Sound Quality Vs. Measurements
Well, I would have to disagree with that as a blanket statement.
It was actually very valuable insider's information from experienced designer who speaks of taste of food he ate personally. 😀
A lot of times, a better component makes some aspects sound better, but some worse.
Example?
What was improved, and what as the result was you getting worse?
Uh, is this directed at me? "Correlation" in a valid and meaningful manner is exactly my point.
Yes, it is directed at you. When you put some "better" component and got worse result, that means that the component is worse. Period.
It can have better look, or better reviews, or some better parameter, but something is definitely wrong with it. Like, not enough power to drive your speakers that were easily driven by an amp with ten time higher distortions, but on ten times higher output power. Or something else. But please stop repeating BS as if sound gets worse because better component exposes some other component that sounded better when something else was wrong.
My point is, if you are going to criticize by sweeping comments all participants of the thread at once, please find some arguments that are not so wrong and silly.
Well, if you are somehow taking offense to my point of comparing apples to apples when making valid correlations, and view my comments as criticizing ALL participants of the thread at once, and rudely attack me for my "BS", then maybe you have issues that I don't care to get involved with. I'd rather listen to better music. Later dude.
Talk to you later, when you are ready to answer my straight question, what was improved in sound quality, and what as the result was exposed in sound quality, that caused overall worse sound quality. Until then I know examples only how each improvement adds to the overall improvement and enjoyment. I heard such comments as yours, but they were made by sellers of crap that were suggesting to buyers to buy even more of other crap, after they complained that the component they sold sounds worse.
Class-D, Now his comments are starting to make sense........ 🙂
In his defense (not that he needs one) he doesn't so much prefer class D if I've read him right. It's merely that, as a fortuitous consequence of trying to find the simplest topology for class D, when employed by Philips, he came upon a very elegant approach (dubbed UcD) which encloses the L-C output filter within the loop and does so making it an integral part of the self-oscillating system. And it's done in such a way as to significantly enhance the high-frequency performance, compared to just about all other class D topologies. But I don't believe that he would argue that class D is the ultimate way to go, by any means. It's merely efficient, and when that's a requirement you do the best you can.
In fact I once read that Bryston was asked by someone why they didn't pursue their own switchmode amps, and quoted Bruno's comments in response. That may be available somewhere on their site. As I recall he said in essence that one could do better with nonswitching designs from the standpoint of audio quality.
Brad
No problemo, to each his own is what I say.
Bear in mind that I am talking about an amplifier made to play music, not reproduce steaty state sine waves into a lab resistor. This means that its COTINUOUS power will never be over 25W/8 Ohms, to accomodate those transients which will come along.
Given that I have rather efficient loudspeakers, 92 dB/2.83V/1m, and that my room is small (app. 170 ft2), by the time I get to 5 Watts steady state, my window panes are swinging along with the music. By 10 Watts, I have SWAT people raiding me, and the neighbours are evacuating fast (I live in a condo). The truth of the matter is, a decent 50W per side amp will do just fine, and I have a collection of power amps. My trusty and beloved Marantz 170 DC from 1978, practically rebuilt and beefed up, is said to deliver 85 W/8 Ohms, and it just never goes over 2 Watts according to its power meters; allowing for their not too good a dynamic response (a fad in those days), even if that is actuallay 5 Watts, I am still way below its actual capability.
Attaching my Karan Acoustics KA-i180 integrated amp, rated at 180/250W into 8/4 Ohms is really overdoing it, but, as we both know, big sound is usually delivered by big amps, just as usually only big seakers will deliver a big speaker sound. Well, I got both.
So, as I see it, you really need BIG power in transients only, and what I have in mind is a REASONABLE REAL WORLD solution, not an example of a perfect amp.
To you, I would suggest you hop over here and I'll introduce you a friend of mine, Milan Karan, and his top power amp model. It weighs in at around 260 lbs and delivers 1,200W into 8 Ohms, and a hell of a lot more into lower impedances. A gift at around $50k. He has to ship it in a wooden crate.
Plus great food, great girls, an added bonus. 😀😀😀
I will accept the food and the girls, but his amp would have to make 1200 watts @.8 ohm ( like:h_ache: laboratory resistor) to tickle my fancy.... 🙂
:whacko:
Wayne, I just thought of something ...
If we say that about the average power device used today is say Toshiba's 2SA1943/2SC5200, each rated at 150W, in between those small 90, 100 and 120 W plastic devices used in the industry, and the more serious Sanken and ON Semi platic devices rated at 200 and 230 W, my choice would be a rough equvalent of 9 pairs of thiose Toshiba devices.
I just looked up their Data Sheets, and their power derating number is also 1.43. So, at 85 degrees, their actual real world power would be just (1.43 x 60 = 85.8 W; 150 - 85.8 =) 64.2 W, or about 1/3 of my initial Motoroloa/ON Semi devices. It will take three of them to equal my one.
The only advantage they would offer is the fact that the heat source would be split into 3 sources with them, which would make my heat sinks more efficient at cooling them down.
Exactly my thoughts when commenting ...
For that, I pay with additional problems with the Miller effect, which I really neither want, nor need.
Why is this, from the addional wiring ..? 😕
Subjectively, I do not believe they are anywhere nearly as robust as the Motorola trannies. I've been using Motorlola output devices for a long time, and I know from experience they will survive what many other transistors will not, and that will be a lot more than Motorola says they will. Which is why you will find them in many (even most) professional grade amplifiers, such as Bryston, Crown, Electro Voice, at al. No sexy Sankens there.
Yes unfortuantely i have had those amplifiers in the past and while robust (bryston for sure) there sonics , was well ...😱
This is all random speculation. The answer is DEEPER than either the amount of feedback or the phase margin. IF just the amount of feedback made 'clearer' sounding circuits, then we would have switched to IC op amps, decades ago.
Halcro made the 'best' high feedback discrete circuitry. Where are they, today?
It is true that zero negative feedback can sound 'soft'. Is that because that is the most natural sound, or a problem? It is anybody's guess.
However, for the Blowtorch, zero feedback was the best overall compromise. For power amps, even I cannot be sure.
I heard Halcro uses so much feedback, they had to make the amps taller than normal to accomodate .... No..?
just nothing related to audio or audio amp stability with dynamic driver loudspeakers
reputedly the test originated from concerns about driving ESL, which are a tiny fraction of the market- but it is flawed even for that purpose
most ESL systems use a step-up xfmr when driven from conventional audio power amps - their impedance doesn't look like a 1 uF cap at any frequency - there is winding series R, leakage inductance - typically there is a resonance ( = pure resistive load at the resonant frequency) just an octave above audio - at higher frequencies the amp sees the xfmr parasitics - its practically unconnected to the ESL panel C anywhere near its loop gain intercept frequency
so a 1 uF Cap isn't related to any load a typical audio power amp will ever see
with load isolating series L the ringing is way below amplifier gain intercept - it isn't telling you anything about amp stability
if the designer wants the amp to "look good" on this artificial test power output Zobel damping networks can be added
and please spare us the "resistive load" Strawman - any characterization of the sorry state of "conventional" audio amp engineering has to at least include the content of Self, Cordell's books - multidriver loudspeaker + XO complex load, I,V phase angle, peak currents from special test signals that "pump" the load resonance’s are discussed, plenty of paralleled output Q in the example circuits
I remember a lot of amps being unstable on them back in the 70's, many smoke bombs. From experience amps that are stable on such a load tend to have very good sonics and drive anything attitude. My MC3500 was one of the few amps that was tested on such a load back then and passed, not even as much as a bump ....🙂
Back then we used to call it the fire in the hole test ......:rofl::rofl:
Again, another incomplete speculation. The original Quad electrostatic had an effective capacitance of 2uF. How much capacitance in bigger electrostats? Maybe four times as much.
i recalled ... Yes !!!
I am getting tired of arguments of theoreticians who don't have experience in measuring and improving sound quality by search for correlation between sound quality and measurements...
Hey now ... look at the memories .........:rofl:
Brad
Thanks Brad,
My comment was not a put down for class-d, but was more an continuation of my previous comment many pages back about class-d types suggesting feedback is great , to the tune of using 120db or as much as possible... 🙂
I have tried class-d and it's not for me , but there are others amongst me who swear by them , yes they are deaf ... 🙂😀
Manual says 125, textbooks say 150, comments in some application guides for the outputs suggest it does better at 110. I find it curious it can barely do 110. Not too worried about it at this point. I'll think about that after I do some measurements and think about the first mods.
Thanks for the link.
Why take one side of the fence? Take both sides, use any hard data you can find and your ears both to an equal extent.
Ideally I think one should listen first, and look at the papers after, if you can.
Also take wild examples into account, like a Skullcandy versus a high-end speaker. Now, is the paper clearly showing you the difference between the Skullcandy and the speaker? If not, there is something clearly not in the papers, it's only sensical, right?
Kindest Regards,
Nicky
I tried class D back in 70'th, and it was for me. It was not for neighbors though, because they heard on their radios what I recorded on my tape recorder. 😀
Sound quality was superb. Crisp, smooth, low noise. Wider bandwidth than with conventional HF bias mixed with signal current.
@A.Wayne
I am hard pressed for an answer. I am tempted to say "everything matters", because it really is so.
But, if I had to choose, thw three most siignificant factors, in order of relevance, would be:
1. The power supply, its construction and quality,
2. The output stage, and
3. The driver stage.
Ad 1. Power is to amps like blood is to us. You can't ask a heart patient to run a marathon. If you want good sound, you have to make sure the amp is being fed with clean power and sufficient energy, while keeping a good ebergy reserve. We need those Joules badly.
Ad 2. I am NOT advocating rows upon rows of output devices, but I am saying that getting 100W/8 Ohms will take more than one pair of trannies (as im Onkyo 282 power amp). Some simple maths will determine how many, use the derating curve from the data sheet and compare that with your design goals.
I am heavily in the True Voltage Source trip, so I don't cut corners, since my 100W/8 Ohms also means 200/400W into 4/2 Ohms STEADY SТАТЕ (although the heat sinks will give way soon enough), at which time I will need to have those trannies working at no more than about 50% of their actual, real world capability if I don't want excessive distortion, so at 956 Watts of EFFECTIVE power at 65 degrees centigrade, 3 pairs of Motorola/ON Semi TO-3 MJ 21195/21196 will do the job just right.
Ad 3. I use a triple stage, meaning predriver -> driver -> output stage. Predriver is not critical if it is used properly, but the drivers stage I find is all too often being "saved" on.
While a single 50W trannie will do the job, TWO 50W trannies witl do an even better job, the lower the impedance of the speaker, the better.
Anyway, many years ago, I discovered that two parallel 50W trannies will do the same job better than a single 100W trannie.
Rgardin slew rate, my feelings are paired.
One is that it has been accepted that if your slew rate is 0.5 V/uS per each PEAK volt of output power, you should not have problems with that aspect. That would mean, for example, 20 V/uS for a nominally 100W/8 Ohms amplifier.
My personal feeling is that I am far happier with double that, I don't like to just get by, I prefer a nice safety margin. But that's just me.
The other is that we talk of VOLTAGE slew rates, but hardly anybody even mentions CURRENT slew rates, expressed a xx A/uS. What use is an amplifier which can do say 200 V/uS, but only say 5 A/uS, when driving difficult load speakers?
To be fair to the industry at large, capacitor manufacturers consistently fail to declare their products in both of those factors. In my life, I have seen only one manufacturer who did it by the book, that was Siemens regarding their Sikorel range; they stated a speed of 100 V/uS and 10 A /uS.
The point being that if you have electronics capable of 200 V/uS, but capacitors which can do say 40 V/uS, your EFFECTIVE overall slew rate is just 40 V/uS.
I am still a newbie in most things audio, but am starting to form some overall opinions, which might be off track, while still trying to learn what is important to measure (and thus to design toward). Please feel free to point out anyplace where I might not be correctly targeted, in what follows.
Power supply was mentioned as number one consideration. Current slew rate and potential limitations due to capacitors were mentioned. Transient distortion was mentioned. These were gratifying to see, because I have been tending toward thinking that these are some places where differences could exist that could discriminate between systems with merely good or great performance and those that are truly exquisite, probably because of differences in the accuracy of their reproduction of transients.
Power supply: The "signal path" that actually makes the sound is through the power supply; specifically, the currents from and to the power supply. The small-signal path and everything up to the output devices is obviously just as important. But that's not what is driving the speakers. And the power supply seems to have taken a back seat because the focus often tends to be on the small-signal "signal path" and the rest of the active "amplifier" circuits.
One could have perfection up to and including the base or gate drive signals of the final output transistors, but ALL transistors are actually passive in their behavior, i.e. they are just valves, not pumps, just voltage- or current-controlled resistances, and if the transient current that is demanded (allowed, actually) is not available to flow through them exactly when and how it is needed, then transient reproduction will be imperfect.
So that would mean that the transient response of the power supply, as seen by (at) each output device, could be very important. Specifically, the decoupling capacitors' ability to accurately supply transient current demands would be very important.
I have been trying to put numbers and equations to that, in another thread, and so far it looks like it would not be difficult at all to end up with insufficient transient slew-rate capabilities, even just due to parasitics, particularly parasitic inductance.
So I suspect that could be a problem in real amplifiers and needs to be measured and needs to be analyzed during the design phase. i.e. It could be an opportunity to make a better-sounding amplifier than those who don't worry about it.
For those who are still interested: After reading part of the latest edition of Henry W. Ott's book, "Electromagnetic Compatibility Engineering", I realized that inductances in parallel will have a lowered total inductance, just as (similar algebraically, at least) parallel resistances have a lower total resistance, but only if there is no MUTUAL inductance. So one potential aid to implementing more-effective decoupling capacitance might be to use multiple parallel capacitors that do not share conductors, up to the point to be decoupled. If you use multilayer circuit boards then this might not be of as much concern. For the rest, it might be very important, i.e. more difficult to implement.
Then I thought, "Why not apply the parallel-inductance-reduction concept to the entire power and ground rail structure?". That would imply using multiple parallel conductors for each power and ground rail. Both the main smoothing caps (or most of them) and the decoupling caps could each have their own copies of the power and ground rails. Theoretically, we could then make the power supply impedance, as seen by each active device, as low as we wanted, just by using more parallel rails and decoupling capacitors (but actually limited, unfortunately, by geometry). If you use multilayer circuit boards, this might translate into distributing multiple power and ground feed points for the power and ground layers.
Even though I thought I already knew the answer, I modeled the concept with LTspice, using three 1000 uF smoothing caps, for the two cases of a) one conductor each for power and ground rails and b) three conductors each for power and ground (with one set for each cap), while also modeling the parasitics of all of the conductors and the capacitors, and the impedance vs frequency plot as seen by the load was significantly better with multiple parallel copies of each rail.
Again, my preliminary calculations appear to show that if one is just placing single decoupling capacitors per rail "as close as you can" to each active device, then even if the caps are sized correctly there is a significant probability that transient-current capabilities would not be sufficient for accurate transient reproduction, at least in the worst case, for some amplifiers.
Coincidentally, maybe, in that light it seems like paralleling a larger number of lower-power output devices should be able to help accomplish the same goals, and is probably already providing some of the same benefits to transient response capabilities and accuracy, when used, even if only accidentally. i.e. Even with typical topologies that are already used it could be partially implementing the multiple-parallel-decoupling-capacitor concept (although multiple parallel caps per output device might still be needed). And it should also lend itself well to implementation of multiple parallel copies of each power and ground rail, if needed.
Tom
Jan,
By popular request, I have placed this article online here:
Linear Audio | Online Resources
(2nd article down).
Opinionated perhaps, but Bruno is one who shores up his opinions with facts and figures. If someone would not agree on something with Bruno, he would have to show the flaw in his reasoning or his facts and figures. So far, no callers 😉
I have done so previously.
Bruno simply brushes the effects of "distortion of distortion" of as non-significant and excludes them from his math and figures.
He does that as a pure ex cathedra assertion (which incidentally is false) without any proof or even showing a first order effects assessment of the quantity and quality of these effects.
This means that as correct his remaining math is, it is utterly useless as it starts from false premises.
Instead of endless theorising Bruno could have taken an actual amplifier and actually measured it, to show what is going on.
Ciao T
@gootee
Tom, your point is well taken.
Speaking strictly for myself, some 20+ years ago, I decided that parallelled capacitors make better sense than a single mammoth one. Thus, by default, I will rather use 2 x 10,000 uF rather than 1 x 22,000 uF.
As a matter of fact, I'll use a triplet: 10,000//10,000//4,700 uF, or some such. They will all be placed before the voltage/current regulator, but no matter what I may do, the actual power amp board will contain 100uF//1uF//0.1uF set on each power line.
What I should also mention is that I will also use a power line filter, to clean up the mess coming in through the grid before it even gets to the power transformers. It is not a power line modifier or shaper or whatever, just a straight filter, and since I've been making and selling them since 2002, I won't go into detailed description lest I be accused of advertising. Its merits have been established over time - perfect it is not, but it does help audibly on most equipment. The point is, I pay very particular attention to my power supplies.
Years ago, I accepted 75 micron copper tracing on my epoxy boards as my standard, that's double the industry standard, not to even mention wide traces, etc. The problem of parasitic capacitance is not a new one. In my case, it has led to eliminiation of some compensation networks, which where found to be completely unnecessary bceuase the quality of the artwork (done by a friend who has been in it professionally for the last 30 odd years, having worked in a HF lab and the military - I am good, but he's WAY better) and the materials used is such that it simply doesn't need what it used to. And certainly much less than a standard industry product, although some will probably always be required.
So your points are well taken, and I'm reasonably certain that most people here are well aware of the potential problems. Poor layout and loose artwork will quickly doom even the best of designs.
