De-Lite grounding
I have built a De-Lite using the IXYS 20N Dep fets. I have made a sort of star grd on the module where the Power grd, speaker and input grd are connected together. Should I be getting hum? It sounds like 50/60Hz.
I am posting a pic as I might have had that "illuminating" moment as you do when you think hard.
I originally had the tx at the rear of the case. The bridges are attached to the rear panel. To free up more space I moved it to the front (see pic). The tx secondary wirings are running back to the bridges along the side of the case, under the power amp modules. Could this be causing the problem?
