are for a nba center.the "shoebox" guy
Read them both in that order and i think after that you alone will at least smile reading your own posts so far.
Is this the second book you are referring to? Power Supply Cookbook, Second Edition (EDN Series for Design Engineers): Marty Brown: 9780750673297: Amazon.com: Books
- Power Supplies
- Car Amp Power Supply
