FS: Moving sale, lots of goodies
So in anticipation of a moving, I've gone through a vast collection of mostly unfinished projects and some chassis. I'll keep updating this thread with stuff as I uncover more.
1) UcD400 4 channel amp unfinished. Parmetal black alum anon chassis. Antek AN-7239 toroid (39V/0/39). DIYCable powersupply with Panasonic caps. Four UCD 400 AD8620 modules. XLR inputs, Speakon speaker connectors, Powercon power input, Thermal breaker power switch (in lieu of a fuse). Needs to be wired up with connections between all the stuff. $575
5) silver aluminum preamp chassis. comes with extra faceplate. $80
6) black par-metal aluminum chassis. used in my first ever tube preamp project but was noisey as I built it, so I took it apart. the chassis is pretty uglied up but could be made to be very useful for the creative person. $20
8) Silk Audio TVC preamp. Par-metal large steel chassis. 3 Sieden switches. 6 inputs, 2 bypass inputs, two outputs (although I can't recall if second output is wired currently). RCAs are top quality ones from vt4c.com. Black Cherry 1" thick faceplate, unfinished, had planned to engrave/burn, but couldn't find the pattern for the letters I wanted. Long extention shafts to keep wiring short. Silver wiring. Lots of room for adding active stage that had been planned. Hole drilled in back for powercon input. Headphone jack on front. Large knobs. $700
9) UcD 400 AD8620 monoblocks. All high end parts: Plitron transformers 500VA, dual IXYS bridges, 4 Jensen 4pole caps, bulgin switch, rod's switch kit, softstarts, ying/yang ground, XLR inputs, Speakon connectors, powercon and normal power input. Fancy chassis which cost a pretty penny to ship from Thailand.
The are all hooked up except for the switch. My idea of driving a relay didn't work. buyer would need to figure out method. I can see if I can find the details of the board I used. Its marked Amp Turn On V1.1b RCC Dec-2005.
Not super excited to part with these but have WAY too much stuff to move. Considering the parts quality, I have roughly $1400 invested. Asking $1000.
10) DIY Teres plinth. Made from maple chopping blocks, PVC, lead shot and solid oak armboard. brass cone footers. This was my original plinth before I bought a slate plinth. Doesn't come with the rest of the kit, that you provide. Arm drilled for Rega 300 arm. Free but *have to pick up*. I am not shipping, sorry.
12) bunch of non-wallwart power supplies.
12a) 2 each of 13V AC 3A
12b) 5v (DC I am pretty sure) 1.5A switcher. I think this one buzzed a bit.
Free for pick up, $10 if I have to ship (sorry, but it takes time/energy).
14) black par-metal chassis used in a couple of amp projects. Front panel drilled for meters below, but could order new one or make your own. Chassis $40 with the connectors that are currently installed and switch for front panel.
14b) 2 each 500va Avel transformers, dual primaries 115v, dual secondaries 40V/6.25a 0V. $45/ea
14c) 2 each 0-80V DC vintage meters. $40/ea
note: as setup, the front panel won't fit with meters and transformer position where they were. The meters were mounted when I ran UCD 400s off batteries in previous post.
15) 2 each APS UPC battery backup packs. They have built in chargers and are wired for 48Vdc output (54V fully charged). I used two to run UcD400s off of, but for ease and space, I am running them on AC now.
They weight >50lbs each, so local pickup is best. $50/ea
Here is a thread I made about this here.
http://www.diyaudio.com/forums/atta...8983-free-diy-teres-plinth-base-teresbase.jpg
It shows it setup and operating, but prior to paint job.
