I am offering a group buy for the ES9018 Reference Audio DAC PCBs. You can make your own very high performance ES9018 DAC using this PCB at home. This is a all-in-one DAC board with everything onboard including IV stage, pre-regulators, main regulators, separate AVCC buffers, isolated I2C interface, etc. The power supplies and IV stage can be bypassed if buyers wish to have their own IV stage and regulators. A single DAC board works in stereo configuration. Two dac boards can be used if buyers wish to have it in mono configuration. The DAC can be controlled using Arduino controller. The pcb is a high quality FR4 pcb. The pcb size is about 200 mm (l) x 110 mm (b). All necessary documentations will be provided for easy assembling of the DAC.
Cost per dac board - $85
Shipping charge for single board - $15 (Shipping charge for additional boards - $10 each)
paypal charges - $5
The PCB 2D shots are as follows.
Members who are interested in participating in the groupbuy can PM with paypal ID and number of boards required. This is a pre-order offer. The boards will be shipped out in about 8 to 10 days from today.
paypal charges - $5
Hello heartwinter, did you assemble a prototype of this design? Since being a complex board one would like to know if the design works. Without such a confirmation it would be wise spending time and money on assembling this given the difficulty of procuring ES9018 DAC chip in smaller quantities.
If you already have a prototype done and tested then please post the pictures of the assembled board.
Thanks in advance!
Thanks in advance!
I meant to say it wouldn't be wise
shouldnt decoupling be a LOT closer in order to ermm... decouple? why only one GND connection for i2s?
As I spent last few days setting up account with Ismosys and negotiating the shipping prices of ES9018 (successfully) and datasheet availability, I may be interested in couple of the boards, if there would be possibility of some price discount for them ;-)
ES9018 DAC PCB GROUPBUY - WORLDWIDE SHIPPING
I am offering a group buy for the ES9018 DAC PCB. You can make your own very high performance ES9018 DAC using this PCB at home. This is a all-in-one DAC board with everything onboard including IV stage, pre-regulators, main regulators, separate AVCC buffers, isolated I2C interface. The power supplies and IV stage can be bypassed if buyers wish to have their own IV stage and regulators. A single DAC board works in stereo configuration. Two dac boards can be used if buyers wish to have it in mono configuration. The DAC can be controlled using Arduino controller. The pcbs are high quality FR4 pcbs. The pcb size is about 200 mm (l) x 110 mm (b). All necessary documentations will be provided for easy assembling of the DAC.
The actual PCB Photos are as follows
46 PCBs are available for immediate worldwide shipping. Members who are interested can PM.
could you post the schematic and top and bottom layer pictures please, so we can judge and discuss psu and decoupling design?
You get one thread in vendors bazaar. If you want more than that you can consider getting a commercial forum. Please read the information at the following link diyAudio | Where can I sell my stuff?
ES9023 MINI DAC PCB GROUPBUY
I am offering a group buy for ES9023 mini DAC pcbs. You can make a low cost high performance DAC using this pcbs at home. For someone who is very budget constraint this is the best bet. The mini dac can take three inputs USB, SPDIF and I2S signals which can be switched digitally using a single three way switch. The USB receiver is PCM2707 and the SPDIF digital receiver is WM8804. The pcb size is about 110 mm (l) x 60 mm (b).
The enclosure can be bought from here Aluminum Box Enclosure Case -4.33"*2.52"*0.94"(L*W*H)
This enclosure is a perfect fit for the DAC board. All components are very cheap and easy to get. The DAC is very easy to build. BOM, schematic and board layout will be provided for easy assembling. Anyone who is interested in buying the ES9023 DAC pcbs can PM with number of boards required.
Cost per dac board - $25
Shipping charge - $10
Paypal charges - $2.5
ES9018 DAC PCB revised rates are as follows
1 X ES9018 DAC PCB - $75
Shipping Charge - $15
Paypal Charge - $5
2 x ES9018 DAC PCB - $150
Shipping Charge - $20
Paypal Charge - $5
Also note that I will be sending out super low noise regulator boards for all buyers. The regulator boards will be send out only at a later date free of charge. There will be three regulator boards for one dac board. So for buyers who will be buying two dac boards will get six regulator boards.
Very nice. I'll buy a complete fully assembled unit. I can't surface mount all those components without driving me nuts.
Well, I cannot put that on the public domain, i have some restrictions over that.
Hi
can i have the schematics for es9018 ?
- Vendor's Bazaar
- FULLY FINISHED ES9023 DAC KIT GROUPBUY
