My active 3-ways with QSC HPR-152i horns + BMS 4550 CDs + TD12M + AV15X
thats the most comprehensive collection on the web :
links to webpages with pictures and descriptions of Audio Systems with hornspeakers - Audio Voice Acoustics
Thanks Angelothats the most comprehensive collection on the web
for the double WE horn :Silbatone Acoustics, courtesy of Graaf
and as I am in the thanksgiving section, bravissimo to Angelo for this incredible list.
And more repro Western Electric horns here; http://www.audioanthology.com/
Of course the WE 16 "double" horn was not designed for stereo....it was introduced in the late 1920s.
Since the two horns are separate and joined only at the mouth, it can be used as a "one unit stereo" transducer, and most modern users set up that way.
The axis of max radiation of HF is at 45 degrees to the plane of the horn mouth for each half. It does produce a stereo image. Overall presentation is quite huge and quite different from modern box speakers.
Here's a picture of my 1400 Array clones using Be drivers and a Charge Coupled crossover. I have an active set-up as well using JBL PT Waveguides
Rob![]()
Hmmm. Sounds interesting....
More details please
Temp solution to test the mid horn
another test
More evolution
As they stand / souind now
- Horn loaded systems (pictures, description and building tips)
