tapped horn is new to me
Oliver
Here is my list.
Box size - 34*24 * 42.
frequency -35 to 100Hz @ 135 spl
I will be moving it around .
Music type. Soul, pop, old school hip hop and soca.
Let me know if you need more information.
Oliver
Here is my list.
Hi Nathenry,
The two TH examples I referenced should give a choice to work from. To reach ~~135dB it will take about four of the 6-Fold boxes, and 3 of the TH18's (and that doesn't take into account any form of high power losses). If you have taken the time to work through the TH18 thread you will have noticed, that there is currently a debate about the application of a "cone correction" to the throat area of the horn path. Keep on looking at this thread until that subject has been resolved.
I'll attach a quick Hornresp comparison between both boxes with the driver @ Xmax (9mm), and a quick spreadsheet comparison of the external dimensions.
kHi Nathenry,
Oliver sorry I did not mention that I bought two more of the b&c driver on a good labor day sale and I also read about the cone correction plate that will make the driver preform better and add a few more db to the tapped horn output. I will be watching that thread to see the outcome and hopefully learn somethings about tapped horn. I also know that the lower the tapped horn play the bigger the box get and I am cocomfortable with the 6 fold design.
Thanks Oliver
Hi Nathenry,
"...comfortable with the 6 fold size..."
That should be interesting, and basically you have an almost perfect fit for your driver. I just wanted you to think a little more about the size, extension and SPL tradeoffs. It seems that most people that have looked closely at this have opted for the Xoc1 TH18; lighter weight, greater power handling, higher SPL, but slight loss at the very low end. It is definitely your decision to make, you know your requirements, etc...
One question that I have never gotten a good grip on (maybe the experts can jump in here?) are the tradeoffs between the throat correction as now suggested, the short/small S1 throat as in the Furybox, and an actual, optimized throat chamber with basically S1=S2 transition into the horn (as in the DTS-20) . I'll have to do some more work on this, but that should not slow you down.
The Xoc1 6-Fold w/ a simple throat correction should be your ticket. 🙂
Hi Nathenry,
I will take a closest look at both box size
Oliver
The xoc1 TH18 put out 2.5 db more than the 6 fold from 40Hz up and used less wood to build. The 6fold goes down to 35Hz and is larger than the xoc 1TH18 with less output so I will go with the xoc1 Th18 lighter and louder with little lost in the low end.
Thanks for the eye opener
hi nathenry.
you might want to take a look at this one too,also designed around the tbx.
its <17 cubic feet
Hello epa
Is there any cone correction for this tapped horn.
in this case the driver is almost at the first bend.
there wil be no pressure bild up near the edge of the driver.
so in this case i think its not nesecerry.
Post #683
Hi epa,
For your design in Post #683: with the 18TBX100 you might benefit from moving the driver as close to the mouth as possible, which will also shorten L12, and reduce S2 a little bit.
Hi epa,
hi nathenry.
its <17 cubic feet
How does your design compares to the xoc1 th18.
From power handling to the amount of wood to build one.
Once everything is said and done I will build a th.
in this design al longer s4>s5 is used to boost the bottom octave.Hi epa,
i wil play with the sim to see what it does.
tnx.
i wil have to compare them.How does your design compares to the xoc1 th18.
one moment..
black is the xco1 th 118 ,grey is my design.
the 118 has the low knee at 50 hz ,mine 40 hz
excursion differs 1mm in favor of the th118.
btw not 100% sure this is the correct sim of the th 118.
i think you can make my model out of 1 sheet 5'x10'
i think the same for the th118
one moment..
Epa
Thanks for the data they are close.
Hi Nathenry,
Looks good. 🙂 Here is the combined SPL w/ 700W into each, 4 in parallel in Hornresp (no compression, etc.):
Oliver
I am looking at the tapped horn for my next build with the same speaker.
Hi Nathenry,
Oliver
- Subwoofers
- Bass for my soldier
