In the full range and multiway forums there are threads dedicated to pictures and stickied to the top but not this one. With the variety of different subwoofer design options it seems like a pictures thread could be interesting. I for one would love to see everyone's subs in one place
Maybe the mods could chime in on this one
(Mod note: Thread now in place as requested)
Perhaps that subs should be heard rather than seen.What? I can't say I have any idea what that post meant sorry
Here are some from the Welter Systems fleet, 15" Chorns, 2x10" & 18" Keystone subs, 2x8" and 2x12" ported subs:
Way to get the party started
Here's mine, not quite finished yet but it wont look much different with the drivers in so its close enough
More info here:
http://www.diyaudio.com/forums/subwoofers/205299-sofa-subwoofer-3.html
I will have some coming up here in a few weeks. Its 8 "12's under the bed (replacing the box spring).
This is my current FOH, the subs are 4 x Peavey 18" Lowriders in 135ltr BR enclosures. The kick-bins are P.Audio 15" E15-350N, tops 12" E12-250N with 1" selenium Dt220i on a clone JBL waveguide. Probably not as loud as Tapped Horns which I would really like to build when finances are available but still quite capable and very mobile. All the cabinets can be lifted individually by one person.
col.
col.
I will havesome coming up here in a few weeks. Its 8 "12's under the bed (replacing the box spring).
Furniture themed subwoofers for the win!
I don't think you have enough of those 😉 very cool
Ps thanks mods for changing the title 😀
C'mon... you knew it was coming, right?
Subs are lab horns. They produce the buh-HASS that guys with 50 Hz boxes can only dream about. The bottoms (kick bins) are fully loaded to 80 hz so they won't run out of excursion, and run up to 300. Kappa Pro 12 drivers. Tops are 2-way passive, with 2x8PE21 and D3300 drivers, 300 hz and up. 40 degree pattern and acoustic centers aligned. Takes a truck and trailer to move, so the whole rig doesn't get used that often - but just half will blow the roof off a typical hotel ballroom.
It's in 'block party' configuration. Naysayers think it's a comb filtering nightmare until they hear it. Clean and smooth for miles in any direction and it images like crazy at a "normal FOH position". For narrower coverage, 2 tops are stacked tweeter to tweeter, and the midbass stacked in a line next to it. Then there's the 'tower of power', where the midbass are v-plated and tops stacked like a pyramid on top - which I've only done *once*.
Thats really impressive, you should come do my prom 😱
I bet you can bring the rapture with all that, 7.83Hz 😉
THAM15
SUB: THAM15 (35 - 150Hz, 48dB/oct)
AMP: T.AMP PROLINE 3000.
Build pictures: DIY speakers
http://www.diyaudio.com/forums/subwoofers/204968-t-tqwt-double-fold-question.html
I built a little sub...
I completed this sub as part of a surround project that I'm still working on. It sounds great.
You can see all the build details at PaulWanamaker.Wordpress.Com
this looks great! It looks really solid, 350 lbs for something that size is impressive. Do you use any eq with it?
Thanks. Yes, the plate amp has EQ built into it.
Tang Band W8-670C, ~20l bass reflex enclosure, tuned to 43Hz. I'm building some matching tops with 3" Tang Band drivers atm.
- Subwoofers
- System Pictures & Description / Subwoofer Gallery
