100W Ultimate Fidelity Amplifier
thanks for reply.i have also seen o photo of B500 with one pair of output transistors.can you post the pcb?
so ,for home audio in the range of 50-100 watts which one do you suggest? ax14, B500 with one output pair, or something else?
Hi ive just recently come accross this thread and after trying to sift over all 131 pages ive become lost, hehe guess im not the brightest.
Can someone pls post the most recent working and well tested Schematic, PCB, of the Amplifier and Full protection and power supply.
Im am going to build a stereo, what Voltage and VA rating Toroidal should i buy, Ill buy one per channel.
Thanks , even links to most recent pcb etc will be so helpfull.
I have build PSU that APEX posted which has clipping indicator,dc protect,vi limiter and two 10000uF caps on board as well as rectifier bridge and some changes he gave me to use it with 24-0-24 transformer.its a great all in one PSU .
APEX do you have the same PSU but with four 10.000uF caps or is it possible to redesign the same?
Thank you Mile but i decided to use sr200 as you stated of its quality of sound and performance
but there is no protection to it in the pcb can i add b500 protection ckt to sr200
there are so many versions of pcb of sr200 which pcb is to be used can you please suggest me
thank you
